Inverting attenuators
Page 1 of 3 [52 Posts]
Goto page: 1, 2, 3 Next
Coriolis
PostPosted: Sun Sep 24, 2006 9:20 am    Post subject: Inverting attenuators
Subject description: Where to use them - where to avoid?
I see that Serge-fans rave about having attenuators with inverting capabilities on cv-inputs. Makes sense I guess, giving more functionality using less space.
So where would you put them, if you were building a synth? Do they make more sense on some modules than others?
I'm thinking about going that route on my modular, which I'm designing at the moment, but I'm thinking the decreased adjustability (cutting the pot sweep in half) wouldn't be worth it on all modules?
Any input on this?
C
Audio files: 306
PostPosted: Sun Sep 24, 2006 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clavia used inverting inputs for their "voltage" controlled envelope modules on the NM Classic, this sort of makes sense as usually higher notes should be shorter than lower ones and the pitch control voltage can directly be used then to control the envolope attack, decay and hold times.
Coriolis
PostPosted: Mon Sep 25, 2006 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm...I'm not quite sure I understand what exactly inverters would do in that application. I thought ADSR's were used with positive going voltages only? Maybe I'm thinking of gate signals?
I do understand how inverting the output of an ADSR could be useful though... Wink
C
Audio files: 306
PostPosted: Mon Sep 25, 2006 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I was refering to voltage controlling the ADSR times.
Coriolis
PostPosted: Mon Sep 25, 2006 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
So: having an inv att on the cv input of, say, attack time, Instead of having the range of the adsr going from 0v to +5V on a regular pot, it would go from -5v to +5v on an inverting attenuator, or what? And what would the negative portion of that do? Nothing? Negative attack time? Shocked
Question
C
Scott Stites
Audio files: 96
PostPosted: Mon Sep 25, 2006 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
As you mentioned, you wouldn't want them in places where you want that fine range of control - full sweep of the pot certainly helps there. This would include modulation inputs for VCOs, for example. A little voltage goes a long way when setting up a vibrato, chiff or trill.
Sometimes, I'll put both an attenuverting input and a non-attenuverting input to a device in those cases. Better yet, if you have some spare space on any module, plant an attenuverter there - an input, an output and a pot. With this you can patch the output to any input that doesn't have an attenuverting CV input. If you use 1/4" or 1/8" connectors, the added bonus is that this circuit can double as a bias source. If you normal the input connector to, say, +5V, you can get a variable +/-5V bias voltage from the output if nothing is plugged into the input. Bias voltages are very useful to have around.....
Scott
Audio files: 306
PostPosted: Mon Sep 25, 2006 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Coriolis wrote:
or what?
A higher CV would make a shorter atack time, shorter than some preset value. Not a negative time of course.
Coriolis
PostPosted: Mon Sep 25, 2006 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Using banana-jacks here, so no bias for me, but attenuverters as a sort of utility-space-filling element makes sense, except it means using more panel space instead of less, I think. But perhaps having attenuverters dispersed on various modules might make up for that.
I guess I need to get some experience using inverters... Wink
C
PostPosted: Tue Sep 26, 2006 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i found the buchlatype processing very helpful. the incoming cv processed by a +/- attenuation pot, an offset pot and a lag pot (optional). it's worth a module on it's own, i think. you may take a look at this:
Dual Voltage Processor (Peter Grenader, personal use only)
 Filesize:  56.68 KB
 Viewed:  377 Time(s)
Coriolis
PostPosted: Tue Sep 26, 2006 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice! Offset could be useful...
But where would I put the optional lag pot you talk about?
And what does it do?
Sorry for being a bit of a pain... Embarassed
C
PostPosted: Tue Sep 26, 2006 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like a good use for those old fashion dual-pots (a small one mounted ontop/within a larger knob), or one of those push=1thing/pull=another like they use on some car radios (volume/bass, etc).
PostPosted: Tue Sep 26, 2006 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Coriolis wrote:
...where would I put the optional lag pot?
below i posted a small schematic. just replace the output protection resistor (1k) by this little circuit (the left opa from the tl084 can be used as a output buffer...). the cap doesn't have to be polarized, i think.
 Filesize:  2.8 KB
 Viewed:  13594 Time(s)
PostPosted: Tue Sep 26, 2006 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
concerning the voltage processor i'd recommended to replace the 10k resistor at the negative input of the first opa by a 2k 10T trimmer (used as variable resistor) and a 9k1 resistor in series. this way you can use a center taped pot and calibrate the circuit.
Coriolis
PostPosted: Wed Sep 27, 2006 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks fonik, those look nice and easy to try, and probably deserve a module of their own as you say.
So, if I understand correctly, the lag circuit is the same as glide?
If, for instance, I put a sample & hold fed by white noise through the lag circuit, the output voltages would glide from step to step smoothly, instead the abrupt random stepping one usually gets with s/h?
C
Audio files: 232
PostPosted: Wed Sep 27, 2006 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Inverting attenuators are great for CV inputs to filters, especially ones controlled by envelops. This gives one knob control so the envelop with open the filter or close it. Both effects are useful.
PostPosted: Wed Sep 27, 2006 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
C
yep!
Coriolis
PostPosted: Thu Sep 28, 2006 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
To Mosc and fonik:
Keeewl! Cool
I like these simple little things that make a huge difference...
C
bearblock
PostPosted: Fri Oct 06, 2006 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
hey fonik, i was considering stripboarding a couple of the first schematic you posted (the buzzclick one) but sadly enough i can't work out if the offset is +/- or just +, in which case i would probably want to alter things so you can subtract as well as add.
t
PostPosted: Fri Oct 06, 2006 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
C
yep!
Actually, lags and inverters are natural allies that accomplish some pretty clever things.
For example, once I wanted to generate vibrato with my Theremax (it produces cv's) without the note bias. The solution was to split the output voltage from the Theremin, on one side of the split I ran the voltage thru an inverter and then through a lag and then summed the two voltages together:
Theremin cv --> inverter --> lag --> mixer --> cv without note bias
\split -------------------------------------^
One varies the degree of lag to vary the amount of vibrato that "bleeds" through the circuit.
Inverters are great for building morphing waveforms, too. For example, detune two VCO's close to (but not exactly) one octave, use their sawtooth wave outputs, and invert one of the sawtooth waves before mixing. The result will be a waveform that morphs between a sawtooth and a square an octave higher.
(My old EICO oscilloscope quit and I just tossed it. Darn, I wish I had it. I may just break down and get me a scope. I thought I needed the space however I'd rather have the scope. If I keep writing about these topics the urge to get a scope will overtake me!)
Audio files: 232
PostPosted: Fri Oct 06, 2006 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried software scopes:
Wave Tools http://www.sonicspot.com/wavetools/wavetools.html
or maybe
Virtual Analyzer http://hacca.altervista.org/
piedwagtail
PostPosted: Sat Oct 07, 2006 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
My preference.... Mr. Green
Robert
 Filesize:  451.17 KB
 Viewed:  268 Time(s)
PostPosted: Sun Oct 08, 2006 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Never have tried software scopes. Looks very promising... I will take a look.
PostPosted: Tue Oct 10, 2006 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
hi coriolis, i know the klee2 deserves all our attention, but the voltage processor is easy and fast to build. i breadboarded the circuit and came up with some improvements. besides some minor changes i incorporated a lag pot, a trimmer for calibrating a center taped pot (+/- processing) and there's a resistor missing in the original schematic. to bring the LEDs to live they'll have to go to ground via a resistor. so here's my breadboarded and tested version of the buchlidian voltage processor:
voltage processor (+/- attenuvertion, offset, glide)
 Filesize:  16.13 KB
 Viewed:  516 Time(s)
Coriolis
PostPosted: Tue Oct 10, 2006 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Mucho thanks, fonik! Looks very handy and easy to build.
Now i just need to build some more modules, so i have something to lag, offset and invert! Wink Sofar only 1 vco and 1 lfo is done...
C
PostPosted: Tue Oct 10, 2006 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
i just want to say, that in case you want to use the processor for 1V/oct CVs, R4 should be matched with R3/T1 and P1 to have the OPA at 1:1 amplification - mmmh, am i right or just a little bit confused?
