Posted: Fri Oct 27, 2006 4:25 am Post subject:
| v-un-v wrote: | Love the avatar Uncle K. Dunno what's more frightening, you or the teminator  |
If either side of that gif resembles any actual person in the real world, then God help us all!!!  _________________ What makes a space ours, is what we put there, and what we do there. |
Joel
Posted: Fri Oct 27, 2006 7:36 am Post subject:
Hi all,
a couple more questions have arisen as I try to order parts....
Rapidelectronics doesn't have 7805 voltage regulators, can I use this LE50CZ?
In that case I only need a 2.2uF stabilising cap, is that C7 in the parts list / c20 on Uncle K's stripboard layout?
Rapid doesn't have BC550 either, any suggestions for replacements?
Thanks for all the help (as always)
Joel |
Posted: Fri Oct 27, 2006 8:33 am Post subject:
Oh yes they do: - here
Yeah, that would be C20
I'd check again for the BC550, they're almost as common as the 7805.
[Blue Hell shortened the link a bit] _________________ What makes a space ours, is what we put there, and what we do there. |
vibesmaster
Joined: Aug 26, 2006 Posts: 14 Location: southend on sea,essex,uk
Posted: Fri Oct 27, 2006 4:53 pm Post subject:
yes got mine built up tonight and i cant believe it i actually got sound will get some pictures up and sound samples when i get it cased up over the weekend ,
joel i used a bc547 instead of 550 thats what google came up with as a match and it seems to work lovely if you wanted pm me your address and i will post one out on monday for you i ended up getting 50 so got some spare  |
Joel
Posted: Mon Oct 30, 2006 5:28 am Post subject:
Thanks for the link Unc, last time I rely on the search function
Looking forward to pics and samples vibesmaster!! I'll pick up some bc550s at Maplin, cheers for the offer though, I'm sure you'll find something to do with all those spare 547s  |
vibesmaster
Posted: Tue Oct 31, 2006 4:36 pm Post subject:
yes people back again i left the battery in my ds-7 lastnight and went to show it off to a friend tonight but there was no sound , i replaced the battery and it was fine so it seems it is using battery power even if not producing sounds, on my synare it has a plug in power meaning when you plug a 1/4"jack into the input it kicks the battery power through the connection , is this possible on the ds-7 ? didnt think it should use power if not being used? the battery was a good one by the way , just dont want to be taking the battery in and out everytime i want to have a play about , i always take batterys out still if im not going to use it for a week or 2 ,
thanks for any help  |
Joel
Posted: Tue Oct 31, 2006 4:55 pm Post subject:
Hi vibesmaster, can't you just wire a switch in series with the battery? It could either be a toggle switch, or a switch built in to one of the jacks (i.e. the output jack, so that when you plug something into the output it fires up the circuit) - you'd need to find a switched socket that was normally open
Good luck! Remember to post some pics and samples with a fresh battery  |
vibesmaster
Posted: Tue Oct 31, 2006 5:00 pm Post subject:
yeah will have a look into that in the morning when im less tired  |
Wild Zebra
Posted: Wed Nov 01, 2006 8:18 am Post subject:
Use a stereo jack and wire the - battery to the ring of the jack. So when you plug a jack into it, it will make the connection and turn on. Hope that makes sense _________________ "your stripes are killer bro" |
discointellect
Posted: Wed Nov 01, 2006 12:53 pm Post subject:
Nearly got my DS clones finished - 2 DS8s and 2 DS7s on a rackmount panel; got 3 of the boards wired up so far and its sounding good sequenced from my Regelwerk. I've done the CV in mods as well so I can have all 4 channels playing tunes rather than just pure synth percussion if the mood takes me.
From the front...
From the back...
Pretty messy from both angles I'll admit, but amazingly it works. |
Wild Zebra
Posted: Wed Nov 01, 2006 2:10 pm Post subject:
Very Nice, I'm still alittle ways off on the DS7's, but could you point me in the direction of the CV in mods? DS8? thats the DS7 with noise right? I figure by the time I get to these there will be more mods Dnny knows how long I had the DS7's on my list. About as long as his Soundlab hehe _________________ "your stripes are killer bro" |
discointellect
Posted: Wed Nov 01, 2006 2:22 pm Post subject:
Sure, here's the diagrams Marc supplied (hope he doesn't mind me redistributing them here)
39.24 KB |
| Viewed: |
17997 Time(s) |
35.85 KB |
| Viewed: |
17952 Time(s) |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Thu Nov 02, 2006 5:27 am Post subject:
Very nice,
I thought i have posted the CV mod but no? well thanks for posting it.
Tim (zebra) . I´m taking steps back whit my SL - one day week ago, i savaged few pots from my "nearly done"-SL for other projects - that's bad i know.
there should be betting on dnny vs. v-un-v, who gets it done first?
what do you think? _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
richardc64
Audio files: 26
Posted: Thu Nov 02, 2006 8:38 am Post subject:
| discointellect wrote: | | ...I can have all 4 channels playing tunes rather than just pure synth percussion |
Tunes? TUNES?!?!?! How well do the VCOs track? I'd like to hear that. |
discointellect
Posted: Thu Nov 02, 2006 8:48 am Post subject:
| richardc64 wrote: | | discointellect wrote: | | ...I can have all 4 channels playing tunes rather than just pure synth percussion |
Well, it's not a nice 1v/Oct or anything so don't get too excited; I sequence it from my Regelwerk and do it entirely by ear rather than trying to match the notes it says it's playing but you can definitely get melodies out of it. I suspect trying to play it directly from a keyboard would give you some interesting results though  |
Wild Zebra
Posted: Thu Nov 02, 2006 9:20 am Post subject:
THANKS, Cv ins will be dandy
| Quote: | there should be betting on dnny vs. v-un-v, who gets it done first?
he he. Its all good theres just so much sweet stuff to make. I'm "almost" finished my sequencer. I got the boards from Ray last November. I can't tell you how excited I am about that. Just need to find someone to work out my PSU woes. Then finish some module panels I've had for another year. THEN DS7's AHHHHHHHHHHHH. Muhhahahahahahahha _________________ "your stripes are killer bro" |
EraSer
Posted: Mon Nov 06, 2006 1:01 am Post subject:
Hi all,
I have a problem with my DS7 .It doesn't wok very well:when i put a jack from the DS7' output to the mixer, I can hear that it strangely starts oscillating , even when I don't insert piezo in the DS7 input.Then I try making sound with piezo but it doesn't work.What I can do  |
sneakthief
Posted: Sat Nov 11, 2006 3:43 am Post subject:
i just had the funniest DS7 experience
i had only ever visited this thread a couple of times but hadn't been that interested - that is until i had to perform with one last night!!
story: an ex-member of an old new-wave band called "Rational Youth" from Canada had a performance in berlin last night. he 'recruited' various people to help him perform for his set and i helped out with a couple of songs by playing a Merlin and a DS7! (which i had never seen before in real-life)
i basically had to fool around with the knobs while triggering the DS7 by whacking it, thus triggering the internal piezo. it sounds great and is really fun to play with.
the casing is so solid and the knobs still feel good after all these years. i'm impressed. _________________ Sneak-Thief - raw electrofunk |
MIKEFORD
Posted: Wed Nov 15, 2006 7:38 pm Post subject:
anybody tackle the ds8 |
howdy!
anybody build the ds8(vero or ordered/madeds8) They seem to be likker synthdrums for the diyer! |
Posted: Thu Nov 16, 2006 1:16 am Post subject:
| balance wrote: | Hi all,
Did you just build it, or has it worked before? _________________ What makes a space ours, is what we put there, and what we do there. |
EraSer
Posted: Thu Nov 16, 2006 3:44 am Post subject:
| Uncle Krunkus wrote: |
Did you just build it, or has it worked before? |
It just worked before.NOOOOOOOO Now I've noticed that a regulator's pin is broken!Maybe could it be the root of the problem? |
Posted: Thu Nov 16, 2006 5:12 am Post subject:
If any of the pins on the regulator are broken, it won't have a snowball's chance in hell of working!  _________________ What makes a space ours, is what we put there, and what we do there. |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Posted: Sun Dec 03, 2006 4:51 am Post subject:
I reckon the connection between U1A pin1 and the R29/30 pair is where you should cut it. (first, of course, make sure the patient is stable and that the heart/lung machine is on the backup generator! ) _________________ What makes a space ours, is what we put there, and what we do there. |
Pehr
