Posted: Sun Dec 03, 2006 7:46 am Post subject:
What's the worst that could happen? Blood sprayed all over the room. Deregistration? I don't know. I'm only a doctor. A drum doctor it's true, but still only a doctor. If I knew everything then it would be impossible for anyone to sue me for malpractice! Insurance premiums would plummet! I wouldn't be able to justify the outrageous fees that I charge!
Actually, speaking of fees, is your account current? I'll put your invoice in the mail tomorrow!
PS Short answer: - Not sure.  _________________ What makes a space ours, is what we put there, and what we do there. |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Pehr
Posted: Wed Dec 20, 2006 6:25 am Post subject:
Hi!
Here's a PCB layout for the DS8 if anyone needs it. It's for the CA3080 though. |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Pehr
Posted: Wed Jan 03, 2007 4:07 am Post subject:
| Pehr wrote: | Is it really neccesary with log pots on the DS7?  |
I just found out how you can make log pots from linear ones.
Just connect the wiper to one of the sides of the pot via a resistor like in this page http://sound.westhost.com/project01.htm .
So my 100k linear pots with a 100k resistor connected this ways becomes a 50k log pot which is perfect for the DS7!
Why have I never thought of this
It's just:
Rtot = Rres*Rpot/(Rres + Rpot),
which is a log curve when Rpot varies...  |
Pehr
Posted: Thu Jan 11, 2007 5:40 am Post subject:
| dnny wrote: | | do you have the parts layout too? |
Posted by discointellect:
(This image has been reduced to fit the page. Click on it to enlarge.)
dnny
Posted: Thu Jan 11, 2007 8:33 am Post subject:
thanks pehr.
i didn't know i was so blind that i haven't seen that discointellect had all ready posted that - sorry  _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
Pehr
Posted: Thu Jan 11, 2007 11:03 pm Post subject:
| nisios wrote: | | is there any possibility of putting attack on these things with a simple mod? |
Maybe like this?
or this?: |
Pehr
Posted: Thu Jan 11, 2007 11:12 pm Post subject:
| dnny wrote: | thanks pehr.
i didn't know i was so blind that i haven't seen that discointellect had all ready posted that - sorry  |
no problemo ^_^ |
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Sat Jan 13, 2007 11:40 pm Post subject:
Alright, i've gone and done it now. Finally got two out of four finished, with parts on the way for the other half! Also managed to kludge the board a bit for PCB mounted pots. I have a pdf of the layout if anyone's interested. Here's a pic of the twins: |
Pehr
Posted: Sun Jan 14, 2007 1:11 am Post subject:
| goodrevdoc wrote: | | I have a pdf of the layout if anyone's interested. |
I'm always interested
Nice work!  |
goodrevdoc
Posted: Mon Jan 15, 2007 1:05 am Post subject:
Here ya go Pehr!!!
-justin |
Pehr
Posted: Mon Jan 15, 2007 4:11 am Post subject:
Thanks!  |
Pehr
goodrevdoc
Posted: Sat Feb 03, 2007 9:06 pm Post subject:
Generally that means not connected, so as just a guess, i would leave it out. the worst that can happen is that it wont work.
-justin |
Pehr
Pehr
goodrevdoc
Posted: Sun Feb 04, 2007 2:07 pm Post subject:
Yeah, probably just a bit longer, but would it also raise the minimum decay time? Nah, it looks like that's set by R3. Also the other cap is for the sweep control, so changing it wouldn't affect the decay.
-justin |
Pehr
scorpiistar
Posted: Wed Feb 28, 2007 11:26 pm Post subject:
ds7 Subject description: breadboard |
| hi....im new....i just completed the DS7 on a breadboard, and am ready for testing! seems you can pull C2 3u3/sweep and it makes no audible difference ........i think tomorrow ill try the attack decay mod.....any requests?! |
Sonarbase
Joined: Mar 10, 2007 Posts: 5 Location: Beyond Hoag's Object
Posted: Wed Mar 21, 2007 6:38 am Post subject:
Re: ds7 Subject description: breadboard |
| scorpiistar wrote: | | hi....im new....i just completed the DS7 on a breadboard, and am ready for testing! seems you can pull C2 3u3/sweep and it makes no audible difference ........i think tomorrow ill try the attack decay mod.....any requests?! |
And? Did it the attack mod work out?
S. _________________ Sonar base
Sonar base on myspace |
6079smith
Joined: Jan 18, 2007 Posts: 95 Location: Mark of the Dane
Posted: Tue Mar 27, 2007 6:44 pm Post subject:
Hi, just a few comments and whatever...
a decoupling cap (or two) is a good idea. I had a horrible highpitched squeal going on that a 100nF cap across the power rails got rid of.
I don't know what power supply others are using but I'm using 15 volts... and that regulator gets hot. Painful hot. Heatsink is also a good idea. I made one out of a tin can; works fine.
anyone sort out the volume problem? Is it because a 5volt module just can't put out the same levels as ones using +/-15? I have the same problem with the wasp filter. Anyone point me towards a transistor amplifier?
I'll give some of the different mods a go tomorrow, see if there's anything else to add... and thanks to all involved for this module.
Andrew. |
richardc64
Audio files: 26
Posted: Wed Mar 28, 2007 7:46 am Post subject:
| 6079smith wrote: | anyone sort out the volume problem? Is it because a 5volt module just can't put out the same levels as ones using +/-15? I have the same problem with the wasp filter. Anyone point me towards a transistor amplifier?
You could try reducing the resistor between the CA3080 output and the pot (don't go lower than ~ 2K,) or increase the 100K feedback resistor from the '3080 ouput to the - input.
I don't know about the wasp. |
6079smith
Posted: Wed Mar 28, 2007 10:56 am Post subject:
| Thanks for the response... I've actually tried both of these. Even raised the feedback resistor to 10M(!) with no real difference. Oh well, back to the drawing board... |
Sonarbase
Posted: Wed Mar 28, 2007 11:18 am Post subject:
| 6079smith wrote: |
Andrew. |
Have you tried lowering the voltage to 12 or 9v?
