elanhickler
Joined: Jun 24, 2008 Posts: 152 Location: Gilbert, Arizona
G2 patch files: 6
elanhickler
G2 patch files: 6
Posted: Sun Mar 11, 2012 2:17 pm Post subject:
wiring diagram for SRBM140800 switch
fluxmonkey
Posted: Mon Mar 12, 2012 10:35 am Post subject:
i used this one from mouser: 690-C5P0206N-A, works great. outstanding module!
initially i used an undocumented switch from the spare parts bin--but the first few times i dialed it, there was a catastrophic short that blew fuses and shut down modules. I assume it was a shorting rather than break-before-make switch, but I didn't check, just pulled the thing out and threw it away before it did any serious damage! _________________ www.fluxmonkey.com |
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Mon Mar 12, 2012 5:02 pm Post subject:
LOL ground and the negative rail always make trouble when they meet LOL
I finally got mine going as well. Dont remember how... I think Q3 ws burned. My oven hot OTAs survived thank god, and this thing just RIPS.
LOVE |
pdub
Posted: Wed Mar 28, 2012 5:15 pm Post subject:
Hi Group
I just finished the Threeler today. Man it's very cool! It will take me some time to fully get the scope of it. It is very wicked though!
Right now it's starts self oscillating around 11 o'clock on the Res pot. Compared to other filters I have this seems rather early in the rotation. Does this sound correct for this filter? I know it works a little differently and even requires some resonance to pass audio from Output 3.
I used the Bridechamber parts kit and I am running the module at 15V with the suggested resistor changes.
Any help would be greatly appreciated!
Thanks, Charles |
frijitz
Audio files: 54
Posted: Wed Mar 28, 2012 6:35 pm Post subject:
| pdub wrote: | | Right now it's starts self oscillating around 11 o'clock on the Res pot. Compared to other filters I have this seems rather early in the rotation. Does this sound correct for this filter? |
Hi Charles --
Yep, that's exactly right. The reason is that there is lots of nonlinear and chaotic action above resonance. Play with the higher resonance settings with the input level fairly low and you should see what I mean.
Ian |
pdub
Posted: Thu Mar 29, 2012 8:57 pm Post subject:
Thanks for your response Ian.Yes I see what you mean, I got to spend a lot of time with the filter in the studio today. It is really a fantastic filter! Great job on the concept and design.
It will be one of my favorites for sure.
Thanks, Charles |
egodzillal
Posted: Fri Apr 20, 2012 5:27 am Post subject:
docs ? |
just received my threeler pcb + parts but can't find build docs anywhere :p
any hint ?
cheers |
thermionicjunky
Joined: Dec 07, 2006 Posts: 90 Location: san francisco
Posted: Fri Apr 20, 2012 7:27 am Post subject:
Re: docs ? |
| egodzillal wrote: | Hi,
any hint ?
cheers |
They should be emailed with purchase, but sometimes Scott needs a reminder. |
davebr
Joined: Jun 09, 2007 Posts: 198 Location: portland, or
egodzillal
Posted: Tue Jun 05, 2012 9:40 am Post subject:
Hi
i'm almost done with my threeler.
the things is about that R36a again.. sorry i red all i could about it but my english seems bad enough i don't understand it.
Bridechambers says :
| Quote: | | Q1/ Q2 are the matched pair, in this case the 2SA798. It can go in either direction, in the five pins. After that, put the tempco in R36a, leaving the legs long enough so that the resistor goes over the matched pair, so that you can pull it tight w/ some thermal compound between them, making a good physical connection. |
so you put a798 first then R36a and stick the R36a thing to the top head of the a798 ... if that's what i understand what is it for ? thermal something ?
or does it have to do with a special way to sold the legs behind the PCB ?
i'm sorry you answered this question like 10 times already but it's really because i'm afraid to miss some english words
other question about the construction part.
i see on davebr's picture that he has a metal plate to hold the PCB.
i don't have this plate is it missing from my kit or did davebr built it himself ?
http://modularsynthesis.com/bridechamber/threeler/djb-theeler_rear.jpg |
davebr
Posted: Tue Jun 05, 2012 10:00 am Post subject:
Threeler tempco |
i'm sorry you answered this question like 10 times already but it's really because i'm afraid to miss some english words |
I put in the 2SA798 unsoldered and then formed the leads of the tempco so it would fit tight against the 2SA798. This required bending the leads both inward and around in order to fit properly against the side of the 2SA798. Then I soldered in the 2SA798 at the proper height. Then I removed the tempco, applied heat sink grease on the side of both the tempco and 2SA798 and installed and soldered it in.
Here's how mine looks.
Dave |
frijitz
Audio files: 54
Posted: Tue Jun 05, 2012 11:12 am Post subject:
| egodzillal wrote: | other question about the construction part.
i don't have this plate is it missing from my kit or did davebr built it himself |
If you are using the Bridechamber kit you do not need a bracket. The board is supported by the pots.
Ian |
davebr
Posted: Tue Jun 05, 2012 11:20 am Post subject:
Threeler Subject description: bracket |
I choose to use a bracket on any module I build so I fabricate one for all DIY modules. I have 0.050" sheet aluminum that I use. It's thin enough to mount behind potentiometers and jacks and easy to form.
Dave |
egodzillal
Posted: Tue Jun 05, 2012 12:21 pm Post subject:
| Quote: | | The board is supported by the pots. |
NICE ! thx both for explanations. hope i can find some "heat sink grease" at the store :p
oh btw special hello to Argitoth who gave me the will to do that wonderful threeler with his soundcloud demos ! |
davebr
Posted: Tue Jun 05, 2012 12:42 pm Post subject:
| egodzillal wrote: | NICE ! thx both for explanations. hope i can find some "heat sink grease" at the store :p
RadioShack does sell heat sink grease.
http://www.radioshack.com/product/index.jsp?productId=2102858
Dave |
egodzillal
Posted: Wed Jun 06, 2012 6:21 am Post subject:
  and it's a success
wouhou ! sounds great. really happy to have that in my synth and all the nice options on it.
now .. what should i do with my ms10  |
egodzillal
Posted: Wed Jun 06, 2012 9:08 am Post subject:
... euh was happy to fast
i have something i don't understand.
it seems to work all fine for filter and reso on these positions :
2LP/HP
LP/2HP
3HP
but on the 3LP the resonance goes weird :
output 1&2 = no significant reso like it does on the other MODE sounds almost like if it was 0% reso
output 3 = same but reso acts like a volume. when set to0% it cuts the sound. :X |
frijitz
Audio files: 54
Posted: Wed Jun 06, 2012 9:36 am Post subject:
| egodzillal wrote: | but on the 3LP the resonance goes weird :
output 1&2 = no significant reso like it does on the other MODE sounds almost like if it was 0% reso |
The first and second stages are a bit weaker, but you should still see a definite resonance. Make sure you don't have the input up too high.
| Quote: | | output 3 = same but reso acts like a volume. when set to0% it cuts the sound. |
Correct, it has to be part way up.
Don't know why you are not seeing resonances. Are you sure the resonance control is up far enough?
Ian |
egodzillal
Posted: Wed Jun 06, 2012 10:41 am Post subject:
| Quote: | | Make sure you don't have the input up too high. |
yeah that was it ! it's working normal when input level is lower
it sounds terrific. my favorite filter by far thx for make it ! |
davebr
Posted: Wed Jun 06, 2012 2:42 pm Post subject:
| frijitz wrote: | | Quote: | | output 3 = same but reso acts like a volume. when set to 0% it cuts the sound. |
Ian |
I biased my resonance control slightly on so I always have an Out3 signal. It didn't take much and seems to work quite well without having any significant effect on the resonance.
Dave |
ShyK
frijitz
Audio files: 54
Posted: Tue Jun 12, 2012 5:57 pm Post subject:
| ShyK wrote: | | Ian, I just logged in to say that your filter is the best I've ever used. A big statement and yet completely true. |
Thanks! Glad you like it.
| Quote: | | I've been a fan of 3-pole filters for a very long time. My opinion is that a good 3-pole design provides a more balanced and musically useful result than either 2-pole or 4-pole in most cases. |
Yeah, I wonder if the reason is the same as why a lot of folks like 3P for speaker xovers?
| Quote: | | I've attached a simple little example to show people how awesome it is. |
Thanks for putting that up -- sounds great!
Ian |
brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Tue Jul 03, 2012 7:52 am Post subject:
Hi Ian,
finished my Threeler yesterday using a Bridechamber part-kit. Flawless build, everything worked as expected from the first switch-on.
Added one mod stated by Dave Brown, just one more resistor (1M5) on the tl072 to keep the reso up a little bit, so all outputs work perfect in every mode without turning up the reso-pot.
This vcf is absolutely amazing, breathtaking and outstandig! Highly recommended to everyone using modular synths!! I´ve never heard a filter screaming like this (in an absolutely positive way), and yes, turn up the resonance and you´ll know why there is a fine-tune pot in addition to the cutoff-pot...
In other words : G R E A T !!!
Greg _________________ Best regards
Greg |
ShyK
Posted: Fri Jul 06, 2012 6:03 pm Post subject:
| frijitz wrote: | | Quote: | | I've been a fan of 3-pole filters for a very long time. My opinion is that a good 3-pole design provides a more balanced and musically useful result than either 2-pole or 4-pole in most cases. |
Yeah, I wonder if the reason is the same as why a lot of folks like 3P for speaker xovers? |
I think that somehow it generally resembles resonance properties of things in nature more than 4-pole which may be too steep in comparison. Instuments, voices, structures. For example, I'm sure you know how the character of your filter in the second output is surprisingly voice-like, no multiple filters and no special tweaks, just a single 3-pole filter with some resonance. I think the "vocal" quality of it is not really vocal quality, but simply natural quality, but we just naturally tend to associate it with voice.
On another note, there is a lack of demos so I've attached a trippy acid/trance sample for anyone who wants to hear what a super tough 3-pole filter can do in a production-ready setting.
| Description: |
| Q106 VCO -> Threeler VCF -> KSP8 -> HVTP2 -> PL-2 |
 Download (listen) |
| Filename: |
shy-threeler-acid.flac |
| Filesize: |
5.78 MB |
| Downloaded: |
2371 Time(s) |
