2010 Build Pictures
Page 18 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, ..., 16, 17, 18, 19, 20, 21, 22, 23, 24 Next
tjookum
Audio files: 26
PostPosted: Wed Oct 13, 2010 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool darkomen, I really like to see someone's first ventures into synthmaking. Very nice work on the perfboard and panels, looks great!
What are you planning on doing next?
Hunter S. Thompson
movies
noise
XCenter
PostPosted: Thu Oct 14, 2010 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
davitr0n wrote:
It's pretty simple, nearly all digital except it is controlled by voltage.
I'm planning on making kits once I finish figuring out all the small details out.
Nice Arduino-project. Would love to see it documented and available. thumb up
BTW does it follow 1V/Oct?
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/
Scot Solida
PostPosted: Thu Oct 14, 2010 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Nice,Scot!
darkomen
PostPosted: Thu Oct 14, 2010 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right now I'm working on the ds-7 clone, and I've just ordered the parts for the MFOS soundlab mini synth.
synthmonger
PostPosted: Fri Oct 15, 2010 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
info on them here http://www.flickr.com/photos/synthmonger/5083337442/
Youtube!
modular demos!
Whacky tunes!
PostPosted: Fri Oct 15, 2010 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful and unique panels. What kind of material did you use for the panels?
synthmonger
PostPosted: Fri Oct 15, 2010 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.acehardware.com/product/index.jsp?productId=1308453
I can't find the exact link to the ones I purchased but if you go inside an Ace Hardware and ask for Aluminum sheets they'll direct you to a nice display of them. Most are 4x10 but they have other sizes. They're about $4 dollars.
Stick with the 4mm or greater thickness though, the 2mm thick panels bend a lot when drilling. You'll also get a ton of burrs with either thickness.
For the labeling I use this kind of "paper"
http://www.google.com/products/catalog?q=Avery+18665&um=1&ie=UTF-8&cid=3490315950464576597&ei=ceG4TLj7FdidlQe3jJ3XDQ&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CCwQ8wIwAg#
It is semi-gloss but spray some clear coat on it and it'll end up looking great. I always spray a hefty amount on them and then bake for 5-10 seconds. As soon as it clears up I remove them from the oven or they'll start to rink up in spots. A blow dryer will probably work just as well.
Youtube!
modular demos!
Whacky tunes!
shawn
PostPosted: Fri Oct 15, 2010 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I didn't think of Ace Hardware. Nice! Now I can engrave my front panels with the cnc! Woop! Thanks man!
synthmonger
PostPosted: Fri Oct 15, 2010 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
you betcha Wink
Youtube!
modular demos!
Whacky tunes!
shawn
PostPosted: Fri Oct 15, 2010 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Meant to ask, what did you use to cut them?
synthmonger
PostPosted: Fri Oct 15, 2010 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The panels come in 4x10 size. No cutting necessary.
Youtube!
modular demos!
Whacky tunes!
Spacehardware
PostPosted: Sat Oct 16, 2010 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello all,
First of all this a great site and constant source of inspiration.
And I thought it was time I posted something after lurking for a couple of years.
This is a digital monosynth I finished this summer, (only just) in time for the Synth DIY event in Cambridge.
dsPIC30F4013 = Wave processing
PIC18F4022 = Keyboard scanner
PIC12F x 3 = LFOs
PIC16F x 2 = Envelopes
4046 PLLs = Analog Oscillators (not working yet)
SSM2044 = Filter 1
MF10 (switched cap filter) = Filter 2
And there's some YouTube stuff as well:
http://www.youtube.com/watch?v=kErBx2ZNiwE
http://www.youtube.com/watch?v=TJenM5xrqr4
http://www.youtube.com/watch?v=3PV4Us6Uc0M
 Filesize:  1.98 MB
 Viewed:  299 Time(s)
Scot Solida
PostPosted: Sat Oct 16, 2010 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Holy moly, mrbf. That is truly magnificent!
Spacehardware
PostPosted: Sat Oct 16, 2010 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Scot!
I tried to cram in as many ideas as possible, and see what sounded good.
My next project will be something smaller. Smile
johans121
PostPosted: Sat Oct 16, 2010 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
MRBF, it looks as though you used plexiglass with paper underneath for your panel. If that is the case, how exactly did you drill the holes without having melted plexiglass piled up around the drill bit exit points and how did you get such large holes without cracking the plexiglass?
I have only had minor successes drilling plexiglass without it cracking it in the process.... Sad
Don't feed me Indian, you WILL regret it!
-Jim
Spacehardware
PostPosted: Sat Oct 16, 2010 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spot on Johans, it's plexiglass with (laminated) paper underneath.
I think varying the drill speed from low to medium, and the amount of force while drilling, helped. I still got a build up of melted plexiglass on the drill bit but the holes came out ok, and cleaned up well with a bit of deburring.
Having said all that... although it's an inexpensive method, for me the end result is too reflective and can make it difficult to see the labelling.
I might try aluminium for the next project.
adamon
PostPosted: Sat Oct 16, 2010 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've had success drilling a lot of different sized holes in acrylic (similar to plexiglass) with an uni-bit (or a stepped bit). I start off with a pilot hole, then use something small like a 1/16" bit, then once I have the initial hole, I use the uni-bit the rest of the way (uni-bits won't really guide themselves without an initial hole). Uni-bits are great for thin sheet metal also...
Nice looking stuff in here everyone!
www.soundcloud.com/adamon
sndbyte
PostPosted: Sat Oct 16, 2010 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I already posted this in the Lunetta section, but thought I'd post it here as well. It's a digital logic sound machine using all CMOS chips (with the exception of one Op Amp used for a filter). It is made up off oscillators, logic gates, dividers, sequencers, lfos, melody generators, etc. You can patch the individual chips together using thin wire jumpers. The square headers are inputs and the round metal headers are outputs. There is a passive mixer but also 3 peizo disks mounted on the rear which you can use as well (that is what the 3 wires pictured are connected to). I lost count, but there are over 100 LEDs on this thing! It runs off a 9 volt battery. It is less than 3 inches thick so I can hang it on the wall when I'm not using it.
 Filesize:  535.98 KB
 Viewed:  244 Time(s)
Taylor
PostPosted: Sat Oct 16, 2010 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing! Where do you get that black perf board?
sndbyte
PostPosted: Sat Oct 16, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. It is just regular colored perf board I bought from Futurlec. I painted it black with a wide tip permanent marker.
Tasmanian Alkaloid
PostPosted: Sun Oct 17, 2010 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
macumbista wrote:
This module allows “Buchlidian” style processing of three input voltages. It can do much of what the original Buchla 257 Voltage Processor does: addition, subtraction, multiplication and division. The only feature of the 257 it lacks is the ability to “transfer control” (i.e. interpolate) between the two different applied voltages.
It contains one section with three "attenuverting"/bipolar inputs. The other section contains an analog multiplier. The panel contains two of each section. The X and Y inputs can be switched between AC and DC coupling, while the Z input is always DC coupled.
Full documentation including schematic here.
LOVE your panels!
Tasmanian Alkaloid
PostPosted: Sun Oct 17, 2010 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Top Top wrote:
the dudes over in the lunettas forum have seen this, but here is my 10 step, 7 oscillator synth/sequencer. It has a filter and sort of triangle LFO as well hardwired to the filter. All cmos.
Not the clearest photo, sorry.
magic
kupfer_m
PostPosted: Sun Oct 17, 2010 6:02 am    Post subject: Weird Sound Generator Reply with quote  Mark this post and the followings unread
Here some pics of my WSG.
Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img]
davitr0n
PostPosted: Mon Oct 18, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Honestly, I don't know much about electronics besides the basics I learned a few years ago in high school, but the VCO's can take any value from 0 to 5 volts. I can evenly distribute 5 octaves with it and have 1024 values I can use for the frequency variable from that.
It can't go too high of frequency (without some errors) since it's all being changed via code.
Do most synths use some sort of voltage addition circuit for input so that the 1v/octave can be applied with external sources?
The way I have it set up is that there is 0-5v through a potentiometer and output of that has a parallel input for additional sources. This results in a division of the two or more inputs (I believe).
I'd probably keep it the way I have it either way. That's like 6 simple modules using only two chips and a diode. (This will soon change to include 6 resistors on the ground sides of some of the pots so that smoke stops coming and/or the atmega chip wont reset because of shorting 5v to ground out of them when I do stupid things)
Oh the joys of stackable bananas.
I've been slacking on schematics since I change the design a lot. Seems like the biggest trouble I've had during all of this is my VCA wouldn't fully cut out the signal at 0 volts. I threw in a diode there and for simplicity.
loydb
PostPosted: Mon Oct 18, 2010 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
kupfer -
Awesome case!
