Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Wed Aug 08, 2012 12:47 pm Post subject:
I've split off a bunch of posts from here to the new G2 extended patches section : http://electro-music.com/forum/topic-54650.html _________________ Jan
veta
Posted: Wed Aug 08, 2012 9:01 pm Post subject:
does anyone have any idea if this open source editor will run on a mac using the application 'WinOnX' ?
more info here: http://itunes.apple.com/us/app/winonx/id421346233?ls=1&mt=12
i really want to use this editor but don't want to do a full windows purchase / install. |
drapdap
Posted: Thu Sep 06, 2012 3:53 am Post subject:
Hey Bruno!
any news? we love news!
did you consider making a different extension name for the patchfiles with hidden modules? |
brunov
Posted: Thu Sep 06, 2012 7:21 am Post subject:
Hey Drapdap!
Yes, well I'm working on an update, but nothing as spectacular as new modules or something like that. Mostly user-interface stuff.
I'm working on these things:
Like Jan suggested, the editor will put x behind the file extension when it detects that one of the extended modules is used, so you get pch2x and prf2x.
And I thought it would be nice if you could use the g2ools from within the editor, so I made a little shell around it, so you can start it from the menu. Maybe in future this could be integrated a bit more.
And then recently I bought a couple of midi-controllers, a Novation launchpad and a BCR200. The BCR2000 I bought because I read here on the forum that it may be a good one to use in combination with the g2 engine. The nice thing about it is these rotaty controls with leds that look a lot like the G2 keys controls. The downside is that the cc mapping is not fixed like the controls on a g2 keys. The controls of the g2 keys are more or less fixed to the parameter pages.
So what I would like to do is to make ik possible in the editor to map cc's from a midi-controller to the knobs on the parameter pages of the editor, so it behaves something like the controls on a g2 keys. I'll put a picture up tonight so see what I mean.
Of course another downside is that it doesn't have displays to show which parameter you're editting.
With the launchpad I had this idea, maybe somtehing for a distant future: wouldn't it be nice to use a controller like the launchpad in combination with a path mutator? I thought of this because the patch mutator in the clavia editor also has some sort of a grid that stores the different mutations. Of course we'll have to figure out how to make a patch mutator first... _________________ My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
My new G2 editor FMX: http://www.bverhue.nl/g2dev/?page_id=17
Source code: https://github.com/BVerhue/nord_g2_editor |
brunov
Posted: Thu Sep 06, 2012 1:43 pm Post subject:
Here is a picture of what I'm working on, it's something for engine owners I guess.
On the application settings I made a Tab "Ctrl Midi", there you can specify your midi-controllers. It works like in ableton, after you specified the midi devices, you can turn a knob on the device and with a right click of the mouse you can connect it to a control on the parameter pages form, so that way you can create a midi mapping and the mapping will be saved in the ini-file.
The arrows show how I made my mapping of the bcr2000 at the moment: the top row knobs correspond with the 8 knobs on the parameter pages, then the row of buttons below correspond with the 8 buttons of the parameter pages.
The first 5 buttons on the second row select the parameter page, and the last 3 select the column.
And with the push function of the top row knobs you select a variation.
And finally the four buttons right below on the bcr2000 select the function: parameters, global parameters, morphs or patch parameters.
Don't know yet what to do with the 24 knobs below.
The nice thing about the bcr2000 is the feedback function, so if you specify the bcr2000 in the Ctrl midi output list, the editor will send midi back to the bcr2000, so if you switch for example to another variation, the leds around the knobs and on the buttons will show the new values.
Pity there are no displays to show the parameters your editting.
So not quite like a g2 keys, but maybe getting close...
Description: |
Filesize: |
270.83 KB |
Viewed: |
466 Time(s) |
Posted: Thu Sep 06, 2012 10:59 pm Post subject:
BCR mapping onto the parameter page!! Straight from the top of my wish list! You, sir, are a hero and a genius!
_________________ Antimon's Window
Estarriol
Posted: Fri Sep 07, 2012 9:42 am Post subject:
The main problem I've experienced while having G2engine and BCR2000 is a lack of feedback -- G2 does not send any data to BCR encoders, so the leds dont jump as good as G2keyb does. |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Fri Sep 07, 2012 11:23 am Post subject:
Bruno, you are fantastic! Thank you!
I use BCR's for my Engines. |
brunov
jksuperstar
G2 patch files: 18
Posted: Sun Sep 09, 2012 3:12 pm Post subject:
Hi Bruno,
How much effort is required to get this editor running on Linux at this point? (I also have to think about the Clavia driver, but I had that running via WINE at some point a long time ago, it was the editor which graphically wasn't very happy).
My thought is to use a Raspberry Pi linux board embedded in my Nord G2, and that way the keyboard is fully self-sufficient, no external computer *required*. The Raspberry Pi computers are very small, and sell for about $35 US, which includes a USB port and HDMI output. It also has a network port, so instead of a monitor, VNC or other remote controlling system could be used to control the editor over the network.
http://www.raspberrypi.org/
Later on, things like CopperLan could be added, which is a network based replacement for MIDI. It's quite powerful, and looking to be a wonderful system that takes the strengths of Open Sound Control and MIDI, and puts it in a IP-free self aware network environment.
https://www.facebook.com/CopperLan
The Raspberry Pi is based on a 700MHz system with 256MB of memory. I don't know if these are limits at this point, I imagine not. the boards have a GPU on them as well, and that is being developed currently, so graphics should be largely off loaded from the main processor.
Just an idea! |
brunov
Posted: Mon Sep 10, 2012 12:34 pm Post subject:
That's an interesting plan! At the moment though the editor only works under windows.
I had a try to get it working under Linux some time ago, and basically it worked, only I had some trouble with what I think are bugs of the Delphi compiler under Linux (FPC), but that could also be my inexperience with Linux/FPC.
So I decided it would be better to first finish the windows version, with most of the functionality of the original editor and then maybe later, to try to make a linux/osx version.
I'm not experienced at all with Linux/osx programming, so for me it's a steep learning curve. But I would like to explain a bit what i've code so far, maybe to get some ideas going
What I've learned so far is that in cross-platform programming the difficult parts are in the peripherals. So for the editor these are the usb connection, the midi connection and the graphical ui.
I've spend a lot of time structuring the code so that the peripheral dependencies are in the top layers of the code, now I have these layers:
g2_file : base classes (module, cable, parameter, patch, slot, performance and so on)
g2_mess : adds messages definitions (create module, create cable and so on)
g2_usb : adds usb functionality
g2_midi : adds midi functionality
g2_graph : adds graphical ui functionality
g2_file and g2_mess should compile with FPC under linux/windows/mac with some minor modifications.
Then g2_usb, I know for a fact that it works under linux/windows, Osx should be possible also according to the Lib-usb specs.
g2_midi. Don't know yet. But the midi functionality is not really essential for the function of the editor.
g2_graph : That's the difficult one! If you look at the editor, it doesn't look like a very graphical intensive application, but because the modules/knobs are so small, to make it all a bit visually appealing, the graphics have to be anti-aliased, wich means, "make it look less build out of blocks". So more complex code is needed to scale the colors, which means more cpu. That in combination with the blinking leds: when a led is partially obscured by a cable, that part of the cable has to be redrawn every time the leds blinks.
I've worked out the graphics for windows, but for linux a ran into trouble. I have to see how things work out with osx.
So that's basically the situation now. Maybe this winter I get some spare time to work on this.
An alternative option to building a complete application myself is to compile the first 3 layers into a library. And someone with more linux/osx experience can build an UI in another language and use the library to communicate with the the g2. _________________ My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
jksuperstar
G2 patch files: 18
Posted: Tue Sep 11, 2012 9:19 am Post subject:
Hmmm, maybe an alternative to knobs would be more useful? Especially if a touch interface ever became available in the future.
Some things that come to mind to replace a knob might be data bars
Or sliders. I'll give it more thought.
Thanks for considering the idea! |
brunov
grimley
G2 patch files: 9
Posted: Mon Sep 17, 2012 3:12 pm Post subject:
Very impressed with the progress you have made. I'm considering buying a cheap PC just to use your software (all Mac here at the moment). Fantastic work. _________________ Sleep Distillery
Apeirophobe |
Roland Kuit
G2 patch files: 127
Posted: Mon Sep 17, 2012 3:30 pm Post subject:
Great Brunov! That tablet idea sound appealing. |
jksuperstar
G2 patch files: 18
brunov
Posted: Wed Sep 19, 2012 11:40 am Post subject:
Didnt even know these things existed
I think the editor will run on it if it's windows of course, you need an usb an a lan port and some kind of storage system, maybe you kan even boot in from an usb stick. I'm not really an expert on hardware so I'm really not the person to give advice on it.
The performance of the editor can be tuned if it turns out that it runs to slow, for example resrticting the number of screen updates from led's blinking by a parameter. So I don't think that would be a show stopper, just let me know if you run into a problem! _________________ My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
grimley
G2 patch files: 9
Posted: Wed Sep 19, 2012 5:09 pm Post subject:
Nice! I wonder if anyone has successfully embedded something like that in their G2 yet? That is a very tempting idea! If you did, do you think it would be possible to somehow have only one power cable for the G2 and this?
I'm drooling at the possibilities here ... _________________ Sleep Distillery
Apeirophobe |
ZeeByeZon
Posted: Thu Sep 20, 2012 12:50 am Post subject:
You will still need a screen, a keyboard and a mouse...
The screen needs a power cord too |
brunov
jksuperstar
G2 patch files: 18
Posted: Thu Sep 20, 2012 7:51 am Post subject:
grimley wrote: |
I'm drooling at the possibilities here ... |
I haven't looked into the sizes of power supplies. If it all fit, I would guess one could tap into the mains connector and run power from there. But certainly not off the Nord's own power supply (+/-15v, +5v or so).
Possibly the least damaging/intrusive would be a very small case that would fit on the upper right of the keyboard. No fans, no moving parts for storage, accessible USB for thumb drives, and hopefully a touch screen, (although a tablet via VNC would work immediately).
It's easier for the rack versions...if you have an extra space in your rack |
brunov
fairplay
Joined: Apr 13, 2009 Posts: 11 Location: Germany, near Munich
Posted: Sun Oct 14, 2012 4:24 am Post subject:
brunov wrote: | - wrote a help file. |
xav
G2 patch files: 7
Posted: Tue Oct 16, 2012 10:15 am Post subject:
Hello everybody,
Does anybody tried and succeeded in installing this editor in Parallels or Wine?
Thank you Brunov, nice work. |
grimley
G2 patch files: 9
Posted: Tue Oct 16, 2012 1:45 pm Post subject:
Excellent work on the help document. Lots of great features in there I wasn't aware of. _________________ Sleep Distillery
Apeirophobe |
