seraph
Editor
Audio files: 33
Posted: Thu May 19, 2011 12:59 pm Post subject:
got it  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
BobTheDog
Posted: Thu May 19, 2011 2:03 pm Post subject:
| That resonator looks very nice, I must admit I have always fancied a resonator. I play the resonator model on my vg-99 but it isnt the same! |
BobTheDog
Posted: Thu May 19, 2011 2:05 pm Post subject:
| seraph wrote: | got it  |
Is it good?
I must admit i fancy one. |
seraph
Editor
Audio files: 33
Posted: Thu May 19, 2011 3:09 pm Post subject:
| BobTheDog wrote: | | seraph wrote: | got it  |
Is it good?
I just began going thru presets and noticed that it tracks pressure very well also the electroluminescent underglow makes it visible in every light condition (very handy) not to say anything about its cool-factor!
Still have to figure out how to move my feet but the idea of controlling pitch bend and/or modulation with no hands is very alluring
I checked out the ram usage while the editor is running (more than 800Mb)
btw it's beer-proof  _________________ homepage - blog - forum - youtube
BobTheDog
Posted: Thu May 19, 2011 3:25 pm Post subject:
| seraph wrote: |
btw it's beer-proof  |
Ah, thats what I needed to know  |
seraph
Editor
Audio files: 33
Posted: Thu May 19, 2011 11:18 pm Post subject:
I knew you would appreciate this bit of information  _________________ homepage - blog - forum - youtube
Posted: Fri May 20, 2011 1:09 pm Post subject:
| seraph wrote: | | BobTheDog wrote: | | seraph wrote: |
I knew you would appreciate this bit of information  |
Cheers!  |
BobTheDog
Posted: Sat May 21, 2011 12:51 pm Post subject:
How is it without shoes?
My house is a shoe free zone! |
seraph
Editor
Audio files: 33
Posted: Sat May 21, 2011 1:28 pm Post subject:
| BobTheDog wrote: | How is it without shoes?
I think it depends if you are going to use it sitting down or standing up, plus read this from the manual:
| Quote: | | global gain - amplifies all incoming data from each key. Adjust this first before adjusting other settings. This scales all of the sensor data from the SoftStep keys and can make the SoftStep more or less responsive to pressure. If you are 2 meters tall and 110 KG you would need less global gain than if you weighed half that. |
my first impression is that it is better to use shoes of some sort but I still have to figure out many things about it. _________________ homepage - blog - forum - youtube
BobTheDog
Posted: Thu May 26, 2011 10:28 am Post subject:
| Snap, I got a SE singlecut a while ago to do the same thing to, those SEs are pretty good for the price I think. |
nobody
Posted: Thu May 26, 2011 3:48 pm Post subject:
| Stefan, I had trouble, too, but I was able to upload a file no larger than 600x600. I don't think this is what's intended. I've been PM'ing with Howard about it, so I think he's going to look into it. I think what he wants is for a 600x600 thumbnail to appear after you've uploaded an image, not to put a 600x600 restriction on the upload itself. |
Posted: Fri May 27, 2011 2:58 am Post subject:
Cheers Damien, thanks for the info. I guess it will get sorted in due time.
@Andy: sounds promising! _________________ Antimon's Window
Joined: Apr 03, 2004 Posts: 24661 Location: The Netherlands, Enschede
Audio files: 328
Posted: Fri May 27, 2011 4:40 am Post subject:
| Antimon wrote: | | I guess it will get sorted in due time. |
The auto picture resize? that one is working again already. _________________ Jan
Joined: Jan 31, 2003 Posts: 18306 Location: Durham, NC
Audio files: 235
Posted: Fri May 27, 2011 9:03 am Post subject:
Stefan or Damien: Please try to attach a pic larger than 600 X 600 here. I can't test so good because admins seem to be able to do virtually anything.
 _________________ --Howard
my music and other stuff |
Posted: Fri May 27, 2011 9:42 am Post subject:
OK, I just tried editing my original post, then I tried posting the picture in a new post, then I tried a new post with a downsized version (500 px width) and finally I tried downloading the picture from the top post on page 50 of this thread, and attached that to a new post. No luck.
Edit: rephrased the part about the downloaded image _________________ Antimon's Window
Audio files: 235
Posted: Fri May 27, 2011 1:27 pm Post subject:
Sorry, still no luck, just tried all three pics again.
Each time I've waited a minute or more, none of the files are above 350 kB, which I assume should upload quicker than that.
Posted: Fri May 27, 2011 1:33 pm Post subject:
I tried making a new thread with a pic in Schmooze with the same effect (endlessly loading after I click submit). Since you had posted a png file, I tried converting the image to png and attached that, with no luck. That file is approx 110 kB.
Posted: Fri May 27, 2011 3:16 pm Post subject:
Everything is fine here now, the last stumbling block was probably local to me. Thanks for fixing and making things better!  _________________ Antimon's Window
Inventor
Audio files: 267
Posted: Fri May 27, 2011 9:23 pm Post subject:
Now that I finally got my budget under control I put aside some cash (USD $80) for a Gyration Air Mouse Elite, which is sitting in it's cradle atop my Mac mini right now. There it rests, the key to unlocking the power of wireless motion control using ChucK.
So far I have coded two programs that use it's (theta, phi) gyro chip, both in ChucK. The first is ChucKchat, a chat-enabled multi-user web-based music jam program (see the topic in Schmooze that I will post after this message for details). The second is a Star Trek holodeck phaser practice program. As you play this game you hear a sine wave oscillator change pitch to indicate how close you are to the target. Press a button to score a hit and generate another target - fun!
Putting all the motion control pieces together (software, hardware, budget, time, motivation, etc.) fulfills a 20 year long dream of mine. I always wanted to create some type of physically interactive system, much like today's Wii game, that I could personally customize for my own enjoyment and exercise routine. The dream is reality today, and I'm having a blast with this new toy!
Les
| The Gyration Air Mouse Elite! |
157.98 KB |
| Viewed: |
182 Time(s) |
_________________ "Let's make noise for peace." - Kijjaz |
DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Sat May 28, 2011 4:09 am Post subject:
That's cool Les! And not only for musical applications; you can also go into Jedi training now, like the blindfolded Luke trying to hit the hovering robotic sphere. May the G-force be with you
DJ
Audio files: 235
Posted: Sat May 28, 2011 8:45 pm Post subject:
| Inventor wrote: | | The dream is reality today, and I'm having a blast with this new toy! |
As one of my favorite characters would say:
Wonderful! _________________ --Howard
Inventor
Audio files: 267
Posted: Sat May 28, 2011 10:46 pm Post subject:
Hehe, thanks guys! Yeah, actually Dr. Justice, what you say is quite possible with this device. Instead of a phaser that shoots out, one could hold it like a light saber and have the program calculate the position of the light rod part of it. Then the hovering sphere and that classic light saber sound could also be done in ChucK.
At the moment, however ChucK is a little bit embarrassed. You see, his mouse HID routine only reads the X and Y values and the first three buttons. That means that the accelerometer and the remaining three buttons are unavailable to ChucK. That's a shame, because the combination of the gyro and the accelerometer allow one to do limited forms of tracking, i.e. knowing not just the angle or the orientation or the g-force, but actually knowing the full (x, y, z) position and (pitch, roll, yaw) angular orientation.
Well not roll, the Gyration mouse uses only a two-axis gyro, curse them for that shortsightedness, but I guess cost is critical here. And I guess it's supposed to be a floating mouse, not a tracking device, but by now with the existence of inexpensive gyros and accelerometers in all three axes each, it's almost irresponsible for such devices to fall short in this way.
Ah well, I'm not complaining because I can do a heck of a lot with just the two axes of gyro. Luke, use the mouse!
nobody
Posted: Sun May 29, 2011 7:54 am Post subject:
I've got to check out ChuckChat!
This chump must chivalrously choose to check ChuckChat.
Say that ten times, fast.  |
