2010 Build Pictures
Page 4 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 22, 23, 24 Next
andrewF
PostPosted: Sat Mar 06, 2010 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
j.dilisio wrote:
The board looks so simple for the amount of patch points there are on the panel.
I've always wondered how you could use an analog computer in a modular setup. Would you use it mostly as a CV generator/processor?
It would be cool to have a VU meter in there too.
It is very simple, tho I really should make sure it works before saying that.
one good example of using an analogue computer with a synth is Dan Slater's Chaotic Sound Synthesis, you can see the 1st page here
It was common to have voltmeters on analogue computers, if I built this into a larger case it would have one.
macumbista wrote:
Consider me [fr]/[g]eekishly interested in any PCBs you might have for this project!!!!
D.
glacial23 wrote:
Seconded. I was planning on building an analogue computer anyway - this would simplify matters a bit!
no worries, once tested I intend to redesign the PCB to make it smaller (=cheaper) and then will do a larger run. Also considering getting panels made to suit the pactec case.
cheers
Andrew
wmonk
Audio files: 15
PostPosted: Sat Mar 06, 2010 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Karplus Strong module by Inventor!
And you can see a little video on my blog: [url]woodymonk.blogspot.com[/url] It was streamed live to the people in the chat with my phone, so not the best sounds, but still nice Smile
Weblog!
slacker
PostPosted: Sun Mar 07, 2010 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally finished my first module, an ENS-76/CGS style VCO, nothing to look at compared to some of the amazing stuff in here, but apart from one slightly off centre socket I'm happy with it.
Obligatory guts shot
Looking lonely waiting for its friends Very Happy
macumbista
PostPosted: Sun Mar 07, 2010 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a feeling we'd been doing the same homework!
macumbista.net
PostPosted: Sun Mar 07, 2010 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
They all started like that Laughing nice compact build!
TekniK
PostPosted: Mon Mar 08, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
mistake,the format is awesome,am pretty sure it will looks cool when that case is filled up.
DGTom
PostPosted: Mon Mar 08, 2010 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome work slacker! Very Happy
I really like that all in one line style.
slacker
PostPosted: Mon Mar 08, 2010 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the nice comments folks. Hopefully more to follow soon.
RF
Audio files: 28
PostPosted: Sat Mar 13, 2010 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quad Bass ++ (Plus Lunetta)
Thomas Henry Quad Bass ++ board with Lunetta type counters/dividers/logic.
Logic included is a 4094 8 stage shift register, three 40106 clocks, 4024 divider, 4015 4 stage shift register, two XOR gates, a Divide by2/3/4/5/6/7/8 4017 circuit (a section of the CGS pulse divider), and two 4 input R/2R ladders for generating CV's. Iy uses mains power, the drum voices have individual and summed outputs and manual triggers. Banana and 1/4 inch so it'll play well with my Lunetta or modular.
I just finished a couple hours ago - Have not decided if I'll dress it up any more or not. (ie wood sides) Maybe too many colors Embarassed of jacks and knobs... That may change too.
As I learn how to use it I'll make a vid or audio clip.
bruce
EDIT to add clip & comment -
Obviously I was going for the Headley Grange vibe on the recording....
 Filesize:  180.15 KB
 Viewed:  343 Time(s)
Drums1.mp3
Uber-basic 1st patch
 Filename:  Drums1.mp3
 Filesize:  3.18 MB
 Downloaded:  1310 Time(s)
www.sdiy.org/rfeng
loydb
PostPosted: Sat Mar 13, 2010 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is some dense panel! Congrats, great build.
skylab76
PostPosted: Sun Mar 14, 2010 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm done with phase 1 of my modular named "Grendel" (ugly, but mean as hell)
Four VCOs, Two VCAs, Moog clone/Synthacon/MFOS 4 pole LP filters, 2 custom ADSRs, 3 LFOs, Rebote Delay, Knick Knacks here and there.
The "cabinet" is 100% Home Depot which is made up of oak planks (aisle 32), plexiglass front panels, 6 layers of black paint. To mount the panels, I used aluminum L strips which were screwed on to the top and bottom planks. The L strips were then threaded for 8/32 screw size. I'm adding another tier in the summer.
PostPosted: Tue Mar 16, 2010 5:54 pm    Post subject: New Clock Divider, Boolean Logic, and Schmitt Trigger module Reply with quote  Mark this post and the followings unread
I completed the final troubleshooting on the Yusynth Boolean Logic and so this module is now up and running.
This module represents some "firsts" for me. All three PCBs are homemade -- the first three I've ever made.
The Schmitt Trigger circuit board is my own design -- nothing overly complicated but a chance for me to acquaint myself with Eagle software. The other boards are Yusynth designs.
The Schmitt trigger's output produces a trigger when both inputs go "high" and does not produce additional triggers until both inputs go low. Thus, I can delay the start of a note until a clock trigger and, once the trigger is received, suppress additional triggers until the note is lifted (and the gate goes back to zero).
I'm really having a lot of fun building new "stuff"!
I decided to combine three different modules to conserve panel space -- Aries used to group related functions together in common modules.
 Filesize:  4.59 MB
 Viewed:  304 Time(s)
View of the Schmitt Trigger PCB (my first attempt to design circuitry with Eagle and to turn it into a PCB) and the Yusynth Clock Divider card.
 Filesize:  4.86 MB
 Viewed:  297 Time(s)
View of the Yusynth Boolean Logic PCB. I mounted the PCBs back to back (with spacers) to fit it all behind the panel.
 Filesize:  4.81 MB
 Viewed:  291 Time(s)
mark_olson
PostPosted: Tue Mar 16, 2010 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, Kevin!
Nice work.
Mark
adambee7
PostPosted: Wed Mar 17, 2010 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Good job Kevin. Been thinking of this module aswell for a while. Made pcbs at work but not for myself at home. Will take the plunge. Post some music you've created with it. Very Happy Very Happy
PostPosted: Wed Mar 17, 2010 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
my latest three modules using SMD got a frontpanel finaly. no wiring needed!
SMD modules
triple module
j.dilisio
PostPosted: Wed Mar 17, 2010 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,. those are amazing. Shocked
You've got this diy thing down to a science.
DRONEGOAT
PostPosted: Wed Mar 17, 2010 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the laurels. however i will accept your comment as related to the hardware only, not for the circuits. Laughing
anyways, the hardest part for me was to find sockets, switches and potentiometers that matched in height (so consequently sockets and potentiometers are ordered directly from manufacturers in asia).
Danno Gee Ray
PostPosted: Wed Mar 17, 2010 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kevin, Mathias,
You guys are machines!
droffset
PostPosted: Wed Mar 17, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Danno Gee Ray wrote:
Kevin, Mathias,
Agreed, great stuff!
Edit: Spelling mistakes.
toppobrillo
PostPosted: Wed Mar 17, 2010 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik- great job on those! I am making the transition to SMD for my modules as well... at least partially. it gets hard to squeeze everything behind these little panels Smile
Inventor
Audio files: 267
PostPosted: Wed Mar 17, 2010 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik, that is simply masterful! I shall have to follow in your footsteps someday, with your permission of course.
Les
PostPosted: Wed Mar 17, 2010 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonic, beautiful workmanship! Wow!
PostPosted: Wed Mar 17, 2010 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
This evening I finished my 2nd MPS. I revised my front panel a bit -- I will likely redo the panel on the first MPS at some point... for now I'll just leave it.
Below is a pic of my latest modules that are temporarily housed in an old 11 module cabinet. The newest MPS is on left.
The only module that I have started and not finished is the Klee Sequencer. It has a larger panel and I'm still working out details of the design.
However... I couldn't resist... and I ordered about half a dozen CGS PCBs. I can see the instrument doubling in size over the next year or two.
 Filesize:  343.18 KB
 Viewed:  313 Time(s)
adambee7
PostPosted: Thu Mar 18, 2010 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
It will always get bigger (ahem). Mines grown twice the size in a year. That is going to be one nice groove machine. Lovely work. Very Happy Very Happy
Inventor
Audio files: 267
PostPosted: Thu Mar 18, 2010 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just gotta re-emphasize my astonishment at what fonik has revealed to us here. It's truly a whole new synth format. Noicely done fonik!
Les
