Posted: Wed Jan 11, 2017 7:15 am Post subject:
professional manufactured PCBs are available from THONK (he even sells just the main PCBs w/o the euro adapter and stuff), and synthCube. _________________
Tech Buddy at Random*Source |
Posted: Wed Jan 11, 2017 7:16 am Post subject:
You can buy VCO-555 PCBs from Fonik, who Thomas has licensed this design to. Otherwise, it's perfboard.... |
Posted: Wed Jan 11, 2017 7:30 am Post subject:
i just placed a re-order, so all thomas henry diy projects via fonitronik will be available again, soon. _________________
Cfish
Posted: Wed Jan 11, 2017 7:34 am Post subject:
I think he has them listed for sale on THONK DIY. Only had the board and euro face plate kit last time I looked
THONK is a great company to work with, plus they have tempcos in stock at a great price. |
Cfish
Posted: Wed Jan 11, 2017 7:36 am Post subject:
Oops you posted as I did Fonik
I yeald the floor to the man who knows |
wackelpeter
Audio files: 10
Posted: Wed Jan 11, 2017 7:39 am Post subject:
I would like to add that i guess the small 250mA PSU had fuses for it's Output voltages, if that's correct and furthermore if These where fast fuses they can affect the voltage at some minimal current changes... which in turn would result in unstable pitch of the VCO...
I have experienced similar behaviour because i always put fuses on the Output of my PSU to protect it and my builds when i first power them up and start with small ones and once the cabinet is finished drop in a 2A slow 1,5 or 2A fuse...
One advice too before you connect your circuit to a PSU measure the resistance between gnd and both power rails, maybe turning the pot's that are connected to the power rails each direction once, so you can be highly sure that there is no short in your circuit and you have minimal chance to blow something up... _________________ https://soundcloud.com/bastian-j |
alanwilder81
Posted: Wed Jan 11, 2017 10:33 am Post subject:
There are no press-n-peel / foil layouts for this circuit that I'm aware of. |
alanwilder81
Posted: Wed Jan 11, 2017 10:54 am Post subject:
thanks elmegil
so,they are called press and peel or foil layouts? good to know. And you confirm there's none for the Thomas's 555 VCO, like i feared.Never mind. Perfboard will do the job.
Another question is, are the pulse-sawtooth-triangle-sine signal available at the same time?
cheers ! |
wackelpeter
Audio files: 10
alanwilder81
Posted: Wed Jan 11, 2017 12:15 pm Post subject:
wow.it's excellent to have all 4 waveforms available simultaneously and mixable to taste  |
dillydally
Posted: Sun Jan 15, 2017 5:32 pm Post subject:
I'm thinking to use the VCO-555 as a replacement for the PCO in my DIY Serge system. It seems like it would be easy enough to use maths and an extra op-amp to scale and offset the triangle and sawtooth. After doing that will any change need to be made to the sine shaper circuit? |
alanwilder81
Posted: Mon Jan 16, 2017 2:59 am Post subject:
be sure to have an increase of 1V per octave from the keyboard.
when tuning the VCO start with the lower octaves (1-6), using the actual scale trim of the VCO. the higher octaves will be a little bit flat. use the HF trim to iron that out.
use matched transistors for the VCO expo! _________________
alanwilder81
Posted: Mon Jan 16, 2017 3:05 am Post subject:
thanks
so i first set up the keyboard trimmers? then,once i get 1 V per octave output, i go on trimming the VCO . Hoping it works |
Posted: Mon Jan 16, 2017 3:12 am Post subject:
alanwilder81 wrote: | thanks
absolutely. the 1V/oct is the most common standard (Hz/oct another one), and the 555VCO is made according the 1V/oct.
once your keyboard is tuned to this standard you could use it for any other analog synthesizer following this standard (i.e. a microbrute).
or you could control your 555VCO with the microbrutes CV out... _________________
alanwilder81
Posted: Mon Jan 16, 2017 3:17 am Post subject:
cheeers |
alanwilder81
alanwilder81
Posted: Mon Jan 16, 2017 9:59 am Post subject:
another simple question is ,whats the difference between linear and exponential FM ? they sound fairly similar to my ears.  |
Posted: Mon Jan 16, 2017 10:31 am Post subject:
alanwilder81 wrote: | another simple question is ,whats the difference between linear and exponential FM ? they sound fairly similar to my ears.  |
when doing FM you will keep the base frequency of the VCO. with linear modulation the freq of the VCO will change. _________________
alanwilder81
Posted: Mon Jan 16, 2017 10:34 am Post subject:
thanks,
i need to experiment a little more to full exploit the 555 VCO potential  |
bonzai
Posted: Thu Apr 27, 2017 3:36 pm Post subject:
Hi there!
I couldn't find an answer in the search function, so I am throwing in the question here: I don't have the 2N390x types available, but some BC549 and 559 (C types) instead. Now I am worried whether they would work anyways? Wikipedia lists them as (more or less) equivalent parts. Any one tried it out yet?
First problem I've just found out: the pinout of the BC types is apparently reversed (CBE instead of EBC), but what if I just flip them around? I.e the BC559s would be aligned "belly-to-belly" like this: |)(|
Same goes for the TLC555 - I have some UTC555 types laying around in the junk bin and I'm not sure whether they are CMOS or TTL, the DS does not tell anything... (not such a big problem though, as the chips are socketed anyway)
Any hints?
Chris
PS: I'm using fonik's PCBs btw... |
Posted: Fri Apr 28, 2017 5:34 am Post subject:
The transistor subs should work, but be aware that the pinouts are opposite (I believe) on the BC* transistors compared to the 2N39* transistors. Double check the data sheets!
As for the 555, if it's not CMOS it won't work right. Not sure the best way to ensure that. |
JovianPyx
Audio files: 224
Posted: Fri Apr 28, 2017 7:39 am Post subject:
elmegil wrote: | The transistor subs should work, but be aware that the pinouts are opposite (I believe) on the BC* transistors compared to the 2N39* transistors. Double check the data sheets!
If you are referring to the nasty habit of the bipolar 555 timer to crowbar the power supply, you can try the PAiA Fatman method (which was sold with bipolar 555 chips). In the Fatman, the crowbar effect caused the VCOs to soft synch when they got close together in pitch. The original design powered the 555 timers through 100 ohm resistors with a 100uF cap across the ICs Vcc and Vee terminals. That works "ok", but PAiA's Scott Lee improved it by replacing the 100 ohm resistor with a standard LED (not high brightness). Note that the 555 doesn't draw enough current to light the LED, the LED is used because of it's diode characteristics. The CMOS 555 (7555) doesn't have this issue. _________________ FPGA, dsPIC and Fatman Synth Stuff
bonzai
Posted: Fri Apr 28, 2017 10:04 am Post subject:
Thanks guys!  |
