Recent Changes - Search:
go to the forum
Contents
Site
Help
« feb 2026 · jun 2026 »
    add a calendar item
    PmWiki / Link Variables
    admins (advanced)
    $EnableLinkPageRelative
    When enabled, causes PmWiki to use relative urls for page links instead of absolute urls.
            $EnableLinkPageRelative = 1;
    $PagePathFmt
    This array lists the order in which PmWiki looks for the page that you most likely are attempting to link to. The default is listed below. Look at Cookbook:PagePaths for some ideas.
            array('{$Group}.$1', '$1.$1', '$1.{$DefaultName}')
    $LinkPageExistsFmt
    The (HTML) string to output for links to already existing wiki pages. Defaults to
            <a class='wikilink' href='\$LinkUrl'>\$LinkText</a>
    $LinkPageCreateFmt
    The (HTML) string to output for links to non-existent wiki pages. The default is to add a '?' after the link text with a link to the page edit/create form. Defaults to
            <a class='createlinktext' href='\$PageUrl?action=edit'>\$LinkText</a>
            <a class='createlink' href='\$PageUrl?action=edit'>?</a>
    $LinkPageCreateSpaceFmt
    Same as $LinkPageCreateFmt, but used when the link text has a space in it.
    $LinkPageSelfFmt
    The (HTML) string to output for self-referencing links (i.e. links to the page itself). Defaults to
            <a class='selflink' href='\$LinkUrl'>\$LinkText</a>
    $UrlLinkFmt
    The (HTML) string to output for URL-links that begin with 'http:', 'ftp:', etc. Defaults to
            <a class='urllink' href='\$LinkUrl' title='\$LinkAlt' rel='nofollow'>\$LinkText</a>
    $IMapLinkFmt
    an array of link formats for various link "schemes". Not set as default.
    Examples of custom formats to allow different styling via classes:
    Links to http: standard url links:
             $IMapLinkFmt['http:'] = "<a class='httplink urllink' href='\$LinkUrl'>\$LinkText</a>";
    Links to https: secure pages:
             $IMapLinkFmt['https:'] = "<a class='httpslink urllink' href='\$LinkUrl'>\$LinkText</a>";
    Links to PmWiki: InterMap shortcut:
             $IMapLinkFmt['PmWiki:'] = "<a class='pmwikilink urllink' href='\$LinkUrl'>\$LinkText</a>";
    $InterMapFiles
    An array consisting a list of files and pages containing InterMap entries to be loaded (see CustomInterMap).
    $MakePageNameFunction
    Name of a custom function to replace MakePageName(), which converts strings into valid page names.
    $MakePageNamePatterns
    $MakePageNamePatterns is an array of regular expression replacements that is used to map the page link in a free link such as [[free link]] into a page name. Currently the default sequence is:
        "/'/" => '',                           # strip single-quotes
        "/[^$PageNameChars]+/" => ' ',         # convert non-alnums to spaces
        "/((^|[^-\\w])\\w)/e"
          => "strtoupper('$1')",               # initial caps after spaces
        "/ /" => ''                            # strip spaces
    Note that if you change $MakePageNamePatterns, the documentation links may break. This can be fixed by re-setting $MakePageNamePatterns to the default in local/PmWiki.php.
    $WikiWordCountMax
    The maximum number of times to convert each WikiWord encountered on a page. Defaults to 1,000,000. Common settings for this variable are zero (disable WikiWord links) and one (convert only the first occurrence of each WikiWord).
            $WikiWordCountMax = 0;     # disable WikiWord links
            $WikiWordCountMax = 1;     # convert only first WikiWord
    $WikiWordCount
    An array that allows the number of WikiWord conversions to be set on a per-WikiWord basis. The default is to use $WikiWordCountMax unless a value is set in this array. By default PmWiki sets $WikiWordCount['PmWiki']=1 to limit the number of conversions of "PmWiki".
            $WikiWordCount['PhD']=0;     # Don't convert "PhD"
            $WikiWordCount['WikiWord']=5;  # Convert WikiWord 5 times
            # the following lines keep a page from linking to itself
            $title = FmtPageName('$Title_',$pagename);
            $WikiWordCount[$title]=0;
    $EnableRedirectQuiet
    Enable the quiet=1 parameter for the redirect directive. On publicly edited wikis it is advisable not to enable quiet redirects.
            $EnableRedirectQuiet = 0;     # disable quiet redirects (default)
            $EnableRedirectQuiet = 1;     # enable quiet redirects
    This page may have a more recent version on pmwiki.org: PmWiki:LinkVariables, and a talk page: PmWiki:LinkVariables-Talk.
    Edit - History - Print - Recent Changes - Search Page last modified on 2012-10-25 17:45 [UTC-7] - 651 views
