PmWiki / Auth User
administrators (intermediate)
AuthUser is PmWiki's identity-based authorization system that allows access to pages to be controlled through the use of usernames and passwords. AuthUser can be used in addition to the password-based scheme that is PmWiki's default configuration. AuthUser is a very flexible system for managing access control on pages, but flexibility can also bring complexity and increased maintenance overhead to the wiki administrator. This is why PmWiki defaults to the simpler password-based system. For some thoughts about the relative merits of the two approaches, see PmWiki:ThoughtsOnAccessControl. See also: Cookbook:Quick Start for AuthUser. Activating AuthUser
To activate PmWiki's identity-based system, add the following line to local/config.php: include_once("Ensure that you have set a site wide admin password, otherwise you will not be able to edit SiteAdmin.AuthUser. Note: Older versions of PmWiki (before 2.2.0-beta58) use Site.AuthUser.
PmWiki caches some group and page authorization levels when a page is accessed. For this reason, it is better to include
(If you don't use a custom PageStore class and i18n, include All other recipes should be included after these. Creating user accounts
Most of AuthUser's configuration is performed via the SiteAdmin.AuthUser page. To change the AuthUser configuration, simply edit this page like any other wiki page (you'll typically need to use the site's admin password for this). To create a login account, simply add lines to SiteAdmin.AuthUser that look like: username: (:encrypt password:) For example, to create a login account for "alice" with a password of "wonderland", enter: alice: (:encrypt wonderland:) When the page is saved, the " To change or reset an account's password, simply replace the encrypted string with another The password cannot contain spaces, tabs, new lines, columns ":" and equals "="; on some systems it should contain at least 4 characters. Usernames and passwords are case sensitive, eg. "User" is not the same as "user". Controlling access to pages by login
Pages and groups can be protected based on login account by using "passwords" of the form It's possible to use multiple "id:" declarations and passwords in the quick id:alice,carol To allow access to anyone who has successfully logged in, use " One can also perform site-wide restrictions based on identity in the # require valid login before viewing pages
You can change the
Organizing accounts into groups
AuthUser also makes it possible to group login accounts together into authorization groups, indicated by a leading "@" sign. As with login accounts, group memberships are maintained by editing the SiteAdmin.AuthUser page. Group memberships can be specified by either listing the groups for a login account (person belongs to groups) or the login accounts for a group (group includes people). You can repeat or mix-and-match the two kinds as desired: @writers: alice, bob
carol: @writers, @editors
@admins: alice, dave
Then, to restrict page access to a particular group, simply use " Excluding individuals from password groups
Group password memberships are maintained by editing the SiteAdmin.AuthUser page. To specify a password group that allows access to anyone who is authenticated, you can specify: @wholeoffice: * If you need to keep "Fred" out of this password group : @wholeoffice: *,-Fred To allow all users except Fred to change page attributes, for example, you can add to config.php : Getting account names and passwords from external sources
The AuthUser script has the capability of obtaining username/password pairs from places other than the SiteAdmin.AuthUser page, such as passwd-formatted files (usually called '.htpasswd' on Apache servers), LDAP servers, or even the local/config.php file. Passwd-formatted files (.htpasswd/.htgroup)
Passwd-formatted files, commonly called .htpasswd files in Apache, are text files where each line contains a username and an encrypted password separated by a colon. A typical .htpasswd file might look like: alice:vK99sgDV1an6I
carol:Q1kSeNcTfwqjs
To get AuthUser to obtain usernames and passwords from a .htaccess file, add the following line to SiteAdmin.AuthUser, replacing "/path/to/.htpasswd" with the filesystem path of the .htpasswd file: htpasswd: /path/to/.htpasswd Creation and maintenance of the .htpasswd file can be performed using a text editor, or any number of other third-party tools available for maintaining .htpasswd files. The Apache web server typically includes an htpasswd command for creating accounts in .htpasswd: $ htpasswd /path/to/.htpasswd alice
New password:
Re-type new password:
Adding password for user alice
Similarly, one can use .htgroup formatted files to specify group memberships. Each line has the name of a group (without the "@"), followed by a colon, followed by a space separated list of usernames in the group. writers: carol
editors: alice carol bob
admins: alice dave
Note that the groups are still "@writers", "@editors", and "@admins" in PmWiki even though the file doesn't specify the @ signs. To get AuthUser to load these groups, use a line in SiteAdmin.AuthUser like: htgroup: /path/to/.htgroup Configuration via local/config.php
AuthUser configuration settings can also be made from the local/config.php file in addition to the SiteAdmin.AuthUser page. Such settings are placed in the $AuthUser array, and must be set prior to including the authuser.php script. Some examples: # set a password for alice
$AuthUser['alice'] = crypt('wonderland');
# set a password for carol
$AuthUser['carol'] = '$1$CknC8zAs$dC8z2vu3UvnIXMfOcGDON0';
# define the @editors group
$AuthUser['@editors'] = array('alice', 'carol', 'bob');
# Use local/.htpasswd for usernames/passwords
$AuthUser['htpasswd'] = 'local/.htpasswd';
# Use local/.htgroup for group memberships
$AuthUser['htgroup'] = 'local/.htgroup';
Configuration via LDAP
Authentication can be performed via an external LDAP server -- simply set an entry for "ldap" in either SiteAdmin.AuthUser or the local/config.php file. # use ldap.airius.com for authentication
$AuthUser['ldap'] = 'ldap://ldap.airius.com/ou=People,o=Airius?cn?sub';
Make sure to include AuthUser below the entry for the ldap server: # Want to use AuthUser so we can use ldap for passwords
include_once("And remember to assign the Security Variables for edit and history (or whatever): #Security Variables set login for edit & history page
# to let anyone edit that has an ldap entry:
LDAP authentication in AuthUser closely follows the model used by Apache 2.0's mod_auth_ldap module; see especially the documentation for AuthLDAPUrl for a description of the url format. For servers that don't allow anonymous binds, AuthUser provides See also Cookbook:AuthUser via Microsoft LDAP Setting the Author Name
By default, PmWiki will use a login name in the Author field of the edit form, but allows the author to change this value prior to saving. To force the login name to always be used as the author name, use the following sequence in config.php to activate AuthUser: include_once("To allow more flexibility, but still enable changes to be linked to the authorized user, one can give the author name a prefix of the
include_once("$FarmD/scripts/author.php");
include_once("$FarmD/scripts/authuser.php");
if ($Author) {
if (strstr($Author, '-') != false) {
$Author = "$AuthId-" . preg_replace('/^[^-]*-/', '', $Author);
} else if ($Author != $AuthId) {
$Author = $AuthId . '-' . $Author;
} else {
$Author = $AuthId;
} else {
$Author = $AuthId;
$AuthorLink = "[[~$Author]]";
The above will allow the user to put in the author name of their choice, but that will always be replaced by that name prefixed with " Removing the "Author" edit field
To force users to edit with their AuthID instead of having a field they can place any name in. This enables administration to keep track of who is doing what better. This line also links the Author name to their Profile. Authorization, Sessions, and WikiFarms
PmWiki uses PHP sessions to keep track of any user authorization information. By default PHP is configured so that all interactions with the same server (as identified by the server's domain name) are treated as part of the same session. What this means for PmWiki is that if there are multiple wikis running within the same domain name, PHP will treat a login to one wiki as being valid for all wikis in the same domain. The easiest fix is to tell each wiki to have use a different "session cookie". Near the top of a wiki's local/config.php file, before calling authuser or other recipes, add a line like:
The XYZSESSID can be any unique name (letters only is safest). See Also
Can I specify authorization group memberships from with local/config.php? Yes -- put the group definition into the $AuthUser array (in config.php): $AuthUser['@editors'] = array('alice', 'carol', 'bob');
Can I have multiple admin groups? Yes, define the groups with I'm running multiple wikis under the same domain name, and logins from one wiki are appearing on other wikis. Shouldn't they be independent? This is caused by the way that PHP treats sessions. See PmWiki.AuthUser#sessions for more details. Is there any way to record the time of the last login for each user when using AuthUser? I need a way to look for stale accounts. Though every setting seems correct, authentication against LDAP is not working. There is nothing in ldap log, what's wrong? Be sure ldap php module is installed ( on debian apt-get install php(4|5)-ldap ; apache(2)ctl graceful ) The login form asks for username and password, but only password matters. Username can be left blank and it still signs in under the account. Is this intentional and if so, can I change it so that the username and password must both be entered? - X 1/18/07 Never mind I think this has something to do with using the admin password. I created a test account and it's working ok.
Make sure you are not entering the admin password when testing the account because, if the password is equal to the admin password, it will authenticate directly through the config.php file and skip any other system. Do note that even with AuthUser activated you can still log in with a blank username and only entering the password. In that case any password you enter will be "accepted" but only passwords which authenticate in the given context will actually give you any authorization rights. Using this capability AuthUser comfortably coexists with the default password-based system. If you want to require both username and password, then you need to set an admin id before including authuser.php:
## Define usernames and passwords.
## Enable authentication based on username.
include_once('scripts/authuser.php');
# $DefaultPasswords['admin'] = crypt('secret');
$DefaultPasswords['admin'] = 'id:carol';
A username and password will then be required before login is successful. Is there any way to hide IP addresses once someone has logged in so that registered users can keep their IP addresses invisible to everyone except administrators? - X 1/18/07 Yes, see solution provided at PITS:00400. Is there a way that people could self-register through AuthUser? You can see HtpasswdForm and AuthUserSignup for two recipes providing this feature. I would like it that after I have AuthUser turned and a user is authenticated to get on my site, that if I have a password put on a particular page or group that they don't get the AuthUser form to show up (username and password), but only the typical field for password? This page may have a more recent version on pmwiki.org: PmWiki:AuthUser, and a talk page: PmWiki:AuthUser-Talk. |
Edit - History - Print - Recent Changes - Search Page last modified on 2012-08-30 18:04 [UTC-7] - 396 views
