today> Twyndyllyngs Chez Mosc
Wacky, Zany, Weird (and possibly Odd) Sound Maker Project
Page 6 of 9 [206 Posts]
ladislaobiro
PostPosted: Fri Apr 07, 2006 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
here's my growing system... next step will be the Sound Lab (PCB already populated...)...
ladislao
 Filesize:  772.34 KB
 Viewed:  473 Time(s)
PostPosted: Fri Apr 07, 2006 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice.
Audio files: 235
PostPosted: Fri Apr 07, 2006 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Great looking box. Congrats... thumb up
Wild Zebra
PostPosted: Fri Apr 07, 2006 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Kudos, Thats looks SWEET Very Happy
Really nice.
"your stripes are killer bro"
ladislaobiro
PostPosted: Fri Apr 07, 2006 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks...
really thank you all... Smile
ladislao
dnny
PostPosted: Fri Apr 07, 2006 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice work !
soon you need a bigger amp Shocked
www.koelse.org
flickr: cable porn group
ladislaobiro
PostPosted: Sat Apr 08, 2006 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree... Smile
I like to use this small amp while taking pictures just because it is really small and battery powered, like the rest of my system...
BTW, when I play my little machines I usually plug them into a bigger and more powerful amp... much more enjoyable... Wink
ladislao
biancho
PostPosted: Sat May 06, 2006 9:45 am    Post subject: WSG done...but sound fades out! : ( Reply with quote  Mark this post and the followings unread
Hi every body!!...im 21 years old and live in bogotá....i have build the WSG from the musicfromouterspace page and used the Lorenzo's PC board, i did all the process from play around with virgin board, markers and construction of the WSG box....it really works.and sound great but i have a problem.....the WSG sound fades out after a certain time of use, so i have to turn off and on again the WSG every time that sound fades out...i dont know why it happens(note: the LED always is on, even the WSG sound fades out), i tested the voltage given by the battery and its ok...i do not understand,,why happens......i wish you could and want to help me... thanks for your time..Bye bye.
Audio files: 316
PostPosted: Sat May 06, 2006 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome biancho
http://electro-music.com/forum/topic-9856.html might be of interest to you.
biancho
PostPosted: Sat May 06, 2006 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey man! tnx...i found exactly wath i need
Audio files: 316
PostPosted: Sat May 06, 2006 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Colombia .. remember some pretty good weed was grown there Very Happy
(sorry was listening to some /very/ old Pink Floyd (summer of '68 ), must have brought me in a mood or something)
Anyway, hope you'll get it working now.
dnny
PostPosted: Sun May 07, 2006 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Colombia - my grandfather used to live in Bogota and teach at the university.
but anyway - welcome, and hope you get everything working
www.koelse.org
dnny
PostPosted: Mon May 08, 2006 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
WSG´s keep comming - i was doing my normal afternoon surf on net and i saw this lovely WSG from donebysimom.be
www.koelse.org
PostPosted: Tue May 09, 2006 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Nice Smile
Pehr
PostPosted: Tue May 09, 2006 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool Cool 4.1 Megapixel WSG Twisted Evil
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
EraSer
PostPosted: Sat May 20, 2006 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Very Happy
Do you know if it is possible to add a noise generator to wacky,zany,weird project?how could it be add?
welcome
dnny
PostPosted: Sun May 21, 2006 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
balance wrote:
Hi Very Happy
yes
connect noise output to -
point 1 of R1
or if you build the filter:
point 1 of R3
but you may want to ad a potentiometer - to adjust the amount of noise
dnny
www.koelse.org
EraSer
PostPosted: Sun May 21, 2006 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
point 1 of R1
point 1 of R3
dnny
first of all: thanks dnny Wink
Could I add to soundmaker a simple white noise generator like this?
why I should connect noise output to R3?Yes I've built the oDNESS cUT oFF fREQ, but I didn't use a second circuit (I read that I've to use R3 from second circuit if needed)..so I think I should connect noise output to point 1 of R7.is it ok? Rolling Eyes
bye
balance
[editor's note: made your link into an inline pic using the IMG tag. Hope that's OK. --mosc]
dnny
PostPosted: Sun May 21, 2006 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
that noise circuit of yours is kind of "second circuit" so i think you should try it first thru R3 (1M) and if the signal is too weak or too loud adjust the resistor value or maybe ad a potentiometer and "noise on/off"-switch or push button ...
www.koelse.org
EraSer
PostPosted: Sun May 21, 2006 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
please you correct me if I mistake:could I make this connections?
Should I repeat the soundmaker circuit using the 3 inverters that are left over if I use R3?
You pardon me if I am not expert of electronics Embarassed
I'm here to understand study
and build! Wink
[editor's note: made your link into an inline pic using the IMG tag.-dnny]
dnny
PostPosted: Sun May 21, 2006 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
that noise wiring is OK. try first whit 100K pot and if the signal is too weak try substituting R3 whit 500K resistor...and so on until you get what you want.
you don't need to repeat the circuit - but if you like you can - and then you need to ad R3b (another 1M resistor)
www.koelse.org
EraSer
PostPosted: Sun May 21, 2006 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow!
The noise wiring it's ok! I thought to have made one mistake.... Surprised
tnx dnny for your suggestions.....Today I'll try to ad noise gen.
as soon as possible I will post some audio sample of mymfirst WSG Wink
EraSer
PostPosted: Mon May 22, 2006 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yea !hear my WSG
hours & hours of zany,wacky,weird fun....i post a sample
WSGtest.mp3
Wsg-test-
 Filename:  WSGtest.mp3
 Filesize:  3.62 MB
 Downloaded:  1259 Time(s)
dnny
PostPosted: Mon May 22, 2006 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
nice to hear that you got everything working.
bravo
www.koelse.org
hanley
PostPosted: Fri Jun 02, 2006 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
hi
i came across the musicfromouterspace site a few weeks ago and decided to try make a wsg using Lorenzo's pcb layout that was on the MFOS site.ordered some stuff off the net and did most of the work yesterday but there was one of two things that i was a little confused about.
one thing was the switches
i got spst switches and the ones on the pcb diagram are a different type.i guessed about the wiring of one of them but am a bit confused about the other.i put up a rough picture here ( http://i3.tinypic.com/11h8lz5.gif )
i couldn't get a ceramic capacitor for C10 which was meant to be 1uf.
could i use an electrolytic 1uf or a lower value ceramic cap?
if i used an electrolytic cap which direction should the negative be pointing?
any suggestions would be great
cheers
