M185 sequencer Project - NEW PCB VERSION
Page 11 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, ..., 44, 45, 46 Next
The Alison Project
PostPosted: Tue Dec 16, 2008 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a pic of my finished Dual version.
 Filesize:  362.46 KB
 Viewed:  661 Time(s)
The Alison Project
www.thealisonproject.com
ryktnk
PostPosted: Wed Dec 17, 2008 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh la la !
That looks great, and big.
Well done.
-ryk
lexvortex
PostPosted: Wed Dec 17, 2008 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my attempt at a panel for the M-185. It's not done yet, I'm just waiting for the hardware in the mail to make any last tweaks so that I can make sure it all fits Cool I'm not sure whether I should have a sub panel for the switches or just mount them directly to the panel.
 Filesize:  60.24 KB
 Viewed:  525 Time(s)
del_poolp
PostPosted: Thu Dec 18, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
It's My first try for the adaptation of the faceplate for Eurorack format :
http://www.themeloon.net/wp-content/uploads/2008/12/frontdesign-ryk-m185-sequencer.pdf
Of what do you think of it?
I added a modification, a gate out by step.
Have you an idea of cabling for this modification ?
Thanks Wink
PS : ->ryktnk : You have a HPGL file for your logo or FPD file of your faceplate ?
 Filesize:  238.54 KB
 Viewed:  502 Time(s)
numbernone
PostPosted: Thu Dec 18, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my switches today LIGHTNING SPEED too. They look great.
If some kind soul would like to post an FPD file for the switch cutouts and mounting holes, I would be beyond eternally appreciative. I am a front panel designer virgin, and would like someone gentle to introduce me!
ryktnk
PostPosted: Thu Dec 18, 2008 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello del_poolp
The panel looks very nice !
But you have missed out a switch
and need to change the "mode" switch.
Have a look at the panel wiring PDF as there
is a 4-way switch for the sequencer mode [this
used to be random on/off on my old panel picture]
Also there is a new 4-way switch which is for the stage
subdivisions, sorry.
If you would like to add a "RYK" logo I can send
one over, very flattered !
cheers
-ryk
del_poolp
PostPosted: Fri Dec 19, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I have corrected my front panel Wink
Thanks, it's a same for my other module :
http://www.themeloon.net/diy/papareil-synth-labs-ds8/
http://www.themeloon.net/diy/papareil-synth-labs-mcv876/
http://www.themeloon.net/diy/papareil-synth-labs-polivoks-vcf/
Yes, send me your logo Wink (Look on bottom of my front panel)
For the mod (Gate out on each step), if possible, you have any idea for Wiring/Schema.
Bye,
PooLP
 Filesize:  322.16 KB
 Viewed:  351 Time(s)
numbernone
PostPosted: Fri Dec 19, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
So it looks like I will be building these out sooner than expected, but I still have few questions I want to clear up about the wiring before I proceed.
The switches for stage 2 show connections to the like numbered pins of the stage 1 switches. Should then the switches for stage 3 connect back to stage 2 and so on chronologically? If so, the 8 position switches show no connection for pin 1, these will then be left alone? The 4 position for stage 1 shows no connection on pin 1, but stage 2 shows to connect back to stage one on pin 1, is this correct?
Man, attaching the ladder resistors to the little switches is gonna be a blast!!
Thats it for now, thanks!
ryktnk
PostPosted: Sun Dec 21, 2008 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
hello numbernone
Re: switch wiring.
Sorry it's a little confusing.
Yes the all the stage 8-way switches are wired in parallel.
Pin 1 of theses switches is left unconnected.
Pin Q [the pole of the switch] is connected individually to the
"POT" connections on the PCB via a Diode [pot1, pot2,pot3 etc]
Re the 4-way switches, sorry yes the PIN 1 is also
left unconnected on all these switches [the diagram is a little misleading]
The resistors only need connecting on the first switch, it is not
too hard as the switches are big enough.
I think the PCB soldering of the LED resistors is much more of
a blast Wink
have fun !
-ryk
mono-poly
PostPosted: Sun Dec 21, 2008 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
That dual version by The Alison Project looks great!
norman phay
PostPosted: Sun Dec 21, 2008 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Just sent payment for the switches, Ryk. Many thanks & sorry for the delay - I started a new job quite recently and it's taken up a bit of my mental space over these last 2 weeks.
lexvortex
PostPosted: Sun Feb 01, 2009 7:31 pm    Post subject: BC548B? Reply with quote  Mark this post and the followings unread
Hi Ryktnk,
I have a bunch of BC548B transistors lying around and was wondering if I could use these instead of the BC547's?
Thanks,
ryktnk
PostPosted: Mon Feb 02, 2009 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello
yes should be fine, the transistors aren't super critical.
ryl
lexvortex
PostPosted: Tue Feb 03, 2009 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great!! Thanks Smile
janvanvolt
PostPosted: Sat Feb 14, 2009 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk:
i need some answers Smile i finally got all parts for the frontpanel together and now i am working my way thru the diagrams and wiring out.
- on the stage gate switches, which end is P1/P5 (? the 2 or 3 pole end?)
- same as with the stage count, is P1 = step 8 or step 1?)
also i do not understand the wiring of step 2-8. do i need to connect each P2-P8 together (e.g. like a bus system?)
(and P1-p4 of the stage gate mode ?)
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
ryktnk
PostPosted: Sun Feb 15, 2009 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
unit-sound wrote:
ryktnk:
hello
here are some answers !
stage mode switches [4way] - q1 [the pole] is the centre most pin on the row of three,
p1 is at one end p4 is at the other ! [makes no difference]
stage count switches [8way] - again the p1 or p8 you can chose
which end depending on orientation. q1 is the pin on its own.
there is a diagram of the switches posted previously on page8 of this thread
regarding the wiring, yes it is like a bus system where all the switches are wired in parallel, except the `q` poles of each switch.
hope this makes sense.
-ryk
janvanvolt
PostPosted: Sun Feb 15, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
unit-sound wrote:
ryktnk:
hello
-ryk
okay, the Q1's are now clear Smile i also measured it with the multimeter to be sure.
my question more or less regading P2 - P4 (and P2-PCool which part of P? is indicating the "lowest" position, e.g. P2 would be "I" and P3 = "II" and P4 ="l-" and as well P2-P8 = number 2-8 ?
(would seem logical to me).
if that's correct, i start bus'sing Smile
ryktnk
PostPosted: Mon Feb 16, 2009 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
hello
yes you are correct.
-ryk
norman phay
PostPosted: Sun Feb 22, 2009 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Ryk, for the 547 transistors I have a bunch of mixed 547Bs and 547Cs. Does it matter which I use, and can I mix them on one board, please?
Many thanks.
ryktnk
PostPosted: Mon Feb 23, 2009 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks.
Hello
They should be fine to use, perhaps use the same ones for the LED buffers
just so they are the same.
-ryk
lexvortex
PostPosted: Fri Mar 06, 2009 6:19 pm    Post subject: Screws for switches? Reply with quote  Mark this post and the followings unread
Where can I get the screws for the specialty switches from Ryktnk or what size I should look for? I've been to my local hardware and surplus store but can't get something to fit.
Thanks,
ryktnk
PostPosted: Tue Mar 10, 2009 3:36 am    Post subject: Re: Screws for switches? Reply with quote  Mark this post and the followings unread
lexvortex wrote:
Thanks,
hello
sorry for the delay.
the screws for the switches I think are m2 thread, which is fairly small.
m3 is more common.
better to try and get them from electronic components
place such as Farnell or Rapid, as this size is probably to
small for DIY shop.
be aware of the depth of screw as well, as it shouldn't protrude
too much into the switch mechanism.
there are tech. drawings of the switches on page 8 of this thread.
-ryk
lexvortex
PostPosted: Sat Mar 14, 2009 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm, I've looked at several sights for an M2.6 x 0.45 bolt size including the usual suspects (digi-key, etc) but can only find one type of bolt that will fit but its got a big ugly hex head likethis,
http://www.4chobbysupply.com/servlet/the-144/M2.6-x-6mm-Socket/Detail
whereas I would prefer a pan-head or button-head type head that is smaller and doesn't stick up too far from the surface I did find the one below but it has the dimensions M2.5 x 0.45, would that work or is it too small?
http://www.modelfixings.co.uk/ht_button_heads.htm?qty=1.00&sub=1.00&shp=0.00&dis=0.00&vch=0.00&tax=0.00&tot=1.00&sd=&tp=CONTINUE+SHOPPING
Does anyone have a link to somewhere where I can get something like that?
Thanks,
This is all i can find
 Filesize:  2.31 KB
 Viewed:  15488 Time(s)
This is what im looking for
 Filesize:  5.91 KB
ryktnk
PostPosted: Sat Mar 14, 2009 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
hello
try these guys:-
http://www.microfastenings.com/Home.aspx
they specialises in m2.6 and below.
-ryk
lexvortex
PostPosted: Sat Mar 14, 2009 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great!! Thanks, I just emailed them to get a quote Smile
