alain6870
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Sun May 23, 2010 2:50 am Post subject:
Want one. Great work. Post some mp3s so we can hear this beast. What keyboard did you use. Like the way you have made it patchable.  |
TekniK
Posted: Sun May 23, 2010 4:38 am Post subject:
Nice Look Alain |
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Sun May 23, 2010 5:45 am Post subject:
Very nice indeed. A patchable microsynth - quite Buchla-esque in some ways. _________________ Mike |
alain6870
Posted: Sun May 23, 2010 7:01 am Post subject:
Here a crappy MP3, it seems that MP3 compression introduces a lot of distortion in the 20 first seconds of the recording, anyway here it is:
Basic patch: saw wave + sub osc (with PWM by tri LFO) + filter (Moded by same LFO) + short attack time (2ms) + decay + release on the EG.
Effect: small chorus with ALESIS picoverb
0:00 HP filter and Res
21:00 LP mode and Res (this is normal distortion)
34:00 playing with the mixer for SUB level
46:00 octage range starting from Low to high.
I built this synth as a controller for my mini modular thats the reason why a made it "patchable". I was quite surprised by the "power" of the beast as i undertook the first audio tests.
About the construction:
I used an old keyboard and removed the rubber contacts and replaced them with microswitches and added the resistor ladder. A lot of work that I would not recommend. Its the first synth i've built with integrated KB normally I use MIDI-CV converters, wich are easier to implement and much accurate than the old S&WY designs. But for this synth I wanted to give it a special look and a vintage touch...
have a small look at the mess inside
Anyway DIY is a lot of fun, reading, learning, building, debugging, playing
Alain
Description: |
Filesize: |
2.36 MB |
Viewed: |
374 Time(s) |
delayed
Posted: Mon May 24, 2010 6:09 pm Post subject:
Hi, Great looking synth. Could you please post some images of the keyboard section? I am looking to make a keyboard layout like this and would love to steal some ideas from yours. |
alain6870
delayed
Posted: Tue May 25, 2010 4:26 pm Post subject:
Hello,
Thank you for the nice drawing. I have made a few of the MFOS controller using push buttons, but had not though of the mini type you used under the keys. Does pushing the key cause any clicking sound from the contact of the tiny buttons you used?
And your English seems fine to me! Much better than my French. |
delayed
Posted: Tue May 25, 2010 4:43 pm Post subject:
Here is what I tried with the MFOS
Description: |
Filesize: |
293.13 KB |
Viewed: |
283 Time(s) |
Description: |
Filesize: |
293.13 KB |
Viewed: |
229 Time(s) |
alain6870
Posted: Thu May 27, 2010 12:35 pm Post subject:
Hello delayed,
cool design! (Like accordion?)
For the construction of single bus KB, you'll have to choose of course really good microswitches. I took some push buttons with a very high mechanical lifetime (eg 1 000 000 cycles minimum). And you have to be sure that when you depress the key you won't push too much on the button, else you will maybe destroy them too quickly.
The design is really noise immune but this is due to the real good circuitry by Ray. Normally you should hear no noise because the KB is on the controller side of your synth and not on the audio path. The only "noise" that can be heard is the double triggering of the button's contact. With the KB you "naturally" trigger less easily that with a single button. Anyway, if you experience problems you can change the C21 capa with a higher value (max 1nF) to get larger waiting time between two triggers but, then you won't be able to play as fast of course.
I also did the wiring of the grounds in a "star" way to avoid ground loops. I also added a 20R resistor on the rails of the VCA to be noiseless ( this is not recommended by Ray but, I think it helps a lot).
Alain |
azot
adambee7
Posted: Thu May 27, 2010 5:59 pm Post subject:
Good looking panels man. How do you apply those trnsfers and keep them secure. Really interested in using those myself.  |
Inventor
Audio files: 267
Posted: Thu May 27, 2010 8:27 pm Post subject:
azot, I love those panels and the metal knobs make them look like they belong on the space shuttle. I must joke with you though, when I glanced at that photo, the way all the parts are scattered about made me think you were playing your synth too loud and it exploded! Haha, good luck with your builds...
joshco
Posted: Fri May 28, 2010 12:34 am Post subject:
nice work, those silver panels and knobs are looking very neat! |
TekniK
Posted: Fri May 28, 2010 1:02 am Post subject:
yes those modulles looks great! |
azot
Posted: Fri May 28, 2010 2:05 am Post subject:
Thanks !!)
Ahaha, Inventor, it’s really looks so!)))
I entered synthdiy inspired by old analog synths and modular systems like Moog modular or 100M and first have planned classical black with white legend panel design, mooglike knobs etc. But in way of economy made test panel from anodized aluminium with aluminium knobs. That looks so neat, so I decided implement all faces in this style.
“The Magick Touch” http://www.themagictouch.com/ is enough simple for home implementation. It’s a sort of decol paper for laser print. The transfer process is cold, no thermal press needed. After drying baking is desirable for better adhesion. The surface is waterproof, well steady for abrasion. I had an accident when drilling - the drill goes wrong and left just insignificant scratch! |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Posted: Fri May 28, 2010 4:52 am Post subject:
Love those knobs. I've got a bunch of aluminum bar stock, I may try turning some. |
adambee7
adambee7
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Fri May 28, 2010 9:20 pm Post subject:
I've decided to ditch my acrylic panels in favor of aluminum panels. Now that I've got a good supply of aluminum. One of my friends chopped up some old street signs on his table saw for me. Here's my first attempt. Only 33 more to go!
Description: |
Filesize: |
106.45 KB |
Viewed: |
22796 Time(s) |
Description: |
Filesize: |
182.47 KB |
Viewed: |
174 Time(s) |
_________________ When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr |
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Sat May 29, 2010 2:06 am Post subject:
crashlander,
are IN1 / In2 attenuators for the MS20 filter clone?
how did you go about when you added the second input?
i noticed that mine sometimes just goes silent when the input signal is too strong... on the other hand i have a feeling that the output is rather low as well. i guess it needs a bit more work...
(it is the rene schmitz version i am talking about, using the jörg schmitz pcb) |
Rykhaard
Posted: Sat May 29, 2010 3:46 am Post subject:
delayed wrote: | Here is what I tried with the MFOS |
(2 pics of the blue panel, with jacks to the left side of it; pots centered and push buttons to the right side/)
Wow! It's great to finally see someone other than myself - separating the jacks from the rest of the controls! Nice work. (I've been doing it, since about 1995, to help keep cabling out of the way of knob control / etc.) |
crashlander42
Posted: Sat May 29, 2010 8:46 am Post subject:
creekree wrote: | crashlander,
I added a simple input mixer. The filter is overdriven really easily without it. This filer is the Rene Schmitz version in vector board. _________________ When they plug me in the lights go down in Hong Kong.
TekniK
Posted: Mon May 31, 2010 6:57 am Post subject:
Fixed filters.. Last edited by TekniK on Thu Aug 19, 2010 2:54 am; edited 1 time in total |
adambee7
Posted: Mon May 31, 2010 8:00 am Post subject:
stunning as always teknik.  |
