elanhickler
Joined: Jun 24, 2008 Posts: 152 Location: Gilbert, Arizona
G2 patch files: 6
Posted: Tue Aug 31, 2010 8:40 am Post subject:
Hello Yves.
I have a friend who is having a problem (maybe?) with the saw animator I built for him. This is his message:
"Last night I plugged it up and it mostly seems to work fine. I do get a popping sound out of the 2nd channel when nothing is plugged in to it. With nothing going to the "In" of channel 1 and the 1 out going to the amp I don't get anything, but doing the same with channel 2 gives the popping. Once something is plugged into channel 2 the sound goes away and it sounds fine. Got any ideas on what it could be?"
Thank you,
-Elan |
yusynth
Posted: Tue Aug 31, 2010 9:10 am Post subject:
It's a perfectly normal behaviour, the saw animator needs to be fed with something (i.e a sawtooth) otherwise the output delivers the DC of the internal modulator. There is no point at listening at the output of this module if nothing is plugged in at the input
Cheers _________________ Yves |
elanhickler
G2 patch files: 6
Posted: Tue Aug 31, 2010 9:19 am Post subject:
| Thank you Yves! I thought that was the case. |
Ojd
Posted: Sat Oct 02, 2010 1:55 pm Post subject:
| Sorry to interrupt conversation, but can anyone post a samples of saw animator itself (normal operation mode) fed with something else than saw wave, any samples really? It seems like it does magic to single vco. |
yusynth
Posted: Sun Oct 03, 2010 4:22 am Post subject:
| Ojd wrote: | | Sorry to interrupt conversation, but can anyone post a samples of saw animator itself (normal operation mode) fed with something else than saw wave, any samples really? It seems like it does magic to single vco. |
Feeding it with something else then a sawtooth is meaningless because all the effect is based on a saw. For example if you feed it with a triangle what you get is the equivalent of a mix between a triangle and a PWM pulse. Feeding it with a sqaure returns a square. Feeding it with some audio signal gives a distorted audio signal but if that's what you want you can get a better result with a disto box... _________________ Yves |
Ojd
Posted: Sun Oct 03, 2010 7:29 am Post subject:
The reason i'm asking is because i've found this one
http://www.cyndustries.com/modules_sawtooth.cfm
I'm sure you are aware of this module, seems like it has pulse wave animation too (like many vco's doing pwms at different speeds), so i thought if your module could do that too? |
yusynth
Posted: Sun Oct 03, 2010 7:51 am Post subject:
| Ojd wrote: | The reason i'm asking is because i've found this one
But this type of feature is already available on PWM VCOs, feed the PWM with a random votage and you'll get the same effects. _________________ Yves |
thermionicjunky
Joined: Dec 07, 2006 Posts: 90 Location: san francisco
Posted: Sun Oct 03, 2010 9:58 am Post subject:
I'm guessing that the Cyndustries module processes the output of the saw animator to produce a squared version. It uses the same input saw. You can do similar things with external waveshapers. |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Thu Dec 02, 2010 11:40 pm Post subject:
Is there an interconnection wiring diagram available for this add on board?
I'm not too great at reading schematics. _________________ LektroiD |
yusynth
Posted: Sat Dec 04, 2010 3:06 am Post subject:
| LektroiD wrote: | Is there an interconnection wiring diagram available for this add on board?
I'm not too great at reading schematics. |
No, but I will try to draw one... _________________ Yves |
LektroiD
Posted: Fri Dec 10, 2010 10:52 am Post subject:
| yusynth wrote: | | LektroiD wrote: | Is there an interconnection wiring diagram available for this add on board?
No, but I will try to draw one... |
Much appreciated. Looking forward to getting this module working  _________________ LektroiD |
LektroiD
Posted: Mon Jan 03, 2011 3:17 pm Post subject:
Assuming Yves is busy since there's been no further action in this thread for the past month, I wondered if anyone else has managed to get this working?
I have both boards assembled, but just awaiting an interwiring diagram. Does anyone else who has successfully interwired them have a few spare moments to put a basic wiring diagram together for me (and whoever else is stuck on this)?
It doesn't have to be anything flash, a simple hand drawn sketch would do the job.
Thanks in advance  _________________ LektroiD |
iopop3
Joined: May 28, 2010 Posts: 94 Location: Malmö, Sweden
Posted: Tue Jan 04, 2011 10:10 am Post subject:
My pcb is still in the backlog, but this is how I would wire it up. Not tested so it might be some errors!
For the first part, the waveshaper, exchange the red cable going from LFO to Mod in the original wire diagram with,
| Code: |
________________
LFO ---> Triangle_in*| add on board |*Sine out --> Mod in
|______________|
and for the output,
| Code: |
________________
Dry Saw input --> Saw In*| add on board |*Output --> New Output
Original Saw Output --> Shifted Saw*| |
|______________|
"Dry saw input" is the same signal as you insert into the SAW pin, copper coloured.
"Original Saw Output" should the the purple output pin.
"New Output" is your output jack on the panel.
Do the same for both animators.
Yves mentions a switch on the output, that have not been added in this example. Havn't had the chance to try it out, so not sure if you need it. |
yusynth
Posted: Tue Jan 04, 2011 10:17 am Post subject:
Yes iopop3, your diagram is correct, nice ascii rendering by the way ! _________________ Yves |
LektroiD
yusynth
LektroiD
yusynth
Posted: Mon May 02, 2011 11:37 pm Post subject:
Post a photo of the add on board track side and one photo of the components side such that I can check there is no mistake.
Just to be sure were you powering the addon board ? I did not show the power wire on the wiring diagram because it was obvious but one never knows... _________________ Yves |
LektroiD
Posted: Tue May 03, 2011 5:20 am Post subject:
I piggy-backed the power from the main board.
2.76 MB |
| Viewed: |
441 Time(s) |
2.04 MB |
| Viewed: |
467 Time(s) |
LektroiD
Posted: Sun May 08, 2011 4:55 pm Post subject:
Please let me know if those photos are ok, or if anything is amiss.
I left the saw in 1 tip connected to the switch terminal of saw in 2, would that cause any problems? It's the only wiring that's not mentioned on the add-on board.
Incidentally, has anyone managed to get their add on boards working successfully, or am I the only one who can't get it working? _________________ LektroiD |
yusynth
Posted: Sun May 08, 2011 11:30 pm Post subject:
The wiring diagram is logically completed by mirror symetry.
I know at least three other people beside myself who built it without a problem.
I cannot see any obvious error on your PCB however you may check with a continuity tester that there is no shortcut between tracks or a microbreak in a track.
Check that the ICs on the board are correctly powered (+15V on pin 8 an -15V on pin 4). Have you checked the AOP ICs ? _________________ Yves |
bassculture
wackelpeter
Audio files: 10
Posted: Thu Aug 31, 2017 11:29 am Post subject:
just finished one half of the saw animator on the free parts of the stripboard from the Mutant BPF Version. Worked from start, but i was a bit curious how it would be if i can attentuate the Input Signal... so i placed a 100k attentuating pot with a 4k7 resistor in series from it's wiper and well it worked and gave some interesting results... fully cw normal behavoiur and with the Input level slowly reduced it gave some intersting sounding and looking figures until when nearly Zero Input only the Modulator Input remained at the Output... _________________ https://soundcloud.com/bastian-j |
