today> Bill Fox solo tonight! Chez Mosc
WaveWiper V2.1: PCBs, part kits and front panels (euro)
Page 1 of 2 [26 Posts]
PostPosted: Tue Feb 02, 2016 5:51 pm    Post subject: WaveWiper V2.1: PCBs, part kits and front panels (euro)
Subject description: interest check/now available!
After doing a test run I want to order another batch of PCBs for the WaveWiper.
For those wondering what a WaveWiper is:
"The WaveWiper is a circuit, designed to be used as a synthesizer module, that merges two signals together.
It's based on Jim Patchell's Control Voltage Splitter and it splits two input signals in a positive and negative part.
The positive halve of one signal is then added to the negative halve of the other signal and vice versa.
The level where the signals are split can be controlled with a potentiometer (the Wipe pot) or an external
Control Voltage. It has 2 CV inputs, one with an attenuator and for the other one the Wipe pot works as an attenuverter."
More info about it can be found here, here and in the manual.
There are 2 PCBs, one that contains the actual circuit (Circuit Board) and the other one (In/Out Board), that can
be connected to the other PCB by means of pin headers, which has the pots and (1/8") sockets to be used as a 8HP
euro-rack module. The first limited run had green PCBs the next ones will be black. I also made a change to
the power connector so it can now have a MOTM or Dotcom connector as well.
There are 2 part kits available: Kit A with all the parts for the Circuit Board and Kit B with the pots & sockets
for the In/Out Board. So for a fully working (euro-rack) module you'd need both. (+PCBs +front +knobs)
And I also ordered some (euro-rack) frontpanels, made from 2mm PCB material. (black with white silkscreen).
I will most likely add an extra option for knobs aswell, so you can order everything to built a fully working module.
Now before I order more PCBs there are two things I would like to know:
First of course; how much interest is there ?
And how much interest is there in the Circuit Boards compared to the In/Out Boards ? If it is about the same I will
order and sell them as a set like the first run, but if there is a large difference I could order and sell them seperately.
estimated prices:
PCBs: € 1,75 (each)
Kit A: € 3,65 (Circuit Board parts)
Kit B: € 8,15 (In/Out Board parts)
Front Panels: € 4,45 (2mm PCB material, black & white)
Knobs (2x): € 2,35 (Davies Clone with brass insert)
worldwide shipping: € 3,10 ... € 6,85 (depending on weight)
first run WaveWiper PCBs
 Filesize:  123.49 KB
 Viewed:  424 Time(s)
L´Andratté
PostPosted: Tue Feb 02, 2016 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Phobos!
I would like to build one!
1x Kit A
1x Kit B
PostPosted: Wed Feb 03, 2016 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I assume you would also like some PCBs with that ? Laughing
btw. I am not taking orders through the forum (at keast not at the moment)
but I will note it down so it can be sold on a first come first served basis.
bubzy
Audio files: 64
PostPosted: Sun Feb 07, 2016 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
pcbs?!
i'd take 4 at that price, i need some more to add to my backlog.
(dont need the front panel pcb just the brains)
_Richard_ Smile
mcop
PostPosted: Sun Feb 07, 2016 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi PHOBoS,
I'll take a pcb set and a panel when they're available if I may.
cyclic
PostPosted: Mon Feb 08, 2016 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, I'd take a pair of PCBs for sure.
lance
Paradigm X
PostPosted: Tue Feb 09, 2016 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi yes i would certainly like two of the main pcbs, no panel stuff etc tho.
Many thanks, and especially thanks for putting on the motm header (and for making the price so cheap!!)
Cheers, Ben
PostPosted: Wed Feb 10, 2016 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, so that is 3 sets and 6 single boards sofar. So I'll probably order 10x CB + IOB and 20x CB. The front panels are delayed
because something went wrong during production and the shop is closed for holidays now. So that is going to take another couple
of weeks.
cyclic
PostPosted: Fri Feb 12, 2016 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
I'm actually only after a main PCB, not the in out one as I don't use standard jacks.
I'd thought before that they were coming together and I was just going to store the unnecessary one.
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Feb 12, 2016 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for two sets of PCB.s and panels.
Ivan
PostPosted: Mon Feb 15, 2016 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I just ordered 10 sets + 20 single boards. It will probably take 2-3 weeks for them to arrive. Cool
Moosgummi
PostPosted: Wed Feb 17, 2016 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello PHOBoS,
I´d like one set of PCBs and a panel
PostPosted: Wed Feb 24, 2016 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Front panels and PCB's are ready and being shipped. So if everything goes right I should have them within 2 weeks. Very Happy
post 2500!
PostPosted: Wed Feb 24, 2016 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just in case I forgot... I'm after a front panel pcb only for my working WW Smile
PostPosted: Fri Feb 26, 2016 5:57 am    Post subject: WaveWiper front panels Reply with quote  Mark this post and the followings unread
I just received the front panels Razz So I'll probably get the PCBs next week.
WaveWiper Front Panel
 Filesize:  72.59 KB
 Viewed:  275 Time(s)
PostPosted: Fri Feb 26, 2016 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice! Shocked
PostPosted: Fri Mar 04, 2016 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
got the PCBs today! Razz
I'll send a pm with ordering info to everyone who showed interest shortly.
2nd run of WaveWiper PCBs
 Filesize:  170.38 KB
 Viewed:  285 Time(s)
raph36
PostPosted: Sat Mar 05, 2016 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
hi there! is there any pcb+panel left for order ?, i'd like one or two
thanks
PostPosted: Sat Mar 05, 2016 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure there are still plenty of PCBs and front panels (and part kits).
I´ve send you a pm.
PostPosted: Sat Mar 05, 2016 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is what the complete (euro-rack) module looks like.
Complete WaveWiper v2.1 module
 Filesize:  499.82 KB
 Viewed:  275 Time(s)
khakifridge
PostPosted: Mon Mar 07, 2016 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat. Cool
I'd be up for a PCBs+panel set please, if there are still spares.
Paradigm X
PostPosted: Mon Mar 07, 2016 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, the completed module looks excellent. sadly for me its designing my own and hardwiring.
thanks so much for these, theyre such a good price, its very generous of you. ive ordered two.
Paradigm X
PostPosted: Thu Mar 10, 2016 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
hi
bit OT possibly, so apologies, but im looking into a panel design fro this in 5u (motm), and its a bit of pain - i cant fit two in one panel, easily, but one is quite sparse (lots of wasted space).
Do you have any suggestions as to a small utility module or something which would complement this circuit nicely?
(EDIT) looking at the schems, i guess at least i could add additional cv inputs?
many thanks, Ben
PostPosted: Thu Mar 10, 2016 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
extra CV inputs are useful or a simple LFO as Dave did with his quad W4ve Wiper.
A wavefolder might be an interesting addition too.
Paradigm X
PostPosted: Thu Mar 10, 2016 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
hi - many thanks. i had missed those posts, i will read them in detail when i get a chance. an lfo might well be a great addition, theres a few super simple ones floating around here.
cheers, Ben
