 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Nomad (NM open editor) pre release available for DL
Page 1 of 3 [74 Posts]
Goto page: 1, 2, 3 Next
PostPosted: Mon Jul 10, 2006 11:24 am    Post subject: Nomad (NM open editor) pre release available for DL Reply with quote  Mark this post and the followings unread
Today I found in my mailbox :
(see http://sourceforge.net/project/showfiles.php?group_id=69377 for downloads, scroll down for some notes I added)
our first release of Nomad - Nord Modular Editor is now available.
You can download the release in the Files section:
Package: nomad
Release 0.2.1-pre
Please note that this is only a pre release and has several bugs and
limitations.
However you can do the most important operations:
- import patch file(s)
- export patch to a file
- send a patch to the synthesizer
- receive a patch from the synthesizer
- edit patch which exists in the synthesizer
See also the file 'README.txt' in the release.
Requirements:
- Java Runtime Environment (JRE) 5.0
- platform: any
Starting Nomad:
You start Nomad with the command:
java -jar nomad.jar
Micro Modular users:
Since none of us developers has a Micro Modular available for testing
we don't support this model at the moment. However you can try if
Nomad works with this model and supply us with feedback so that we
can make necessary changes to achive support.
Note: Before you use Nomad with the Micro Modular you have to ...
- open nomad/conf/application.xml in a text editor
- change the line
<entry>4</entry>
to
<entry>1</entry>
- save the file
Feedback / Reporting Problems:
You can supply us with feedback or report problems at
the nmedit-devel mailing list:
http://sourceforge.net/mailarchive/forum.php?forum_id=18303
If you want to report exceptions please add the log file 'nomad.log' to
your report.
Your nmedit team
This is a Java version of the editor, so you'll need to have Jave installed. The software was developed under Linux but could be working on Mac's and Windows platforms as well. For details see the sourceforge site.
http://nmedit.sourceforge.net/
ocp
Audio files: 9
PostPosted: Mon Jul 10, 2006 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
Will give it a try right away!
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
The Why Project
PostPosted: Mon Jul 10, 2006 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Impressive job! GUI looks the part too!
Very nice work. It's been a while in the making, but I think it's a great
achievement!
Now I'll have a look if I can get it to work with my MM too props
Regards,
The Why Project
seawolf
PostPosted: Mon Jul 10, 2006 5:10 pm    Post subject: beautiful Reply with quote  Mark this post and the followings unread
Interface is so slick.
Anyone have any luck getting their Nord and Nomad to talk from OS X 10.4 (PPC)?
Seawolf
http://www.teamabunai.org/seawolf/
gomidas
G2 patch files: 6
PostPosted: Tue Jul 11, 2006 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It works Very Happy
mattp
PostPosted: Tue Jul 11, 2006 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
That is fantastic. Top work. Looks lovely.
3phase
G2 patch files: 141
PostPosted: Tue Jul 11, 2006 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
cool thing especially for mac users..only problem..os x jar starter dont opens the file..
have i missed something?
eposk
PostPosted: Tue Jul 11, 2006 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
it works great!
so now that Nomad has the power, will there be any new modules built into this?
PostPosted: Tue Jul 11, 2006 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
eposk wrote:
iwill there be any new modules built into this?
Very Happy that would require the synth OS to be rebuilt as well ... nothing hints at people working on that.
chresan
PostPosted: Tue Jul 11, 2006 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
You have to make sure that Nomad is started from within the same directory where nomad.jar file lays. Something like
Code:
java -jar long/path/to/nomad.jar
won't work. Instead you should do
Code:
cd long/path/to
java -jar nomad.jar
I have no Mac so I can't tell you how to configure the os x jar starter, maybe someone else knows.
Christian
http://nmedit.sf.net
W.T.
G2 patch files: 11
PostPosted: Thu Jul 13, 2006 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
looks good! when all the modules ar suported i might by me a nm1....nice
W.T.
G2 patch files: 11
PostPosted: Thu Jul 13, 2006 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
it works fine on my osx 10.4.7 macbook!
3phase
G2 patch files: 141
PostPosted: Thu Jul 13, 2006 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I just upgraded to 10.4.7..
but i still cant open the nomad.jar...
How do you open it?
W.T.
G2 patch files: 11
PostPosted: Fri Jul 14, 2006 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
How do you open it?
I simply opened the zip on my desktop and then opened the nomad java file that is inside this nomad folder on my desktop. then just opened the java file.
it works great.
PostPosted: Fri Jul 14, 2006 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Sven, just a wild guess ... do you have the right Java Runtime Environment ?
The readme says :
Requirements:
3phase
G2 patch files: 141
PostPosted: Fri Jul 14, 2006 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
i ve the newest that apple is providing..the one inside 10.4.7...
on my machine nothing opens Sad
chresan
PostPosted: Fri Jul 14, 2006 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
1. You might not see the application starting when an exception occurs. Can you look if there is a file 'nomad.log' inside the application directory and if so can you post the file here?
2. If the log file does not exist then nomad has never been started. Could you try starting it manually?
This can be done with the following command which must be called from within the applications directory
Code:
java -jar nomad.jar
If this works for you then the jar starter you mentioned is not working. In this case I am not able to help you since I have no mac.
Christian
3phase
G2 patch files: 141
PostPosted: Sat Jul 15, 2006 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
today my software updater offered me a new java version...seems that the newest one is not part of the initial install of 10.4.7... but it only gets offered after 10.4.7 is installed...
Now its working Smile
Do you nee reports or is this more relevant after the version 1.0 release?
G,.
Sven
pOisK
PostPosted: Sat Jul 15, 2006 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys Smile
Could we hope something like the Mutator for NM1 ? Very Happy
dxmat
G2 patch files: 8
PostPosted: Sun Jul 16, 2006 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent work! Shocked Shocked
klangumsetzer
Audio files: 37
PostPosted: Sun Jul 16, 2006 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
works nicely with xp sp2 and updated j2environment.
looks and feels solid: nice work Very Happy
a few things i noticed (i have not looked into it too deeply, i must admit):
there are certain patches which will not open but open with clavia's editor (v3).
i have to manually download(upload?) the patches to my nn to addition them? is there a setting to do that automatically?
best regards
eike
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Sun Jul 16, 2006 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
damn, this is cool. I don't even own a NM1 or micro but the idea of being able to edit any nord from linux makes it tempting. Excellent use of multi-platform java and open source,
chresan
PostPosted: Sun Jul 16, 2006 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks eike, nice to hear that.
The current patch file parser handles only the 3.03 patch file format. If you open the patch with clavias latest editor and save it again you should have no problems loading it with Nomad. We know that some older patches are not working, but future releases of Nomad will be able to read them.
best regards
eike
Do you refer to bank up/download ? There is currently no support for this, but will be in future releases.
Christian
klangumsetzer
Audio files: 37
PostPosted: Sun Jul 16, 2006 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi christian,
chresan wrote:
(...) Do you refer to bank up/download ? There is currently no support for this, but will be in future releases.
thanks for answering my questions, keep up the good work!
best regards
eike
pOisK
PostPosted: Tue Jul 18, 2006 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Chresan > Could we hope something like the Mutator for NM1 ?
Thanks Wink
