8-Step Sequencer with voltage controllable pattern (VCPS)
Page 10 of 14 [334 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, 13, 14 Next
brother303
PostPosted: Tue Nov 02, 2010 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
hey,first post... Very Happy
I´m a few wires away from finishing my sequencer,but there is one question.
In your building instructions there are 2 cv-outs. One on W1 (processed cv-out) and one on the gate/trigger/cv-jumper.
What`s the difference between those two outs? Is the processed-cv out on W1 only an optional thing?
Thanks for this cool project and best regards
Greg
PostPosted: Tue Nov 02, 2010 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
brother303 wrote:
Hi Fonik,
Greg
hi greg,
the CV on th the W1 pad is optional. it is just the output of the CV processor in front of the ADC.
it might be that you don't use the sequencer, or you use it without the ADC, but with the switches only. then you could still use the CV conditioner/processor for other tasks independently (attenuation, adding offset) from W1.
hope that helps.
brother303
PostPosted: Tue Nov 02, 2010 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
hope that helps.
Yes,it did! Wink
Thanks for support.
Regards
Greg
beer
LektroiD
PostPosted: Wed Nov 17, 2010 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, what type of caps are recommended for the 100nF? Obviously I'd rather go through my ceramics before eating into my collection of audio grade caps Wink
LektroiD
PostPosted: Wed Nov 17, 2010 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
i always use just ceramic for these decoupling caps.
LektroiD
PostPosted: Wed Nov 17, 2010 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
are all 21 decoupling caps, or should certain ones be higher grade?
LektroiD
PostPosted: Wed Nov 17, 2010 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
To the left hand side of the 2 circuit diagrams on the documentation of the vcps-8 , there are some layouts of caps only with i/c numbers & relevant power rail , these caps denote decoupling & power clean up duties, all the caps you see there are fine with ceramic multi-layer or yv5 rough tollerance caps & where showen electrolytics , caps of the same value that are showen in the actual device circuit diagram should been better tollerance like polyester / mylar / etc.
What i do is , mark off with a flourescent marker pen those clean up caps as i put them in first , once the decouple's are all done the remainder of that value (if any) would be polyester box caps.
oldmanfury
PostPosted: Sat Dec 04, 2010 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
New video of the VCPS in action.
http://www.youtube.com/watch?v=DKQk68Ipz3I
-gerald
PostPosted: Mon Dec 06, 2010 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
dancing
amazing build and application, man!
Adam-V
PostPosted: Mon Dec 06, 2010 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are boards for this still available Matthias?
Adam-V
PostPosted: Mon Dec 06, 2010 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are still a very few PCBs left...
Adam-V
PostPosted: Mon Dec 06, 2010 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant, I'll take 2 please.
I'll continue this via PM.
Adam-V.
Rvlt
PostPosted: Mon Dec 20, 2010 7:57 pm    Post subject:
Subject description: another batch? spare pcb?
hi everyone,
it seems that all pcbs are sold by now Sad , so if there will be another batch in the near future i would take one (or two)
OR
(just in case): if anyone has a spare pcb to sell, please pm me. i would definitely buy it.
ok, best regards,
lars
TekniK
PostPosted: Mon Jan 10, 2011 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have several pcb's for sale:
http://electro-music.com/forum/post-318951.html#318951
djg
PostPosted: Tue Jan 11, 2011 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
To clear up some confusion, when using an LM324 for the buffers, if the RA resistors are changed to 10K, would any change be needed for the RB values?
PostPosted: Wed Jan 12, 2011 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
no. the changed ratio of RA/RB sets the gain.
according BOM the RA resistors are 20k, the RB resistors are 10k. this would give you a gain of 1+(20/10)=3. since the ADC delivers 5V you will have a range of 15max. however, a TL074 wii not go that high. it will stop at 12.5V when powered by 15V. using a LM324 would help then, due to the fact that this opamp swings almost to the rails.
so if you use 10k for the RA resistors a TL074 is sufficient.
for a range of 5V you would simply leave off the RB resistors and use a bridge for the RA resistors...
in other words: decide wich output range you prefer (i set mine as high as possible and use an attenuator at the output instead), and then choose the opamp.
arnoid
PostPosted: Mon Jan 24, 2011 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Does somebody still have a blank pcb left that he wants to sell ?
If so plz contact me thru PM.
http://www.soundcloud.com/arnoid
http://www.facebook.com/arnoid
PostPosted: Thu Jan 27, 2011 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
two fellows have had some issues when using certain PSUs. the ADC won't start conversion sometimes, when powering up the module.
here is a little "ignition system"-circuit, that should help. it is a automatic start switch for the ADC, and seems to work fine (however, i had no opportunity to test it with my units, since they start and run quite fine).
explanation: the rising edge from the 5V rail when powering up the module is converted to a short pulse. the pulse controls a transistor to momentarily short pins 3 & 5 of the ADC to GND.
i will incorporate this info in the documentation soon.
patchdub
PostPosted: Sat Jan 29, 2011 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
hi folks! i'm about to make a mouse order but i can't find the 7805 or 100uf. anybody know the numbers for these? that would be much appreciated!
thanks!
www.patchdub.com
PostPosted: Sat Jan 29, 2011 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
512-LM7805CT
647-UVR1J101MPD1TD
patchdub
PostPosted: Sat Jan 29, 2011 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks matthias!
the 512-LM7805CT is on backorder will the LM78L05ACZXA work?
www.patchdub.com
PostPosted: Sat Jan 29, 2011 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
patchdub wrote:
thanks matthias!
yes. it draws much less than 100mA. i used a 78L05 on my 1U/19'' unit...
http://www.flickr.com/photos/fonik/4462779509/in/set-72157623480703851/
patchdub
PostPosted: Sat Jan 29, 2011 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! excellent build!
www.patchdub.com
emdot_ambient
PostPosted: Sun Mar 27, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Nowhere close to actually completing the build on this, but I think I've finalized my design.
2U high 19" wide panel, includes the Barton Music Circuits Simple Quantizer.
All the knobs are going to be 0.5" dia. aluminum (Mouser Part), which will match the knobs being used throughout my first 2 cases.
The drill holes for the Clock and Reset switches aren't the actual size on that rendering, as I haven't yet decided which switches to use.
Dual VCPS8 w/simple quantizer
 Filesize:  81.73 KB
 Viewed:  316 Time(s)
patchdub
PostPosted: Sun Mar 27, 2011 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
that will look sweet next to your m-185 panel!
www.patchdub.com
