beautyofdecay_
Posted: Sun Nov 14, 2010 11:14 am Post subject:
| forbin wrote: | | page 4 of this thread has some info on this including something that you need to bear in mind.... |
Ah yes, I missed that... I scanned the thread for the link I wanted to post and couldn't find it but didn't check for the AVR solution.
And thanks for the remark about the output voltage range. That should also be addressed with the PIC solution. |
beautyofdecay_
Posted: Sun Nov 14, 2010 11:18 am Post subject:
| TekniK wrote: | I have plans to merge the 4 pcb's onto 2 pcb's buchla format.
Its possible to do. |
That would just be great! I also want to mount the PCBs behind a Buchla style panel. That is still possible with 4 PCBs but 2 would be nicer.
Would that be 2 100x160mm PCBs? |
TekniK
Posted: Sun Nov 14, 2010 11:43 am Post subject:
| beautyofdecay_ wrote: | | TekniK wrote: | I have plans to merge the 4 pcb's onto 2 pcb's buchla format.
It surely would be great because with the size how they are now you can't built them behind a buchla panel (one 0f the 4 pcb's is to large)
i think 100x160 is just a bit to big for an easy fit in a buchla boat.
but its a huge work everything have to be redrawed |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Sun Nov 14, 2010 1:17 pm Post subject:
| TekniK wrote: | | i think 100x160 is just a bit to big for an easy fit in a buchla boat. |
A Buchla panel is 4.25" by 7" (roughly 107.95 x 177.8 mm). Figure the mounting rails burn .4" on the top and bottom for a usable height of 6.2" (157.48 mm) and a usable width of 4" (101.6 mm).
This means that these boards are really close to fitting. While it would be better if the board was a hair shorter, I bet that even with the 160 mm board dimension, a module based on these boards could be "rocked in" to a Buchla cabinet. _________________ Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job) |
TekniK
Posted: Sun Nov 14, 2010 1:43 pm Post subject:
indeed we want a perfect fit,not rock'n'roll  |
cbm
Posted: Sun Nov 14, 2010 3:05 pm Post subject:
The actual opening in a Buchla boat is about 6.5" (165.1 mm) so it's just pretty tight, not really tight.  _________________ Chris Muir
TekniK
Posted: Sun Nov 14, 2010 5:46 pm Post subject:
ok thanks for the info Chris  |
forbin
Joined: Jan 29, 2009 Posts: 120 Location: Fremantle, Australia
Posted: Mon Nov 15, 2010 7:22 am Post subject:
| I know this is not completely true to the original (but it does seem the way that Don's designs are going these days). I was looking at rolling QRV & SRV sections of this into a dsPIC and a DAC + a little bit of support. I have built these boads and they work well but there is a little bit of tweeking that can push them a little bit further. They only need to work to 40kHz and the dsPIC is hardly breaking into a sweat at these speeds. I really doubt that this is going to change the "character" of the outputs at all... I had rather cheekily intended to call it the "Sauce of Uncertainty" I would make two of the boards into one that is about 1/2 to 1/3 of their current size.... |
TekniK
Posted: Mon Nov 15, 2010 8:12 am Post subject:
| forbin wrote: | | I "Sauce of Uncertainty" |
haha,excellent! |
L-1
Posted: Fri Dec 17, 2010 8:50 am Post subject:
266 in 3U size |
I have built 266 in 3U size. Device works well. Thanks all people this tread for help!
72.38 KB |
| Viewed: |
2738 Time(s) |
49.67 KB |
| Viewed: |
2864 Time(s) |
vtl5c3
Posted: Fri Dec 17, 2010 1:57 pm Post subject:
| Congrats! I hope it delivers beautiful chaos for your music. |
L-1
Posted: Fri Dec 17, 2010 7:30 pm Post subject:
Hi vtl5c3! Thank you for provided layouts but i have found some errors on pcb1 and pcb4. See images below.
45.19 KB |
| Viewed: |
41820 Time(s) |
48.96 KB |
| Viewed: |
41820 Time(s) |
mph
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Tue Feb 15, 2011 3:41 pm Post subject:
Where can I purchase some of these pre-programmed noise PICs?
Edit: Got a couple of MNs and one FRV board is up and working. Thanks a bunch! (I'd still buy a PIC or two to replace the MNs if anything comes up.) _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
vtl5c3
Posted: Sun Nov 13, 2011 10:20 am Post subject:
...almost a year later....
Sorry it's taken me this long to follow up. I checked the layouts, and I have to disagree about PCB1. The CD4070 (orCD4030) should work just fine in the orientation that I have in my layout. The pin numbers are different from Buchla's schematic, but the x-or sections will still work as required.
You are correct about PCB 4. I've fixed the mistakes and will upload the new pdfs in a moment.
| L-1 wrote: | | Hi vtl5c3! Thank you for provided layouts but i have found some errors on pcb1 and pcb4. See images below. |
Photon
Posted: Tue Jun 19, 2012 4:35 pm Post subject:
I recently finished a 266-4 sample and hold from the corrected layout and can verify that it works (& is great!)
The funny thing is, almost nothing I have seems to be able to clock it. It really digs the clock out from my Blacet Binary Zone, but thats about it. The clock from the BZ is 0-15V.
Does anyone know offhand what this is expecting for a trigger level? BTW, my 208 Uncorrelated Random Voltages seem a lot less finicky about what I goose it with.
I'm curious to hear others experiences... |
vtl5c3
Posted: Fri Jun 22, 2012 5:51 pm Post subject:
| I think you might need to change some resistor values at the pulse input make it more sensitive. I can't remember what values I changed on mine, but it now triggers off 5 V pulses if needed. |
Photon
Posted: Fri Jun 22, 2012 6:33 pm Post subject:
Thanks. I'd be interested to know what the substitutions are.  |
davebr
Joined: Jun 09, 2007 Posts: 198 Location: portland, or
Posted: Fri May 10, 2013 4:37 pm Post subject:
Buchla 266 Source of Uncertainty |
I'm in the process of building another PCB version of this module but I am making changes for +/-5V inputs and various parts substitutions. I am also taking a lot of scope images of the various functions as I analyze each circuit. I just finished up the stored random voltages. Details and photos are on my 266 webpage http://modularsynthesis.com/roman/buchla266/266sou.htm. I also have a 2U MOTM-style panel design (that is very tight) shown on that page.
[EDIT - I finished building the 266 PCBs and have lots of details on operation and output waveforms and levels on the page. I also modified it for 5V inputs and outputs.]
[EDIT - added finished picture]
synesthesia
Posted: Tue Jan 07, 2014 9:33 am Post subject:
hi Everyone,
I got a set of those boards-but no build doc.
I see there is the part per boards across this thread, but is there actually a full BOM?
If so where can I find it? |
Posted: Wed Jan 08, 2014 10:09 pm Post subject:
Which version of the PCBs did you buy? Roman's recent spin? Which format?
I've built the 5U PCBs from Synthcube, so I could advise there if that's what you have. |
synesthesia
Posted: Thu Jan 09, 2014 2:50 am Post subject:
I actually have the press and peel 4xPCB version from this thread  |
Posted: Thu Jan 09, 2014 6:22 am Post subject:
There we go...
I"ll go sit back down now  |
memorygardens
Posted: Sat Mar 15, 2014 5:53 pm Post subject:
| what changes need to be made to make this work in MOTM. I know the cv voltage needs to be changed, but how? |
