Posted: Sun Nov 11, 2007 11:38 pm Post subject:
@bbob
sorry bbob, i'd thought i knw something, in fact it once more turned out that i almost nothing.
@scott
great idea, i will implement this. more functionality without more controls... _________________
Tech Buddy at Random*Source |
Posted: Wed Nov 14, 2007 5:31 am Post subject:
if there is any interest i could do a run of professional manufactured PCBs. this is an easy to build project, no obsolete, expensive or hard to find parts.
the board would be about 10.-EUR/14.50USD, providing MTA connectors for all controls. minimum would be 40 advance orders.
so here are the schematics:
RF
Audio files: 28
Posted: Wed Nov 14, 2007 6:25 am Post subject:
Hi fonik -
Sure, I'd go for for a pair of those...
Thanks |
EdisonRex
Audio files: 172
Posted: Wed Nov 14, 2007 7:22 am Post subject:
I'd go for 2. They look pretty simple too. _________________ Garret: It's so retro.
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Posted: Wed Nov 14, 2007 7:45 am Post subject:
I'd go for 1
George |
amos_joseph
Posted: Wed Nov 14, 2007 7:55 am Post subject:
| I'd take two. |
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Posted: Wed Nov 14, 2007 8:26 am Post subject:
I have to say you've handled all your PCB projects in a such a positively exceptional way that it would be simply a pleasure to buy some boards from you once again.
So, two boards for me, please. |
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Wed Nov 14, 2007 10:32 am Post subject:
I'd be down for two.
-justin |
b-funk
Posted: Wed Nov 14, 2007 10:57 am Post subject:
für mich bitte auch 2...
damn, where does all the money go?  |
bubblechamber
Posted: Thu Nov 15, 2007 4:03 pm Post subject:
| i'll take 4 |
fluxmonkey
Posted: Thu Nov 15, 2007 4:15 pm Post subject:
| 2 for me, please. |
insider
Posted: Thu Nov 15, 2007 4:57 pm Post subject:
Me too, 2
thanks Fonik |
bugbrand
Posted: Fri Nov 16, 2007 3:33 am Post subject:
Such modules are really damn useful! Very good that you're offering PCBs, Mathias. However, I recently DIYed my own slightly different versions (-- two twin attenuvert mixers) so I'm afraid this'll be the first Fonitronik PCB I don't partake in!
I recommend at least two for everyone else! _________________ http://www.bugbrand.co.uk
Posted: Fri Nov 16, 2007 4:01 am Post subject:
thanks tom,
the response was rather faint until now, though. i expected this somehow: this is not a sexy module at the first glance, no imposing sound manipulation or something like this.
but it is a very very useful voltage processor nevertheless. each mixer, voltage processor, or multiple expands the possibilities of your synth, and this one is easy to build, straight forward... _________________
norman phay
Joined: Jun 29, 2007 Posts: 176 Location: North-East England
Posted: Fri Nov 16, 2007 5:13 am Post subject:
| Put me down for a couple of these, please. That looks damn handy. |
RF
Audio files: 28
Posted: Fri Nov 16, 2007 6:26 am Post subject:
| fonik wrote: | this is not a sexy module at the first glance, no imposing sound manipulation or something like this. |
I think sexy is way overrated (in a modular). It's the plain old utility modules - mults, mixers, VCA's - that you keep coming home to....
I know this one will get a lot of use in my system - and a PC board just makes it so easy....
Thanks for offering to do this one, fonik. |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Fri Nov 16, 2007 8:20 am Post subject:
| Need four! |
Fidgit
Posted: Fri Nov 16, 2007 11:20 am Post subject:
4 please
tnx |
Sound
Posted: Fri Nov 16, 2007 11:55 am Post subject:
2 to me ,
Thanks fonik! |
sonicwarrior
Joined: Dec 22, 2005 Posts: 266 Location: Cologne, Germany
Posted: Fri Nov 16, 2007 2:14 pm Post subject:
I don't really get it:
Is this for CV-only or will it work with Audio signals?  |
Posted: Fri Nov 16, 2007 4:59 pm Post subject:
| sonicwarrior wrote: | I don't really get it:
both, say audio OR control voltages.
when in AC mode the modules works as a simple audio mixer. the output is AC coupled: the signal goes thru a capacitor and DC components are removed. the LEDs are disabled (would be on all the time when indicating audio).
when in DC mode the capacitor is bypassed, the LEDs are enabled. now you can mix and process the control voltages, i.e. (as scott already mentioned) apply an ADSR signal to channel #1, attenuvert (inverse AND attenuate) it and add offset with unplugged channel #2 (Switched Scott Socket method ) . now you'll get an inverted ADSR going from 10 to 0 instead 0 to 10...
the single outputs (not AC coupled) of my prototype are build following the SSS method, too. as soon as you plug a cord in, this channel is no longer part of the mix.
hope that helps. _________________
sonicwarrior
Posted: Sat Nov 17, 2007 3:16 am Post subject:
| fonik wrote: | | hope that helps. |
Yes, then I'm staying with my 6 PCBs order.
My modular will get big and I'll definately need them.
Mixing signals rocks!  |
Sound
Posted: Sat Nov 17, 2007 6:33 am Post subject:
Hello, sorry the off topic but I'm wondering...
I've noticed that there are some modules that allow AC /DC in the same input, and there are others ,like this one, that have a switch and carry the AC through a capacitor.
why? What is the difference within them?
Thanks! |
Posted: Sat Nov 17, 2007 7:51 am Post subject:
i am not quite sure if i understood your question correct.
we handle audio signals as AC. we want to pass them to the next module AC coupled (or capacitance coupled), the DC offset is removed by using the cap. offset in audio could cause popps and plops.
we handle control voltages as DC. here we don't want to get rid of the offset, we want to use it, therefor the cap is bypassed.
http://zone.ni.com/devzone/cda/ph/p/id/9 _________________
Sound
Posted: Sat Nov 17, 2007 11:26 am Post subject:
Thanks, Good link. It has helped me very much.
But , eg. the PlanB's model9 allows both AC and DC, without any switch.
Could it block in another way the possible DC portion of an audio input? |
