Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Sun Sep 24, 2006 9:20 am Post subject:
Inverting attenuators Subject description: Where to use them - where to avoid? |
I see that Serge-fans rave about having attenuators with inverting capabilities on cv-inputs. Makes sense I guess, giving more functionality using less space.
So where would you put them, if you were building a synth? Do they make more sense on some modules than others?
I'm thinking about going that route on my modular, which I'm designing at the moment, but I'm thinking the decreased adjustability (cutting the pot sweep in half) wouldn't be worth it on all modules?
Any input on this?
C |
Joined: Apr 03, 2004 Posts: 24672 Location: The Netherlands, Enschede
Posted: Sun Sep 24, 2006 3:26 pm Post subject:
Clavia used inverting inputs for their "voltage" controlled envelope modules on the NM Classic, this sort of makes sense as usually higher notes should be shorter than lower ones and the pitch control voltage can directly be used then to control the envolope attack, decay and hold times. _________________ Jan
Coriolis
Posted: Mon Sep 25, 2006 5:01 am Post subject:
Hmm...I'm not quite sure I understand what exactly inverters would do in that application. I thought ADSR's were used with positive going voltages only? Maybe I'm thinking of gate signals?
I do understand how inverting the output of an ADSR could be useful though...
C |
Posted: Mon Sep 25, 2006 5:07 am Post subject:
I was refering to voltage controlling the ADSR times. _________________ Jan
Coriolis
Posted: Mon Sep 25, 2006 7:08 am Post subject:
So: having an inv att on the cv input of, say, attack time, Instead of having the range of the adsr going from 0v to +5V on a regular pot, it would go from -5v to +5v on an inverting attenuator, or what? And what would the negative portion of that do? Nothing? Negative attack time?
C |
Scott Stites
Audio files: 96
Posted: Mon Sep 25, 2006 7:58 am Post subject:
As you mentioned, you wouldn't want them in places where you want that fine range of control - full sweep of the pot certainly helps there. This would include modulation inputs for VCOs, for example. A little voltage goes a long way when setting up a vibrato, chiff or trill.
Sometimes, I'll put both an attenuverting input and a non-attenuverting input to a device in those cases. Better yet, if you have some spare space on any module, plant an attenuverter there - an input, an output and a pot. With this you can patch the output to any input that doesn't have an attenuverting CV input. If you use 1/4" or 1/8" connectors, the added bonus is that this circuit can double as a bias source. If you normal the input connector to, say, +5V, you can get a variable +/-5V bias voltage from the output if nothing is plugged into the input. Bias voltages are very useful to have around.....
Scott |
Posted: Mon Sep 25, 2006 8:34 am Post subject:
A higher CV would make a shorter atack time, shorter than some preset value. Not a negative time of course. _________________ Jan
Coriolis
Posted: Mon Sep 25, 2006 9:07 am Post subject:
Using banana-jacks here, so no bias for me, but attenuverters as a sort of utility-space-filling element makes sense, except it means using more panel space instead of less, I think. But perhaps having attenuverters dispersed on various modules might make up for that.
I guess I need to get some experience using inverters...
C |
Coriolis
Posted: Tue Sep 26, 2006 7:44 am Post subject:
Very nice! Offset could be useful...
But where would I put the optional lag pot you talk about?
And what does it do?
Sorry for being a bit of a pain...
C |
Posted: Tue Sep 26, 2006 9:53 am Post subject:
| Sounds like a good use for those old fashion dual-pots (a small one mounted ontop/within a larger knob), or one of those push=1thing/pull=another like they use on some car radios (volume/bass, etc). |
Posted: Tue Sep 26, 2006 11:01 pm Post subject:
| concerning the voltage processor i'd recommended to replace the 10k resistor at the negative input of the first opa by a 2k 10T trimmer (used as variable resistor) and a 9k1 resistor in series. this way you can use a center taped pot and calibrate the circuit. |
Coriolis
Posted: Wed Sep 27, 2006 12:04 pm Post subject:
Thanks fonik, those look nice and easy to try, and probably deserve a module of their own as you say.
So, if I understand correctly, the lag circuit is the same as glide?
If, for instance, I put a sample & hold fed by white noise through the lag circuit, the output voltages would glide from step to step smoothly, instead the abrupt random stepping one usually gets with s/h?
C |
Joined: Jan 31, 2003 Posts: 18313 Location: Durham, NC
Audio files: 235
Posted: Wed Sep 27, 2006 8:52 pm Post subject:
Inverting attenuators are great for CV inputs to filters, especially ones controlled by envelops. This gives one knob control so the envelop with open the filter or close it. Both effects are useful. _________________ --Howard
my music and other stuff |
Posted: Wed Sep 27, 2006 10:38 pm Post subject:
| Coriolis wrote: | So, if I understand correctly, the lag circuit is the same as glide?
C |
yep! |
Coriolis
Posted: Thu Sep 28, 2006 1:34 am Post subject:
To Mosc and fonik:
Keeewl!
I like these simple little things that make a huge difference...
C |
bearblock
Posted: Fri Oct 06, 2006 11:06 am Post subject:
hey fonik, i was considering stripboarding a couple of the first schematic you posted (the buzzclick one) but sadly enough i can't work out if the offset is +/- or just +, in which case i would probably want to alter things so you can subtract as well as add.
t |
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Fri Oct 06, 2006 11:28 am Post subject:
| fonik wrote: | | Coriolis wrote: | So, if I understand correctly, the lag circuit is the same as glide?
C |
yep! |
Actually, lags and inverters are natural allies that accomplish some pretty clever things.
For example, once I wanted to generate vibrato with my Theremax (it produces cv's) without the note bias. The solution was to split the output voltage from the Theremin, on one side of the split I ran the voltage thru an inverter and then through a lag and then summed the two voltages together:
Theremin cv --> inverter --> lag --> mixer --> cv without note bias
\split -------------------------------------^
One varies the degree of lag to vary the amount of vibrato that "bleeds" through the circuit.
Inverters are great for building morphing waveforms, too. For example, detune two VCO's close to (but not exactly) one octave, use their sawtooth wave outputs, and invert one of the sawtooth waves before mixing. The result will be a waveform that morphs between a sawtooth and a square an octave higher.
(My old EICO oscilloscope quit and I just tossed it. Darn, I wish I had it. I may just break down and get me a scope. I thought I needed the space however I'd rather have the scope. If I keep writing about these topics the urge to get a scope will overtake me!) |
Audio files: 235
piedwagtail
Posted: Sun Oct 08, 2006 12:57 pm Post subject:
| Never have tried software scopes. Looks very promising... I will take a look. |
Coriolis
Posted: Tue Oct 10, 2006 9:18 am Post subject:
Mucho thanks, fonik! Looks very handy and easy to build.
Now i just need to build some more modules, so i have something to lag, offset and invert! Sofar only 1 vco and 1 lfo is done...
C |
Posted: Tue Oct 10, 2006 10:07 am Post subject:
| i just want to say, that in case you want to use the processor for 1V/oct CVs, R4 should be matched with R3/T1 and P1 to have the OPA at 1:1 amplification - mmmh, am i right or just a little bit confused? |
