Joined: Apr 03, 2004 Posts: 24479 Location: The Netherlands, Enschede
Posted: Mon Jul 10, 2006 11:24 am Post subject:
Nomad (NM open editor) pre release available for DL |
Today I found in my mailbox :
(see http://sourceforge.net/project/showfiles.php?group_id=69377 for downloads, scroll down for some notes I added)
Quote: | Hi,
our first release of Nomad - Nord Modular Editor is now available.
You can download the release in the Files section:
Package: nomad
Release 0.2.1-pre
Please note that this is only a pre release and has several bugs and
limitations.
However you can do the most important operations:
- import patch file(s)
- export patch to a file
- send a patch to the synthesizer
- receive a patch from the synthesizer
- edit patch which exists in the synthesizer
See also the file 'README.txt' in the release.
Requirements:
- Java Runtime Environment (JRE) 5.0
- platform: any
Starting Nomad:
You start Nomad with the command:
java -jar nomad.jar
Micro Modular users:
Since none of us developers has a Micro Modular available for testing
we don't support this model at the moment. However you can try if
Nomad works with this model and supply us with feedback so that we
can make necessary changes to achive support.
Note: Before you use Nomad with the Micro Modular you have to ...
- open nomad/conf/application.xml in a text editor
- change the line
<entry>4</entry>
to
<entry>1</entry>
- save the file
Feedback / Reporting Problems:
You can supply us with feedback or report problems at
the nmedit-devel mailing list:
http://sourceforge.net/mailarchive/forum.php?forum_id=18303
If you want to report exceptions please add the log file 'nomad.log' to
your report.
Your nmedit team
This is a Java version of the editor, so you'll need to have Jave installed. The software was developed under Linux but could be working on Mac's and Windows platforms as well. For details see the sourceforge site.
http://nmedit.sourceforge.net/ _________________ Jan
ocp
Joined: Sep 14, 2004 Posts: 535 Location: Porto, Portugal
Audio files: 9
The Why Project
Posted: Mon Jul 10, 2006 3:37 pm Post subject:
Impressive job! GUI looks the part too!
Very nice work. It's been a while in the making, but I think it's a great
achievement!
Now I'll have a look if I can get it to work with my MM too
Regards,
The Why Project |
seawolf
Joined: Sep 11, 2005 Posts: 20 Location: chicago illinois usa
Posted: Mon Jul 10, 2006 5:10 pm Post subject:
beautiful |
Interface is so slick.
Anyone have any luck getting their Nord and Nomad to talk from OS X 10.4 (PPC)? _________________ Seawolf
http://www.teamabunai.org/seawolf/ |
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Tue Jul 11, 2006 4:39 am Post subject:
It works  |
mattp
Posted: Tue Jul 11, 2006 6:22 am Post subject:
That is fantastic. Top work. Looks lovely. |
3phase
G2 patch files: 141
Posted: Tue Jul 11, 2006 7:53 am Post subject:
cool thing especially for mac users..only problem..os x jar starter dont opens the file..
have i missed something? |
eposk
Joined: Apr 29, 2005 Posts: 155 Location: Portland, OR
Posted: Tue Jul 11, 2006 9:45 am Post subject:
it works great!
so now that Nomad has the power, will there be any new modules built into this? |
Posted: Tue Jul 11, 2006 11:07 am Post subject:
eposk wrote: | iwill there be any new modules built into this? |
that would require the synth OS to be rebuilt as well ... nothing hints at people working on that. _________________ Jan
chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Tue Jul 11, 2006 11:42 am Post subject:
3phase wrote: | cool thing especially for mac users..only problem..os x jar starter dont opens the file..
You have to make sure that Nomad is started from within the same directory where nomad.jar file lays. Something like
Code: | java -jar long/path/to/nomad.jar |
won't work. Instead you should do
Code: | cd long/path/to
java -jar nomad.jar |
I have no Mac so I can't tell you how to configure the os x jar starter, maybe someone else knows.
Christian _________________ ----------------------
http://nmedit.sf.net |
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Thu Jul 13, 2006 2:28 am Post subject:
looks good! when all the modules ar suported i might by me a nm1....nice |
W.T.
G2 patch files: 11
Posted: Thu Jul 13, 2006 2:30 am Post subject:
it works fine on my osx 10.4.7 macbook! |
3phase
G2 patch files: 141
Posted: Thu Jul 13, 2006 6:33 am Post subject:
W.T. wrote: | 3phase wrote: | cool thing especially for mac users..only problem..os x jar starter dont opens the file..
I just upgraded to 10.4.7..
but i still cant open the nomad.jar...
How do you open it? |
W.T.
G2 patch files: 11
Posted: Fri Jul 14, 2006 3:46 am Post subject:
3phase wrote: | W.T. wrote: | 3phase wrote: | cool thing especially for mac users..only problem..os x jar starter dont opens the file..
I simply opened the zip on my desktop and then opened the nomad java file that is inside this nomad folder on my desktop. then just opened the java file.
it works great. |
Posted: Fri Jul 14, 2006 6:49 am Post subject:
Sven, just a wild guess ... do you have the right Java Runtime Environment ?
The readme says :
3phase
G2 patch files: 141
Posted: Fri Jul 14, 2006 2:53 pm Post subject:
i ve the newest that apple is providing..the one inside 10.4.7...
on my machine nothing opens  |
chresan
Posted: Fri Jul 14, 2006 3:44 pm Post subject:
3phase wrote: | i ve the newest that apple is providing..the one inside 10.4.7...
1. You might not see the application starting when an exception occurs. Can you look if there is a file 'nomad.log' inside the application directory and if so can you post the file here?
2. If the log file does not exist then nomad has never been started. Could you try starting it manually?
This can be done with the following command which must be called from within the applications directory
Code: | java -jar nomad.jar |
If this works for you then the jar starter you mentioned is not working. In this case I am not able to help you since I have no mac.
3phase
G2 patch files: 141
Posted: Sat Jul 15, 2006 5:48 am Post subject:
today my software updater offered me a new java version...seems that the newest one is not part of the initial install of 10.4.7... but it only gets offered after 10.4.7 is installed...
Now its working
Do you nee reports or is this more relevant after the version 1.0 release?
G,.
Sven |
pOisK
Posted: Sat Jul 15, 2006 6:37 am Post subject:
Hello guys
Could we hope something like the Mutator for NM1 ?  |
dxmat
G2 patch files: 8
Posted: Sun Jul 16, 2006 12:03 am Post subject:
Excellent work!  |
klangumsetzer
Audio files: 37
Posted: Sun Jul 16, 2006 8:04 am Post subject:
works nicely with xp sp2 and updated j2environment.
looks and feels solid: nice work
a few things i noticed (i have not looked into it too deeply, i must admit):
there are certain patches which will not open but open with clavia's editor (v3).
i have to manually download(upload?) the patches to my nn to addition them? is there a setting to do that automatically?
best regards
eike
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Sun Jul 16, 2006 9:33 am Post subject:
damn, this is cool. I don't even own a NM1 or micro but the idea of being able to edit any nord from linux makes it tempting. Excellent use of multi-platform java and open source, |
chresan
Posted: Sun Jul 16, 2006 10:56 am Post subject:
noodulator wrote: | works nicely with xp sp2 and updated j2environment.
looks and feels solid: nice work  |
Thanks eike, nice to hear that.
there are certain patches which will not open but open with clavia's editor (v3). |
The current patch file parser handles only the 3.03 patch file format. If you open the patch with clavias latest editor and save it again you should have no problems loading it with Nomad. We know that some older patches are not working, but future releases of Nomad will be able to read them.
Quote: | i have to manually download(upload?) the patches to my nn to addition them? is there a setting to do that automatically?
best regards
eike |
Do you refer to bank up/download ? There is currently no support for this, but will be in future releases.
klangumsetzer
Audio files: 37
Posted: Sun Jul 16, 2006 11:18 pm Post subject:
hi christian,
chresan wrote: | (...) Do you refer to bank up/download ? There is currently no support for this, but will be in future releases.
thanks for answering my questions, keep up the good work!
best regards
eike
pOisK
Posted: Tue Jul 18, 2006 8:44 am Post subject:
Chresan > Could we hope something like the Mutator for NM1 ?
Thanks  |
