Living VCOs
Page 16 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16, 17, 18, 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
janvanvolt
PostPosted: Tue May 18, 2010 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
i finally figured out what the problem was with my LVCO ...
Nwo some questions with regards to the cabling. I am using the Bill&Will Version (7U with Waveshaper).
a)
What i couldn't get to work correctly is the Octave Switch (4'/8'/16') as only one part of it is working. I am using a DPDT on-on-on switch. Alternatively i got a MTS-2 Switch (also DPDT e.g. 6 pins). What is the correct wiring for this ?
b)
The Linear VCO detuning does not seem to have any effect on the VCOs
c)
What is the correct wiring for the VCO1 PW/PWM Switches ?
d)
1V/Oct Front-Adjust: How to wire this as well ?
Thanks for any help in getting this issues fixed ( and ready for the upcoming Happy Knobbing this weekend)
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
numbertalk
PostPosted: Sun May 23, 2010 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen,
I have found something with my Living VCOs. I have all 3 VCOs' V/Oct scaling calibrated very well. I did them all individually - I turned tracking from the driver off for each and used each VCO's individual V/Oct input with my Midi-to-CV converter unit. But then when I then check the scaling from the driver's V/Oct input and set each VCO to track the driver, each one is very off. I have the driver's vibrato depth all the way down,the driver's tune is close to center - when switching tracking on I tweak it a little to tune from the low note on my keyboard (it's close - don't have to move tune very far from centered) but then when I play the highest note on my keyboard, they are all 3 very sharp.
Have I done or am I doing something wrong?
jhaible
PostPosted: Sun May 23, 2010 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're using some of the individual CV inputs for precise V/Oct control, you need to match the 100k resistors to 0.1%
JH.
numbertalk
PostPosted: Sun May 23, 2010 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I thought I might have done this, but guess I didn't.
So it sounds like I should just calibrate using the driver's V/Oct input, then, right? In that case should I use the driver's tune knob on the panel or the frequency vernier for each individual VCO when going back & forth with the trimmers to calibrate, or does it not matter?
Also, just to confirm, it sounds like the individual CV inputs are better strictly for FM/vibrato and not as keyboard-tracking inputs? Good to know.
JH.
jhaible
PostPosted: Sun May 23, 2010 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Well, you can use the individual CV inputs for precise tracking also, but then the whole chain with all its branches must use 0.1% matching.
If you only use the drive CV inputs for precise V/Oct playing, you only have to match R145 and R146 to get the same sensitivity on both inputs.
But if you want everything to be preccision inputs, then you have to match R1, R2, R3 on VCO1 (and same thing on other two VCOs), *and* you must make sure that the path from driver input to driver output also has precise unity gain, i.e. match R144, R145, R146 and R137, R141
JH.
numbertalk
PostPosted: Sun May 23, 2010 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
JH.
numbertalk
PostPosted: Mon May 24, 2010 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I went back and checked and I did use actual .1% precision resistors, 50ppm as well, for all of these *except* R137, R141 and R144.
Also the interesting thing is, to be clear, I am able to get each of the individual V/Oct inputs to scale great over a wide range. I am also able to get the 3 VCOs to scale to the driver's global V/Oct input over that same range. The problem is that these do not match up - if I calibrate to one then the VCOs do not scale properly to the other. Does this make sense? Could this simply be because of these 3 resistors, if all of those others are .1% resistors?
Right now I have it scaled to the driver but it would be nice and give me some flexibility to also be able to use the individual inputs as well.
Thanks again.
JH.
JH.
jhaible
PostPosted: Mon May 24, 2010 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again.
Yes, R137/R141 sets the gain of U11B. If this is not exactly -1, the result is exactly what you describe.
Same for R144/R145 and R144/R146.
JH.
numbertalk
PostPosted: Mon May 24, 2010 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Ah, good to know. At least it's only a handful of resistors to swap out.
Thanks again.
frenchyinmunich
PostPosted: Thu May 27, 2010 2:31 pm    Post subject: Which waveshhaper for the living VCO Reply with quote  Mark this post and the followings unread
Hello,
I built few living vco and I find them very stable.
It reminds me the ARP2500 VCOs.
Is there someone here who did a waveshaper for it?
f
loydb
PostPosted: Fri May 28, 2010 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there an FPD file for a layout like JH has on his web page? I like the asymmetric layout a lot. I've got two of these puppies I need to start building...
Mr.TorsionTorque
PostPosted: Tue Jun 08, 2010 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there... I'm considering ordering the VCOs but I've got one question.
Is hard syncing of OSC's is possible in a way of mod or something?
Thanks in advance for the answer and sorry for my English.
Noiseconformist
PostPosted: Tue Jun 08, 2010 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
look here: http://www.dragonflyalley.com/constructionJHLivingVCO.htm
Maybe Bill & Will got something you like on their fantastic site.
HTH, Michael.
hear the colours of noise
jhaible
PostPosted: Tue Jun 08, 2010 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't tried this myself, but it cannot be that difficult.
Simply build a second discharge path for C3 (referring to http://www.jhaible.de/living_vcos/living_vcos_sch_1of4.pdf), by connecting a 2nd transitor in parallel to Q3, together with a pulse shaping circuit at the base of this transistor. I will not draw this out for you in detail, but that's the idea how it could be done.
JH.
Mr.TorsionTorque
PostPosted: Tue Jun 08, 2010 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
THX for the rapid answer, thats a good idea to think about... Smile
LetterBeacon
PostPosted: Tue Jun 29, 2010 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to ask a simple question, but what exactly is a 10-turn potentiometer? Does it mean it rotates fully 10 times? Why is that better than using a coarse and fine pot?
Is this a suitable pot:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5222974
£12 each! Are they always that expensive??
jhaible
PostPosted: Tue Jun 29, 2010 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a matter of taste. Whatever user interface pleases you more - go for it. It's DIY, and just one extra resistor if you go for two pots.
I don't think a multiturn is that expensive, though. It needs less panel space, less milling for front panel graphics, only a single knob - allthough you can spend a fortune on stylish looking vernier knobs. Or get them cheap on ebay.
The most expensive solution would be a rotary switch for precise octave switching and a fine tuning pot.
JH.
LetterBeacon
PostPosted: Tue Jun 29, 2010 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply!
I'd like to go for the 10-turn pot for all the reasons you mentioned, I just want to know what the advantages are (apart from using 1 pot instead of 2).
So is a 10-turn pot a pot that goes round 10 times? Does it mean you can be more precise with it, so you don't need a fine tune?
jhaible
PostPosted: Tue Jun 29, 2010 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes and yes.
(As opposed to the method used in the VCS3: There, an ordinary pot is used, in combination with a knob with some gear inside.)
JH.
zarko
PostPosted: Fri Aug 20, 2010 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello All.
Hi Jürgen.
I just finished the wiring of the Living VCO's,and they are fonctional as entended,and sound verry fat Wink
but i have a problem with the tracking v/oct on two vco's, just one is ok and take me less than five minutes to set up,but for the two other imposible to scale correctly.
i go to try explaying in my aproximative english.
Wiring is ok ,i test all the components in ohmmeter mode and i compare all the values with the functional one, and all its ok.
For the tracking i do this:
i connect a cv source directely on the VCO V/oct.
first i ajust the freq trimpot to have 16,20hz for the zero position.
after i aply a CV of 0V and turn the potentiometer knob to obtain 55hz on my freq counter after this i aply 1V and i read 102hz,i ajust the scaling to obtain 110hz. I turn back in 0V CV and i read 57hz, i readjust the freq pot to have 55hz again, after i aply 1V CV again and i read 102hz and this indefinitively until the timpot is in the maximum
range.each time i reajust the freq knob because the freq goes up, the tracking freq goes down.
Here is my problem,i suspect the CA3046 maybe a problem with the unmatched pair?
Lets me know if one of you having the same problem.
Thank you, Regards
Fred
jhaible
PostPosted: Fri Aug 20, 2010 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
zarko wrote:
Hello All.
Hi Jürgen.
Thank you, Regards
Fred
Could it be that you're turning the Scaling pot into the wrong direction?
If your frequency ratio for a 1V CV step is too small, you must turn the scale pot in a direction to increase the ratio, not the absolute frequency. It's a bit counter-intuitive the way that scaling and tuning go into different directions, but once you know it, it's not so difficult to tune at all.
JH.
zarko
PostPosted: Fri Aug 20, 2010 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank or the reply,i try this tomorrow Wink
zarko
PostPosted: Sat Aug 21, 2010 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen
All works fine now Very Happy for the second time i make a neewbe error, in fact its the same procedure to tune the Yusynth CVO, i don't know why i thinking that it was a different way, here was my error Embarassed
Thanks.
The Bad Producer
PostPosted: Fri Aug 27, 2010 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello all,
Just wanted to say, having just now finally finished my fourth Living VCO, how great they are!
I added the Saw - Tri - Sine waveshaper circuits from Electronic Peasants diagram on page 12 and they really add so much versatility to an already great design! Linear detune on Sine waves is something else!
Having these has and will open up so many musical possibilities to me...
So thank you Juergen for the amazing VCO, and thank you also to Electronic Peasant, Ray Wilson and Ian Fritz!
LetterBeacon
PostPosted: Sat Sep 04, 2010 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks fantastic!
Do you have a stripboard layout for the waveshapers?
