today> Twyndyllyngs Chez Mosc
Fritz chaos circuit
Page 10 of 12 [278 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12 Next
Luka
PostPosted: Sun Apr 04, 2010 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
ian there is a quote in this thread way back on the 2nd page from you which states
Are the two pots in series a coarse and fine adjustment?
"Well, not really. The upper one mixes the x and y signals. The lower one sets the amplitude of the signal going into the nonlinear stage."
is this in reference to the QO in the Chaquo?
im asking this as i just made my panel for my Chaquo and planned on using a 10turn instead of course + fine QO freq controls
problemchild
melbourne australia
frijitz
Audio files: 54
PostPosted: Sun Apr 04, 2010 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
[is this in reference to the QO in the Chaquo?
No. It is in reference to the "Coupling" and "Gain" controls on the chaos generator.
Ian
macumbista
PostPosted: Wed Aug 04, 2010 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
ringer wrote:
I have a question, on the Combination Threshold/Gate/Trigger/Sample/Hold Circuit web page you write,
"I have made a short sound clip of it operating on the output of a slightly modified version of the EZ Chaos system. (The modification is the addition of an extra cross-coupling within the circuit.) ".
Would it be possible to further expand on this modification, and if possible, could you please post a schematic, so I can breadboard it and try it out.
It's further up in this thread -- just look for the scribbly drawing on May 7. You will need to cut one trace, as shown by the wiggly line, and tap into three points on the circuit for the signals, plus three for the power.
Is it just me, or has that squiggly drawing been removed from the thread? I guess you wanted to make it exclusive to the ChaQuO Chaos Generator/ Quadrature Oscillator PCB? I was also curious what this "hacked version" added in terms of functionality.
macumbista.net
macumbista
PostPosted: Fri Aug 06, 2010 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
I've designed a stripboard layout of the EZ-Chaos circuit and, with Ian's permission, present it here for anybody to use if interested.
I just built this, so consider it tested... sort of.
Like Dan, I'm having a hard time figuring out whether it is "chaotic" or not. At most LFO frequencies, it gives a quite regular pattern and sometimes quite closely follows the LFO input, only scaling it different and sometimes running it to the rails with too much drive.
With some tweaking of the controls I can get it to "wobble" through some portion of the LFO waveform, but this wobble seems quite regular... it seems like the same wobble every time.
I only get good usable chaos by sending one or two of the outputs of the module back to the LFO, and then it has the potential to go really crazy.
I'll play with it some more and maybe try to post some representative samples. I'm still curious about the secret "hack" and what that added to the possibilities.
BTW, I have two Threshold/Gate/Trigger/Sample/Hold boards and a Jerkster (among other things) on order from Bridechamber now. This one just seemed simple enough to do with the stripboard layout.
macumbista.net
macumbista
PostPosted: Sat Aug 07, 2010 7:17 am    Post subject: sound files! Reply with quote  Mark this post and the followings unread
OK, here's two examples of what I've got.
Modules used in these recordings:
Thomas Henry XR-2206 VCO (Bugbrand PCB layout)(VCO range)
Thomas Henry XR-2206 VCO (Bugbrand PCB layout)(LFO range)
Ian Fritz EZ Chaos (Uncle Krunkus stripboard layout)
In the first example, chaos01.mp3, the triangle waveform of the LFO drives the EZ Chaos. The Z (marked NL on schematic) output of the EZ Chaos drives the 1V/Oct input of the VCO. Both Drive and Rate pots are set about at the middle, and the Damping is totally turned down. As you can hear, it maintains a very steady modulation. The changes in modulation pattern only come from my manually adjusting the LFO.
(Incidentally, the X output of the EZ Chaos gave slightly different but still repeating modulations, while the Y output seemed to drive it to the rails.)
In the second example, chaos2.mp3, the poti settings and routing remain the same from chaos1.mp3. However, I have routed the Y output to the Linear FM of the LFO, and the X output to the Exponential FM of the LFO. The modulations become much more chaotic in this setup. Through the clip, I adjust the depth of the LinFM, ExpFM and the general rate of the LFO. Better, don't you think?
So my question is: does chaos1.mp3 sound right, or should I review the circuit again for errors?
Best from Berlin!
chaos01.mp3
 Filename:  chaos01.mp3
 Filesize:  2.44 MB
 Downloaded:  1605 Time(s)
chaos02.mp3
 Filename:  chaos02.mp3
 Filesize:  3.22 MB
 Downloaded:  1500 Time(s)
macumbista.net
macumbista
PostPosted: Sat Aug 07, 2010 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Block diagram.....
 Filesize:  73.78 KB
 Viewed:  644 Time(s)
macumbista.net
andrewF
PostPosted: Sat Aug 07, 2010 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing you dont have an oscilloscope handy - the easiest way to observe chaotic behaviour, bit hard to be certain otherwise.
Your samples do sound pretty nuts tho.
The EZ-chaos will not be chaotic at all settings, there are some regions of periodicity.
The Jerkster is the chaos module I seem to use the most, it is very tweakable and goes from mildly batty to chainsaw wielding psychopath in just a nudge of the drive pot. Last month I did an entire performance with only the Jerkster controlling everything, all I did was tweak the Jerkster every now and then, or vary the frequency of the signal driving it.
macumbista
PostPosted: Sat Aug 07, 2010 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Andrew... the non-feedbacked patterns sound to me like a non-linear transfer function, but don't sound chaotic at all in the sense that the transfer function remains almost identical for every cycle of the LFO at any frequency tested.
My understanding of chaotic synthesis comes from the Slater article mentioned in this thread. This involves feedback between at least two--but in my experiments up to 8--cross-modulated VCOs with a non-linear function in the feedback loop. The results tend towards certain attractors, but every cycle is distinct from the previous one, even if after 3 or 7 or 15 cycles later you might return to a common origin.
Assuming that my EZ Chaos circuit functions as it should, the benefit I see out of it would be the ability to make chaotic patterns from a single LFO through the feedback. Normally I would have to use 2 or more LFOs to get the same kind of chaotic oscillations.
However, by itself I don't hear chaos coming from this circuit, only non-linearity. It's the feedback that makes it chaotic for me. Looking at it on the scope is one thing, but hearing it is the proof.
macumbista.net
macumbista
PostPosted: Mon Aug 09, 2010 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
In case anyone else is curious, the cross-coupling mod as well as some tuning instructions can be found in the manual available for the Elby Designs version of this module:
http://www.elby-designs.com/panther/ed108-chaquo/ed108.htm
macumbista.net
frijitz
Audio files: 54
PostPosted: Wed Aug 11, 2010 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
The instructions there should get it wiggling for you. As already explained, the system is chaotic only for certain control settings. Remember, in particular, to set the driving frequency appropriately.
Ian
wmonk
Audio files: 15
PostPosted: Mon Jan 10, 2011 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question about the ChaQuo BOM. It says to use tantalum capacitors for C50 and C51. Is there a specific reason to use tantalum capacitors here? Smile
Weblog!
frijitz
Audio files: 54
PostPosted: Mon Jan 10, 2011 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any electrolytic is OK.
Ian
RSFC
PostPosted: Tue Jan 25, 2011 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just built a jerkster. Is it supposed to operate in audio range without any CV input? I mean it sounds like it functions I just expected that it was more of a modulation source and put out low fequencies but in my tests so far I find I am using it more as a weird oscillator.
frijitz
Audio files: 54
PostPosted: Wed Jan 26, 2011 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your interest. Yes, it should run up into the audio range. But if it is working correctly it will also go very low. You should be able to get periods of 10's of seconds. I use mine mainly for LFO-range modulation and control, but many folks use it in the audio range also.
Ian
frijitz
Audio files: 54
PostPosted: Sun Sep 04, 2011 9:11 pm    Post subject: Web page for ChaQuo Reply with quote  Mark this post and the followings unread
ChaQuO now has its own page at my website:
http://home.comcast.net/~ijfritz/projects/ChaQuO.htm
I've included the demos I've posted before on this thread along with a few new ones.
Ian
Dan Lavin
Audio files: 21
PostPosted: Mon Sep 05, 2011 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I need to put this on facebook so I can "like" it. Thanks Ian! Great selection of samples!
Synth DIY since 1977!
billy pilgrim
PostPosted: Wed Sep 07, 2011 7:57 pm    Post subject: Jerkster OTA polarity ? Reply with quote  Mark this post and the followings unread
Ian,
I am about to start building the Jerkster and I'm confused by differences between the 2 schematics on your site; the one with the general circuit blocks looks to have the ota inputs inverted compared to the fully fleshed out one. For example the 2 feedback loops return to the inverting input of the 1st OTA on the "general circuit block" version and the non inverting input on the fully fleshed out one. Am I reading it incorrectly ? Any advice greatly appreciated........billy
frijitz
Audio files: 54
PostPosted: Thu Sep 08, 2011 7:56 pm    Post subject: Re: Jerkster OTA polarity ? Reply with quote  Mark this post and the followings unread
Sharp eye, Billy. The inputs of all four stages are reversed (it runs OK either way). I have a note that I did that, but I don't remember why. Possibly so that the NL circuit would drive a summing node. I'd recommend using the version on the projects page.
Ian
billy pilgrim
PostPosted: Fri Sep 09, 2011 6:41 pm    Post subject: Re: Jerkster OTA polarity ? Reply with quote  Mark this post and the followings unread
I'll do that, thanks for checking it out.
asterisk
PostPosted: Wed Jan 04, 2012 1:16 pm    Post subject: double well chaos question Reply with quote  Mark this post and the followings unread
hi,
im building a euro version from ian's double well chaos PCB.
i want to use multiturn pots for the drive and damping so i have some fine control.
im having a hard time finding a 1M multiturn pot for the damping.
would it be okay to just use 100k multiturn pots for both the drive and the damping?
thanks.
asterisk
PostPosted: Thu Jan 05, 2012 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
just confirmed from ian that you can use 100k multi-turn pots for both the damping and the drive pots.
however, since the damping pot is changing from 1M to 100k, you need to change R7 to 470 Ohm.
ill post more when the module is all together with face plate and wiring all done...
asterisk
PostPosted: Mon Jan 09, 2012 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
so ive just finished up making the Double Well Chaos circuit from the PCB and it doesnt seem to be working correctly.
i was careful with my soldering and wiring and everything but its not working.
the rate pot and the damping pot dont seem to be doing anything at all. the drive pot just a little bit.
ive already done the test settings outlined in the Chaquo manual and elsewhere on the forum and it didnt behave as expected. im not getting any chaotic regions or settings at all. i think the only thing im getting at all is the drive input echoing out the outputs or something like that.
any tips about how to troubleshoot this circuit so i can get it to work?
i dont even know where to start or what problems to look for.
thanks!
andrewF
PostPosted: Mon Jan 09, 2012 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
For some settings and types of inputs this circuit doesn't do much. So have a good 1/2 hour trying different input signals and pot settings.
check the op amp power pins are getting the expected voltages. Check everything that goes to ground IS going to ground.
asterisk
PostPosted: Mon Jan 09, 2012 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did your first suggestion with no luck. tried lots of settings for about an hour.
the default setting outlined earlier in this thread and in the chaquo manual and everything in between. not much happening at all.
ill try your other suggestions though. that seems like a good place to start to find out if something isnt soldered correctly or whatever.
there might be a possibility that i forgot to ground one of the jacks. would that mess up the circuit?
PostPosted: Tue Jan 10, 2012 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Didn't Ian mention that there was some bug involving a capacitor near a chip? Can't remember that well. But you could ask him again? Smile
ACHTUNG!
