Recent Changes - Search:
go to the forum
Contents
Site
Help
« mar 2026 · jul 2026 »
    add a calendar item
    Schematics / MFOS Wave Freaker Module
    < The "5Pulser" Waveform Generator | Schematics | Timbre Modulator Based on Electronotes #72 >
    < Wave Morph circuit | Listbytype | Timbre Modulator Based on Electronotes #72 >
    DIY | Wave Shaping | MFOS | Ray Wilson | Harmonics
    MFOS Wave Freaker Module by Ray Wilson ,visit the MFOS Synth diy headquarters for details on construction of this module ,demo ,and PCB's . http://www.musicfromouterspace.com
    From the description by Ray Wilson :
    If you're looking for some new waveforms for your synth you've definitely come to the right place. I have been asked several times to come up with a circuit that takes a basic waveform like a triangle or a sine wave and takes it in a new harmonic rich direction. This circuit takes a triangle or sine wave (or other non-square wave) and allows you to turn it progressively inside out yielding a totally cool sound (peak inversion). Additionally the triangle, sine (or ramp/saw) is converted to what I refer to as a step waveform which has a cool hollow harmonic-rich type of sound. The modified triangle or sine wave output is further enhanced by the addition of a mixer for pulse wave, sub octave square wave and sub-sub octave square wave for very interesting harmonic rich sounds. You'll love the dry sounds you get but when put through a resonant filter your ears will get a real treat. Finally some new waveshapes beyond sine, tri, ramp, saw and square.
    Features
    Turns a Triangle or Sine Wave Into a Harmonic-Rich Waveform. Provides several waveforms: Inverted Peaks Wave (CV modulation capable) Stepped Wave (CV modulation capable) PWM Rectangle (CV modulation capable) Square Sub-octave of fundamental Square Sub-Sub-octave of fundamental Voltage Controlled Wave Shape Modulation Voltage Controlled Step Wave Modulation
    visit the MFOS subforum : http://electro-music.com/forum/index.php?f=99
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 15:01 [UTC-7] - 5323 views
