bubblechamber
Posted: Fri Oct 03, 2008 2:59 pm Post subject:
just wrapping up the corrections, let a few resistors off and missed a couple connections. should be etching a prototype or 2 real soon(hopefully over the weekend/early next week). we're getting there. just taking a little longer than i had hoped. this is by far the biggest thing i've ever taken on. i'm pretty happy with it so far, just pretty complicated and i want to take my time and not screw this up.
david _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
vtl5c3
Posted: Mon Nov 17, 2008 12:23 pm Post subject:
| Will T4 & T5 (the two 2N5459s) need to be matched? |
Luka
Luka
Posted: Tue Nov 18, 2008 4:21 pm Post subject:
from photos/schems i can see
pots:
impact click (is this envelope amount?)
decay time
bend level (is this attack?)
effect amount (what does this do - lfo?)
and 2 more
+ channel volume slider (not sure if this is included in the single voice run)
jacks
decay kill
ext. pitch
trigger input
bend up/down switch (or is it a pot) _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
johans121
Joined: Jun 19, 2007 Posts: 178 Location: Huntsville, AL (USA)
Posted: Thu Nov 20, 2008 8:48 am Post subject:
I'm definitely in for 4! _________________ Don't feed me Indian, you WILL regret it!
-Jim |
JohnnyBusca
johans121
Posted: Sat Dec 06, 2008 5:16 pm Post subject:
Is this project still alive? _________________ Don't feed me Indian, you WILL regret it!
-Jim |
bubblechamber
Posted: Sun Dec 07, 2008 4:27 pm Post subject:
| johans121 wrote: | | Is this project still alive? |
Hi Jim, sorry for the delay.
It's still moving forward in a slightly on hold kinda way. i'm finishing up my apartment search/relocation from Los Angeles to NYC. that, along with my job, really slowed things down(i've got a new line of eurorack modules heading towards Analogue Haven right now). but i'm hoping to start testing a prototype when i get back home next weekend. i've pretty much wrapped up all my other projects and work stuff till the end of the year and i'm hoping to finish the testing and revisions in that time.
i'll be posting the results of the tests, and if we're really lucky, samples...
i'll also be posting a PCB for a eurorack sized panel for pots and jacks. if there's a lot of interest in that we can talk about doing a run of those, too. it'll be a almost completely wire-free design(jacks will need buss wire), using header rows and connectors with PCB mounted pots. so it'll be set up a lot like the Livewire AFG.
sorry for the delay, guys. sometimes life really gets in the way of plans, but i am completely committed to getting this and having it exactly like the original. mostly cause i really want about 8 of these in my cabinet.
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Dec 08, 2008 3:53 am Post subject:
| A run of Eurosize panels souns interesting to me. |
neandrewthal
Posted: Fri Dec 26, 2008 10:11 am Post subject:
| Luka wrote: | from photos/schems i can see
pots:
decay time
and 2 more
jacks
decay kill
ext. pitch
trigger input
bend up/down switch (or is it a pot) |
Arghhhhhh, I'm trying to figure out what the essential controls are too.
Randal said:
1) LFO rate
2) Mic. level (input sensitivity)
3) Click level
4) Pitch
5) Decay
6) Bend
7) Noise /Tone mix
Cool Bend level
9) Run time (Arp. length-TIME)
10) Effects level (modulation input atten. for LFO and Arp.)
11) Channel level
But, I clearly only see 7 pots per voice, plus the fader. What was he smoking?
Can anyone explain what controls and options are available on the PCB? _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Joined: Apr 03, 2004 Posts: 24580 Location: The Netherlands, Enschede
Audio files: 308
Posted: Fri Dec 26, 2008 5:14 pm Post subject:
| neandrewthal wrote: | | What was he smoking? |
Some of the pots apparently  _________________ Jan
Randaleem
Joined: May 17, 2007 Posts: 456 Location: Northern CA, USA
neandrewthal
Posted: Fri Jan 02, 2009 10:30 am Post subject:
Awesome! Thanks. I've been trying for a long time to find a decent pic of that thing. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
urbanscallywag
Posted: Fri Jan 02, 2009 10:43 am Post subject:
Neat paintjob and rockin' skirted pots.  |
ickystay
Posted: Thu Jan 08, 2009 9:18 pm Post subject:
| Nice to see you here, Randal. |
jmejia
Posted: Mon Apr 04, 2011 3:02 pm Post subject:
| Is anyone still working on this project? I'd be happy to pick it up and continue if no-one else had bandwidth for it! |
TekniK
Posted: Mon Apr 04, 2011 9:19 pm Post subject:
| jmejia wrote: | | Is anyone still working on this project? I'd be happy to pick it up and continue if no-one else had bandwidth for it! |
PM fonik |
Posted: Mon Apr 04, 2011 11:24 pm Post subject:
pick it up! i once did a proto PCB for testing purposes, which did not work, actually. i already handed it over to someone else one year ago... so go ahead. _________________
Tech Buddy at Random*Source |
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Tue Apr 05, 2011 3:10 am Post subject:
Coooool!
4 channels of Simmons, 2x DS7 and one MPS stuffed in a nice (euro-)case...
...awesome!
Go ahead jmejia...  |
jmejia
Posted: Thu Jun 09, 2011 11:59 am Post subject:
Quick update here - nothing too much to tell.. I'm learning kicad so I can transfer the existing design from eagle. I'm an eagle lite user - and not particularly keen on buying the full version. (The design is too big for the free eagle)
It is fairly high in my backlog pile though.. so it will happen. Just not with the speed I had initially hoped. It also looks like the majority of the work has already been done.. so likely just needs a prototype, troubleshoot, prototype, troubleshoot kind of deal. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Thu Jun 09, 2011 4:17 pm Post subject:
yay good to see someone is still working on this |
Posted: Thu Jun 09, 2011 11:41 pm Post subject:
| jmejia wrote: | | ... so likely just needs a prototype, troubleshoot, prototype, troubleshoot kind of deal. |
or breadboard it first?
just my 2 pence _________________
jmejia
Posted: Fri Jun 10, 2011 10:39 am Post subject:
| fonik wrote: |
just my 2 pence |
Yeah... my breadboarding skills aren't super awesome - and I have access to cheap rapid pcb prototyping through a local group I'm involved with here in Portland. So I tend to skip the breadboard step. That would be a whole seperate set of variables to troubleshoot for me! I should definitely get some practice in sometime though - I know I'd be better at all this stuff if I did! |
vout
Posted: Fri Oct 26, 2012 3:28 am Post subject:
Any update on this project? I would be very interested in a set of boards.
Cheers, vout |
Moogah
Posted: Fri Oct 26, 2012 7:41 am Post subject:
Been watching this with interest since the beginning too. Seems like the circuit is a bit tricky to get working reliably!
I captured the schematic in eagle a while ago (the first time this thread went dead). If nobody else is still working on this I'd be glad to do a layout and get a prototype made and see if I have better luck! |
