2016 Builds!
Page 7 of 7 [175 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
PostPosted: Mon Oct 17, 2016 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Buchla 208 Random circuit. Somewhat shonky random (it repeats after 127 steps or so), but with four outputs, and clocked. Two trace cuts were needed, and two blue wires. Other than that, I'm very happy with how it came out.
I'ma gonna experiment me with some krell patching now. dcramer has been teasing me with his youtube vids for too long!
PostPosted: Fri Oct 21, 2016 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Normally, I wouldn't post a kit build, but I quite like how my wiring job turned out.
wackelpeter
Audio files: 10
PostPosted: Sat Oct 22, 2016 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
that equalizer looks nice and i wish i had íncluded the separate channel outputs on my own...
btw. i'm sure i have a bug somewhere in my build and think i'll have to look over it again, does your upper and bottom section output get's affected by the pots from the other section?
PostPosted: Sat Oct 22, 2016 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, it is interactive to a certain extent.
LFLab
PostPosted: Sat Oct 22, 2016 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great project, and your wiring looks excellent.
If you use ribbon cable it will be nicer still Very Happy
PostPosted: Sat Oct 22, 2016 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
on the 2nd picture from below when I look at the colors it looks like there might be a mistake either by you or the manufacturer.
all the colors of the wires coming from the upper board in this picture to the lower board are running next to each other except l p g ( on the upper board) colors are white brown green, but on the lower board they are brown white green.
now maybe they supposed to be like that, in that case this post was never written Rolling Eyes
Audio files: 297
PostPosted: Sat Oct 22, 2016 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Be it wrong or be it right - great eye for detail Grum :-)
Audio files: 297
PostPosted: Sat Oct 22, 2016 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
These are the modules you made your latest track with Alan?
PostPosted: Sat Oct 22, 2016 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
For noiserip, the Serge EQ was pretty much the only active ingredient (the Braids was only providing white noise.)
Audio files: 297
PostPosted: Sat Oct 22, 2016 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, nice filter then :-)
PostPosted: Tue Oct 25, 2016 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am working on a new filter on breadboard, but I was getting a lot of 60Hz interference from the power supply that I also had on breadboard. I moved the power over to a little strip board and soldered it all together. Now I should be able to finish the filter without any problems.
 Filesize:  122.46 KB
 Viewed:  456 Time(s)
 Filesize:  120.01 KB
 Viewed:  427 Time(s)
 Filesize:  127.21 KB
 Viewed:  410 Time(s)
JacobWatters.com
PostPosted: Sat Nov 05, 2016 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Today I've finished a saw-wave module.
Read more about it HERE
Cfish
PostPosted: Sun Nov 06, 2016 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Decided to work on the stack of projects getting left behind.
Bought these PAIA 4700 modules cheep on eBay. I just keep moving them out of my road, so I decided to do something.
I didn't need another full keybed. My MIDI to CV converters will do Volt/HZ, but I decided to include a 16 note keybed to use up my Ken Stone 16 note key matrix circuit I built for anouther project, and didn't use.
Has 2 VCOs, AR, ADSR, 2 Balanced modulators used as VCAs, low pass VCF, and inverter buffer module.
 Filesize:  1.49 MB
 Viewed:  358 Time(s)
Cfish
PostPosted: Sun Nov 13, 2016 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just keeps growing.
New cabinets are coming together
 Filesize:  981.16 KB
 Viewed:  350 Time(s)
PostPosted: Sun Nov 20, 2016 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
looks great Cfish! Very Happy
I finished 2 Roland SYSTEM 100m ADSR modules with an added cycle mode. more info can be found here.
LFLab
PostPosted: Sun Nov 20, 2016 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Verry nice Phobos!
PostPosted: Wed Nov 23, 2016 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eurorack format Buchla 266 Source of Uncertainty. And it all works! ElectricDruid noise chip with this one.
http://electro-music.com/forum/post-423840.html for the build log.
mcop
PostPosted: Wed Nov 23, 2016 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Been following your build Alan, awesome stuff.
Cfish
PostPosted: Thu Nov 24, 2016 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. That's a lot of circuitry. Very impresive Alanp
Made a huge decision myself today. I'm buying a module. Big jump for me, considering everything I have is on perf. Have never even built a kit module, or purchased a board.
PostPosted: Wed Dec 14, 2016 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
This Module already had an 8 channel clock devider and an arbitrairy trigger generator programmed, see THIS
Not realy a new build, but a new programmed section: I've added Euclidean Triggers to this module.
8 channels, each from 0 (no triggers) to 32 possible triggers.
In this video the sounds are coming from a (slightly modified) dsp_M8 build
edit: bad link and typo
PostPosted: Thu Dec 15, 2016 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Pretty cool stuff, reminds me a bit of the Ornament + Crime module on muffs.
PostPosted: Thu Dec 15, 2016 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that! I didn't know about the existence of this Ornament + Crime module but looking at it, I got a whole set of new ideas (well.... for me they're new Wink )
I got my inspiration of a thread here on EM, which is referring to THIS video on Youtube.
wackelpeter
Audio files: 10
PostPosted: Thu Dec 22, 2016 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry that i'm cheating a bit and present here a cabinet with a open hole, but i swear the main stripboard for this place is ready (fingers crossed) and is on top of the cabinet for those who can't believe Very Happy
The missing module is a +/-5V quantizer i build from Fonik's schematic, but accidentally as i drilled the front panel i forgot that i wanted to try it out with attentuating pots on the input and if it fit's well have to look for another filler of the left space, which i first thought should be a simple 2 channel CGS mixer... you simply can't have enough mixers...
From left to right beginning in the upper row:
PSU switch with indicator LED's, Scott Stites Quantizer, big hole, 2xLPG, 2xBuchla enevelope follower, CGS voltage processor, CGS serge VCS,
bottom row: CGS CV Cluster, Buchla 291 BPF, CGS Serge Phaser, Serge Comparator (only 2 sections), from the Buchla SOU: Integrator, S&H, stored random voltages & at least another Serge VCS.
front view
 Filesize:  768.69 KB
 Viewed:  265 Time(s)
back view
 Filesize:  775.14 KB
 Viewed:  262 Time(s)
Cfish
PostPosted: Thu Dec 22, 2016 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice looking synth Wackelpeter.
I really like to see scratch DIY builds.
PostPosted: Fri Dec 30, 2016 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
probably the last project for this year: Snailis Spiralis.
more info and photos here
