today> Twyndyllyngs Chez Mosc
Living VCOs
Page 9 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
TekniK
PostPosted: Tue May 19, 2009 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
you should have linked all psu for each section onboard Juergen with the option to cut the traces for those who like use seperate connectors...or implement jumper wires but the again it add a lot of solder points
numbertalk
PostPosted: Wed May 20, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Since those extra power pads are there, I'll probably use the solution JH suggests (I'll be using a MOTM header so I'll use the dotcom pads on the driver to start the chain), but I have a couple other projects that are going to include daughterboards and those boards don't have an extra set of power pads like this board conveniently does, so this seems like a very attractive solution for situations like that.
So Dave, do you solder both wires into each slot of each header (except for the last one in the chain obviously)? Though looking again it seems you solder 3 sets of wires even into one of the headers.
Actually just found this on your site, which seems to answer my question:
I press the wires in and solder them to the connectors. You can piggyback another wire on top and solder it to the feed-thru wire. It is tight but manageable.
Thanks for all the info!
wicked1
PostPosted: Wed May 20, 2009 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone thought about adding a saw to tri/sine converter?
I was looking at Bergfotrons. http://hem.bredband.net/bersyn/VCO/Saw%20to%20tri-sin%20W.gif
Would I connect it to the 0-10v saw output (as mentioned on JH's vco page)? Then I see there's an offset adjust on the saw-tri converter, and I guess that would bring it down to -5/+5?
thanks! I'm planning my panel, and trying to think about how many +/-5v waves I'll be able to bring to the panel, or if I'll need a switch to send them all to the amp, and then a single output.
numbertalk
PostPosted: Wed May 20, 2009 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I added this circuit to the Arp Odyssey VCOs I built and I believe I had to offset the waveform first. I believe you could just put a cap at the input to the converter circuit though.
2thick4uni
PostPosted: Wed May 20, 2009 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm also going to add tri and sine outputs, I was thinking of using the design on the ASM-2 which is pretty simple to implement.
http://www.elby-designs.com/asm-2/vco/vco1-shaper-asm2-cct.pdf
davebr
PostPosted: Wed May 20, 2009 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I carefully strip the wire from the first connector in the chain (towards the middle of the cable, not at the end of the cable). You only need to displace the insulation about 1/8". I tin it, then press it into the connector. I use these daisy chain power cables for daughterboards. They work well. I make them so the wire is one continuous piece from end to end.
If I need a "Y" (as I did on this module) then I add a second wire on top. Yes, it is three wire segments, but only two wires.
numbertalk
PostPosted: Sat May 23, 2009 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very good to know - will definitely come in handy. Thanks!!
jhaible
PostPosted: Tue May 26, 2009 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I put my first prototype up on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160337912688
This may be interesting for those who aren't into soldering that much.
You still need all the off-board components (potentiometrs, switches, jacks
etc.), though.
JH.
TekniK
PostPosted: Tue May 26, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
etc.), though.
JH.
The bidder is your friend or he is stupid?(no offence)
if hes not both of one mentioned u should stop sell kits NOW and only sell fully populated boards on ebay Cool
Funky40
G2 patch files: 5
PostPosted: Tue May 26, 2009 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
The bidder is ........
wow, allready sold Shocked
populating the boards was easy, wiring the Module will be tough.
a friend told me that this one makes very nice sinewaves.
I go for the Bergfotron myself i think , but only for one of the three VCOs.
I'm also interested to know about the connections to be made
jhaible
PostPosted: Tue May 26, 2009 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Depends on what configuration you want.
I have quite a small number of potentiometers in the VCO section of my JH-5A (http://www.jhaible.de/jh5/jh5_total_large.jpg): Pulse Width shared between 3 VCOs, no CV input attenuators etc., and for for what I'm mostly doing with it (bass and lead sounds), it's more than enough.
JH.
bleekza
PostPosted: Wed Jun 03, 2009 7:54 pm    Post subject: Re: Living VCOs
Subject description: Front Panel Designs
unit-sound wrote:
Anybody worked on a 5U version with the verniers ?
I second that, I want my verniers!
Where are the 5U panels for this thing?
sduck
PostPosted: Wed Jun 03, 2009 8:16 pm    Post subject: Re: Living VCOs
Go get Dave Brown's various versions. Links on the previous page in this thread. Then go get Front Panel Designer from http://www.frontpanelexpress.com/ Then you can use Scale-a-matic (http://stiftsbogtrykkeriet.dk/~mcs/Scale.html) to make some nice looking tick marks for the vernier dials, then mod Dave's design to your taste. The best looking panels are the ones you design yourself!
bleekza
PostPosted: Thu Jun 04, 2009 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent excellent links!!!
thank you so much for posting that!
You don't know how long I've been looking for something like this.
Now the only trick is coaxing a cool layout from my own creativity. jackson dancing
dingebre
PostPosted: Fri Jun 05, 2009 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, so while every teacher says, "There are no stupid questions," I think there are and I do my best to ask each one of them. So, in that light:
I am not understanding the connection between the "Driver" and the three VCO sections. How would one typically connect it all together?
I'm trying to put a panel together and would like to "normal" some typical connections to avoid switches.
David
dingebre@3dphysics.net
jhaible
PostPosted: Fri Jun 05, 2009 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
David
Use normalized jacks for the CV inputs of each VCO. But instead of normalizing to GND, normalize them (all 3 of them) to the output of the Oscillator Driver.
JH.
dingebre
PostPosted: Fri Jun 05, 2009 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, controller (keyboard, sequencer) CV into the driver. Driver out into each VCO I want to control. The drive provides portamento, etc. to the CV and drives the VCO's.
Output of each VCO into a mixer, or filter or where ever I want it to go from there.
Thanks again.
jhaible
PostPosted: Fri Jun 05, 2009 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
JH.
dingebre
PostPosted: Mon Jun 15, 2009 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is the power requirement for the Living VCO?
David
jhaible
PostPosted: Mon Jun 15, 2009 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
David
I haven't made precise measurements Embarassed
Nothing outrageous, for certain.
Last time I had it on the Lab power supply, the meters were about 90mA.
So make that 100mA * 2 * 15V = 3 Watts. (for the whole PCB)
JH.
dingebre
PostPosted: Tue Jun 16, 2009 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you JH.
I'm putting two of these into a rack with a 0.5 amp power supply and wanted to make sure I wasn't overdoing anything. Looks like I'm good to go.
David
intercorni
PostPosted: Thu Jul 02, 2009 6:52 am    Post subject: Tempco
Subject description: These types can I use?
These Tempco types can I use?
http://de.farnell.com/tyco-electronics/lt300014t261k0j/widerstand-temperature-sensing/dp/1174306
Detail:
* WIDERSTAND, TEMPERATURE SENSING, 1K
* Serie:LT
* Widerstand:1kohm
* Tolerance, Resistance:± 5%
* Temperatur, Betriebs- max.:+125°C
* Gehäusetyp:Axial
* Durchmesser, Gehäuse:2.3mm
* Länge, Anschluß:30mm
* Länge/Höhe, Außen-:6.5mm
* Temperaturkoeffizient, +:3000ppm/°C
* Toleranz, Temp.-Koeff., +:10%
* Toleranz, Temp.-Koeff., -:10%
* Widerstand, Isolations-:10Gohm
* Zeit, Ansprech:7.5s
* Nennleistung:0.25W
* Stabilität, Volllastlebensdauer +:1000 hours@125/C, 0.5
* Temperatur Arbeitsbereich:-40°C bis +125°C
* Temperatur, Betriebs- min.:-40°C
* Toleranz +:5%
* Toleranz -:5%
* Verhältnis, Widerstand +:1.37%
* Verlustkonstante:9mW/°C
* Widerstandselementtyp:Temperature Sensing
jhaible
PostPosted: Thu Jul 02, 2009 7:48 am    Post subject: Re: Tempco
Looks good!
JH.
Photon
PostPosted: Sat Jul 25, 2009 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH Living VCOs in Fractional format.
thank you, Jürgen. Very Happy
Sine
PostPosted: Sat Jul 25, 2009 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oeh, very very nice
I love those big multiturns !
I really have to finish mine, the boards are done so now there is just the mechanical work left to do.
-edit-
Can we see the backside Smile
