 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
GuitarSynth
Page 1 of 1 [18 Posts]
Edo
PostPosted: Wed Mar 09, 2005 8:27 am    Post subject: GuitarSynth Reply with quote  Mark this post and the followings unread
Guitarsynth.
Put a clean real guitar signal (preamped) into input 1.
you'll probably have to adjust some levels (threshold/filterfreq/compressor outputlevel)
you can only play monophonic (if you want good pitchtracking)
mostly full-amplitude distorted sounds.
Edo Paulus
http://www.eude.nl
guitarsynth.pch2
guitarsynth with pitchtracking and envelopefollowing of audio input.
 Filename:  guitarsynth.pch2
 Filesize:  2.71 KB
 Downloaded:  2808 Time(s)
PostPosted: Wed Mar 09, 2005 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Edo good to see you here !
Can't try the patch now, but I'm sure it's good :-)
Jan.
Audio files: 235
PostPosted: Wed Mar 09, 2005 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Edo, great to have you here.
There is a lot of interest amoung guitar players about using the G2 as a guitar processor. Would you be able to record an mp3 file or two that demonstrates your patch?
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Wed Mar 09, 2005 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
The G2 (engine or keyboard) pretty much renders the guitar effects processing board obsolete. The FX groups makes the majority of mainstream guitar pedals redundant (, except for niche ones like some overdrives or the agonizer pedals, etc.) You can build, mix, match, have analog control via the knobs AND save it all when you're done. Plus the G2 engine is smaller than some of the equivalent gadgets. I remember messing with the 80's yamaha processors and the digitech RP series effects boards in the 90's...they can't compare in flexibility and real time control.
paul e.
PostPosted: Wed Mar 09, 2005 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
intriguing...does the G2 have an effective distortion/amp simulator module?
Spiral Recordings
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Wed Mar 09, 2005 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heres a demo of variaiton 5 i think. This patch produces some very warm, thick bass. I could not get the "lead" variations to work, but this may be due to my lack of a direct box or pre-amp.
This riff was played on the low E and A strings, I found the best response came from the lowest strings.
guitarsynth_g2patch_demo.mp3
MP3 example of guitarsynth.pch2
 Filename:  guitarsynth_g2patch_demo.mp3
 Filesize:  194.71 KB
 Downloaded:  2185 Time(s)
paul e.
PostPosted: Wed Mar 09, 2005 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool !.... you turned your guitar into a bass...realistic sounding...mhh interesting possibilties....through a squelchy bass patch [303ish] and you can have the kids dancing heheh
Spiral Recordings
zynthetix
Audio files: 10
G2 patch files: 13
perhaps something could be built, but not an out-of-the-box module. some unique overdrives can be made, but you're not going to replicate a mesa-boogie head, marshall stack, or fender twin reverb. IMHO, a G2 is definetly worth trading an effects board for, but not necessarily an amp. (actually...i did sell my amp to help get my G2 keyboard Shocked )
Edo
PostPosted: Sat Mar 12, 2005 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a track i made using this patch. I ran my guitar three times through the patch (dubbing). two times using variation 1, one time using variantion 2. Recoding done in Live. Drums (a though edit) using linndrum samples. all is fattened quite some using compression (no G2).
Edo Paulus.
eude 2005-03-08.mp3
 Filename:  eude 2005-03-08.mp3
 Filesize:  8.28 MB
 Downloaded:  1702 Time(s)
PostPosted: Sat Mar 12, 2005 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
It starts a bit slowish but nice things happen along the road.
Cool patch indeed, it might help sell G2's :-)
Jan.
Edo
PostPosted: Sat Mar 12, 2005 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wel it's not realy a finnished track. realy not actualy. It's about the sound right. Yes, people who want a cool guitarsound might be interrested in this. I think NI's Guitar Rig is currently the best guitarprocessing ware around, though. I don't know if it has a synth with pitchfollwoing though....
though i ought to go to bed (3:34 AM)
by, Edo.
Mohoyoho
PostPosted: Sat Mar 12, 2005 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the guitar processing demos!
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Mar 12, 2005 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool demo! Makes me wanna buy a cheapo electric and plug it into my G2 Cool
G2egory
PostPosted: Mon Mar 14, 2005 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Cool! Being a guitarist for many years, I can't wait to try it out.
You guys are right. It might help sell G2s. The great sound sample had some sounds you could never get out of the latest Moog pedal, which I almost bought, but realized I had to let go of the guitar to get to the soundscape I wanted and bought a G2X. Thanks for sharing!
Greg
PostPosted: Wed Aug 24, 2005 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Makes me think of the group Ratatat... has anyone else listened to them? I am guessing that they use this kind of guitar and bass processing a lot. I've listened to their album a lot since I bought it about a year ago - great stuff.
mtvic
PostPosted: Mon Mar 24, 2008 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Does reminisce Ratatat.
Seen them live with Junior Boys and Mouse On Mars
2002 I believe.
Great Patch . Very Happy
blackdiamond13
PostPosted: Thu Jun 19, 2008 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
heeeey Ratatat are from Brooklyn!! Just like me. Anyway, it's funny that you mention them. a couple of months ago, they just finished touring in Australia and New Zealand. It's funny to think a band like this that doesn't have top 40 stature can really do some globetrotting in their career. Gives me hope. blackdiamond13 @ Jemsite
jono
PostPosted: Thu Jan 22, 2009 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
amazing,
my upright pizzes, bows and starts flying Wink
