tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Wed Oct 13, 2010 11:56 pm Post subject:
very cool darkomen, I really like to see someone's first ventures into synthmaking. Very nice work on the perfboard and panels, looks great!
What are you planning on doing next? _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
XCenter
Posted: Thu Oct 14, 2010 1:25 am Post subject:
| davitr0n wrote: | It's pretty simple, nearly all digital except it is controlled by voltage.
I'm planning on making kits once I finish figuring out all the small details out. |
Nice Arduino-project. Would love to see it documented and available.
BTW does it follow 1V/Oct? _________________ --
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/ |
Scot Solida
Joined: Oct 24, 2009 Posts: 100 Location: Hutchinson Kansas
Posted: Thu Oct 14, 2010 3:29 am Post subject:
Thanks! |
darkomen
Posted: Thu Oct 14, 2010 3:44 pm Post subject:
| tjookum wrote: | very cool darkomen, I really like to see someone's first ventures into synthmaking. Very nice work on the perfboard and panels, looks great!
What are you planning on doing next? |
Right now I'm working on the ds-7 clone, and I've just ordered the parts for the MFOS soundlab mini synth. |
synthmonger
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Fri Oct 15, 2010 7:38 am Post subject:
Beautiful and unique panels. What kind of material did you use for the panels? _________________ -- Kevin
http://kevinkissinger.com |
synthmonger
shawn
Posted: Fri Oct 15, 2010 7:10 pm Post subject:
| I didn't think of Ace Hardware. Nice! Now I can engrave my front panels with the cnc! Woop! Thanks man! |
synthmonger
shawn
Posted: Fri Oct 15, 2010 7:41 pm Post subject:
| Meant to ask, what did you use to cut them? |
synthmonger
Spacehardware
Scot Solida
Posted: Sat Oct 16, 2010 8:30 am Post subject:
| Holy moly, mrbf. That is truly magnificent! |
Spacehardware
Posted: Sat Oct 16, 2010 9:25 am Post subject:
Thanks Scot!
I tried to cram in as many ideas as possible, and see what sounded good.
My next project will be something smaller.  |
johans121
Joined: Jun 19, 2007 Posts: 178 Location: Huntsville, AL (USA)
Posted: Sat Oct 16, 2010 10:17 am Post subject:
MRBF, it looks as though you used plexiglass with paper underneath for your panel. If that is the case, how exactly did you drill the holes without having melted plexiglass piled up around the drill bit exit points and how did you get such large holes without cracking the plexiglass?
I have only had minor successes drilling plexiglass without it cracking it in the process....  _________________ Don't feed me Indian, you WILL regret it!
-Jim |
Spacehardware
Posted: Sat Oct 16, 2010 1:04 pm Post subject:
Spot on Johans, it's plexiglass with (laminated) paper underneath.
I think varying the drill speed from low to medium, and the amount of force while drilling, helped. I still got a build up of melted plexiglass on the drill bit but the holes came out ok, and cleaned up well with a bit of deburring.
Having said all that... although it's an inexpensive method, for me the end result is too reflective and can make it difficult to see the labelling.
I might try aluminium for the next project. |
adamon
Joined: May 15, 2009 Posts: 96 Location: Lawrence Kansas
Posted: Sat Oct 16, 2010 1:12 pm Post subject:
I've had success drilling a lot of different sized holes in acrylic (similar to plexiglass) with an uni-bit (or a stepped bit). I start off with a pilot hole, then use something small like a 1/16" bit, then once I have the initial hole, I use the uni-bit the rest of the way (uni-bits won't really guide themselves without an initial hole). Uni-bits are great for thin sheet metal also...
Nice looking stuff in here everyone! _________________ www.soundcloud.com/adamon |
sndbyte
Taylor
Posted: Sat Oct 16, 2010 6:10 pm Post subject:
| Amazing! Where do you get that black perf board? |
sndbyte
Posted: Sat Oct 16, 2010 6:31 pm Post subject:
| Thanks. It is just regular colored perf board I bought from Futurlec. I painted it black with a wide tip permanent marker. |
Tasmanian Alkaloid
Joined: Jun 29, 2008 Posts: 116 Location: Isle De Mort
Posted: Sun Oct 17, 2010 4:03 am Post subject:
| macumbista wrote: |
This module allows “Buchlidian” style processing of three input voltages. It can do much of what the original Buchla 257 Voltage Processor does: addition, subtraction, multiplication and division. The only feature of the 257 it lacks is the ability to “transfer control” (i.e. interpolate) between the two different applied voltages.
It contains one section with three "attenuverting"/bipolar inputs. The other section contains an analog multiplier. The panel contains two of each section. The X and Y inputs can be switched between AC and DC coupling, while the Z input is always DC coupled.
Full documentation including schematic here. |
LOVE your panels!  |
Tasmanian Alkaloid
Posted: Sun Oct 17, 2010 4:14 am Post subject:
| Top Top wrote: | the dudes over in the lunettas forum have seen this, but here is my 10 step, 7 oscillator synth/sequencer. It has a filter and sort of triangle LFO as well hardwired to the filter. All cmos.
Not the clearest photo, sorry.
magic |
kupfer_m
Posted: Sun Oct 17, 2010 6:02 am Post subject:
Weird Sound Generator |
Here some pics of my WSG.
[/img] |
davitr0n
Posted: Mon Oct 18, 2010 11:18 am Post subject:
| XCenter wrote: |
BTW does it follow 1V/Oct? |
Honestly, I don't know much about electronics besides the basics I learned a few years ago in high school, but the VCO's can take any value from 0 to 5 volts. I can evenly distribute 5 octaves with it and have 1024 values I can use for the frequency variable from that.
It can't go too high of frequency (without some errors) since it's all being changed via code.
Do most synths use some sort of voltage addition circuit for input so that the 1v/octave can be applied with external sources?
The way I have it set up is that there is 0-5v through a potentiometer and output of that has a parallel input for additional sources. This results in a division of the two or more inputs (I believe).
I'd probably keep it the way I have it either way. That's like 6 simple modules using only two chips and a diode. (This will soon change to include 6 resistors on the ground sides of some of the pots so that smoke stops coming and/or the atmega chip wont reset because of shorting 5v to ground out of them when I do stupid things)
Oh the joys of stackable bananas.
I've been slacking on schematics since I change the design a lot. Seems like the biggest trouble I've had during all of this is my VCA wouldn't fully cut out the signal at 0 volts. I threw in a diode there and for simplicity. |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
