today> Twyndyllyngs Chez Mosc
Buchla Source of Uncertainty 266
Page 9 of 10 [229 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10 Next
beautyofdecay_
PostPosted: Sun Nov 14, 2010 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
forbin wrote:
page 4 of this thread has some info on this including something that you need to bear in mind....
Ah yes, I missed that... I scanned the thread for the link I wanted to post and couldn't find it but didn't check for the AVR solution.
And thanks for the remark about the output voltage range. That should also be addressed with the PIC solution.
beautyofdecay_
PostPosted: Sun Nov 14, 2010 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
I have plans to merge the 4 pcb's onto 2 pcb's buchla format.
Its possible to do.
That would just be great! I also want to mount the PCBs behind a Buchla style panel. That is still possible with 4 PCBs but 2 would be nicer.
Would that be 2 100x160mm PCBs?
TekniK
PostPosted: Sun Nov 14, 2010 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
beautyofdecay_ wrote:
Its possible to do.
It surely would be great because with the size how they are now you can't built them behind a buchla panel (one 0f the 4 pcb's is to large)
i think 100x160 is just a bit to big for an easy fit in a buchla boat.
but its a huge work everything have to be redrawed
cbm
PostPosted: Sun Nov 14, 2010 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
A Buchla panel is 4.25" by 7" (roughly 107.95 x 177.8 mm). Figure the mounting rails burn .4" on the top and bottom for a usable height of 6.2" (157.48 mm) and a usable width of 4" (101.6 mm).
This means that these boards are really close to fitting. While it would be better if the board was a hair shorter, I bet that even with the 160 mm board dimension, a module based on these boards could be "rocked in" to a Buchla cabinet.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
TekniK
PostPosted: Sun Nov 14, 2010 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
indeed we want a perfect fit,not rock'n'roll Smile
cbm
PostPosted: Sun Nov 14, 2010 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
The actual opening in a Buchla boat is about 6.5" (165.1 mm) so it's just pretty tight, not really tight. Smile
Chris Muir
TekniK
PostPosted: Sun Nov 14, 2010 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thanks for the info Chris Cool
forbin
PostPosted: Mon Nov 15, 2010 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I know this is not completely true to the original (but it does seem the way that Don's designs are going these days). I was looking at rolling QRV & SRV sections of this into a dsPIC and a DAC + a little bit of support. I have built these boads and they work well but there is a little bit of tweeking that can push them a little bit further. They only need to work to 40kHz and the dsPIC is hardly breaking into a sweat at these speeds. I really doubt that this is going to change the "character" of the outputs at all... I had rather cheekily intended to call it the "Sauce of Uncertainty" I would make two of the boards into one that is about 1/2 to 1/3 of their current size....
TekniK
PostPosted: Mon Nov 15, 2010 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
forbin wrote:
I "Sauce of Uncertainty"
haha,excellent!
L-1
PostPosted: Fri Dec 17, 2010 8:50 am    Post subject: 266 in 3U size Reply with quote  Mark this post and the followings unread
I have built 266 in 3U size. Device works well. Thanks all people this tread for help!
 Filesize:  72.38 KB
 Viewed:  2738 Time(s)
 Filesize:  49.67 KB
 Viewed:  2864 Time(s)
vtl5c3
PostPosted: Fri Dec 17, 2010 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats! I hope it delivers beautiful chaos for your music.
L-1
PostPosted: Fri Dec 17, 2010 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi vtl5c3! Thank you for provided layouts but i have found some errors on pcb1 and pcb4. See images below.
 Filesize:  45.19 KB
 Viewed:  41802 Time(s)
 Filesize:  48.96 KB
mph
PostPosted: Fri Jan 07, 2011 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I am not sure of what I've read exactly but I think FunkyFarm talked about modding this module to use it with 1V/Oct instead of 1,2V/Oct...
Does it conern CV inputs and outputs? or only CV outputs?
I will use it with Yusynth modules and ACX midi to CV converter... which are all 1V/Oct.
And could a simple voltage divider do the job?
I was told to use a 2K resistor and a 10K connected to ground like this one below.
 Filesize:  6.69 KB
 Viewed:  41529 Time(s)
Peake
PostPosted: Tue Feb 15, 2011 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where can I purchase some of these pre-programmed noise PICs?
Edit: Got a couple of MNs and one FRV board is up and working. Thanks a bunch! (I'd still buy a PIC or two to replace the MNs if anything comes up.)
vtl5c3
PostPosted: Sun Nov 13, 2011 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
...almost a year later....
Sorry it's taken me this long to follow up. I checked the layouts, and I have to disagree about PCB1. The CD4070 (orCD4030) should work just fine in the orientation that I have in my layout. The pin numbers are different from Buchla's schematic, but the x-or sections will still work as required.
You are correct about PCB 4. I've fixed the mistakes and will upload the new pdfs in a moment.
Photon
PostPosted: Tue Jun 19, 2012 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I recently finished a 266-4 sample and hold from the corrected layout and can verify that it works (& is great!)
The funny thing is, almost nothing I have seems to be able to clock it. It really digs the clock out from my Blacet Binary Zone, but thats about it. The clock from the BZ is 0-15V.
Does anyone know offhand what this is expecting for a trigger level? BTW, my 208 Uncorrelated Random Voltages seem a lot less finicky about what I goose it with.
I'm curious to hear others experiences...
vtl5c3
PostPosted: Fri Jun 22, 2012 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think you might need to change some resistor values at the pulse input make it more sensitive. I can't remember what values I changed on mine, but it now triggers off 5 V pulses if needed.
Photon
PostPosted: Fri Jun 22, 2012 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'd be interested to know what the substitutions are. Very Happy
davebr
PostPosted: Fri May 10, 2013 4:37 pm    Post subject: Buchla 266 Source of Uncertainty Reply with quote  Mark this post and the followings unread
I'm in the process of building another PCB version of this module but I am making changes for +/-5V inputs and various parts substitutions. I am also taking a lot of scope images of the various functions as I analyze each circuit. I just finished up the stored random voltages. Details and photos are on my 266 webpage http://modularsynthesis.com/roman/buchla266/266sou.htm. I also have a 2U MOTM-style panel design (that is very tight) shown on that page.
[EDIT - I finished building the 266 PCBs and have lots of details on operation and output waveforms and levels on the page. I also modified it for 5V inputs and outputs.]
[EDIT - added finished picture]
synesthesia
PostPosted: Tue Jan 07, 2014 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Everyone,
I got a set of those boards-but no build doc.
I see there is the part per boards across this thread, but is there actually a full BOM?
If so where can I find it?
PostPosted: Wed Jan 08, 2014 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Which version of the PCBs did you buy? Roman's recent spin? Which format?
I've built the 5U PCBs from Synthcube, so I could advise there if that's what you have.
synesthesia
PostPosted: Thu Jan 09, 2014 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I actually have the press and peel 4xPCB version from this thread Smile
PostPosted: Thu Jan 09, 2014 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
There we go...
I"ll go sit back down now Wink
memorygardens
PostPosted: Sat Mar 15, 2014 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
what changes need to be made to make this work in MOTM. I know the cv voltage needs to be changed, but how?
PostPosted: Sat Mar 15, 2014 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most of what you need is in Dave Brown's writeup:
