PmWiki / Group Headers
authors (intermediate)
Every WikiGroup can have GroupHeader and GroupFooter pages that contain markup that should be included at the beginning or end of each page within the group. This feature is useful for:
To create a group header, just create a new page called The default GroupHeader or GroupFooter can be suppressed on an individual page (such as a group's HomePage) by using the If a generic GroupHeader is used in one wikigroup (say, the Site wikigroup), then the code can be easily duplicated in the GroupHeader of any other group by using
If you want a header or footer to appear when you print a page (action print), simply create a page called You can also set the variable See also How do I set the same header or footer for all pages/groups? The header and footer for each page are controlled by the variables
### If you use Site.SiteHeader and Group.GroupHeader
$GroupHeaderFmt = '(:include {$SiteGroup}.SiteHeader'
. ' basepage={*$FullName}:)(:nl:)' . $GroupHeaderFmt;
### If you use Site.SiteHeader instead of Group.GroupHeader
. ' basepage={*$FullName}:)(:nl:)';
### If you use Site.SiteFooter and Group.GroupFooter
$GroupFooterFmt .= '(:nl:)(:include {$SiteGroup}.SiteFooter'
. ' basepage={*$FullName}:)';
### If you use Site.SiteFooter instead of Group.GroupFooter
$GroupFooterFmt = '(:nl:)(:include {$SiteGroup}.SiteFooter'
Note that single quotes must be used in the lines above. See also the Cookbook:AllGroupHeader recipe. Instead of using an additional page, you could set any wiki text in $GroupHeaderFmt .= "Global message here.";
This page may have a more recent version on pmwiki.org: PmWiki:GroupHeaders, and a talk page: PmWiki:GroupHeaders-Talk. |
Edit - History - Print - Recent Changes - Search Page last modified on 2011-09-10 12:08 [UTC-7] - 409 views
