PmWiki / Markup Expressions
authors (advanced)
The substr
The "substr" expression extracts portions of a string. The arguments are
To obtain the last n characters of a string use ftime
"Ftime" expressions are used for date and time formatting. The generic form is {(ftime "fmt" "when")}
{(ftime fmt="fmt" when="when")}
where fmt is a formatting string and when is the time to be formatted. The arguments can be in either order and may use the optional "fmt=" and "when=" labels. Examples:
The fmt parameter is whatever is given by "fmt=", the first parameter containing a '%', or else the site's default. The formatting codes are described at http://php.net/strftime. In addition to those, '%F' produces ISO-8601 dates, and '%s' produces Unix timestamps. Some common formatting strings: %F # ISO-8601 dates \"2026-03-28"
%s # Unix timestamp "1774754062"
%H:%M:%S # time as hh:mm:ss "23:14:22"
%m/%d/%Y # date as mm/dd/yyyy "03/28/2026"
"%A, %B %d, %Y" # in words "Saturday, March 28, 2026"
The when parameter understands many different date formats. The when parameter is whatever is given by "when=", or whatever parameter remains after determining the format parameter. Some examples: 2007-04-11 # ISO-8601 dates
20070411 # dates without hyphens, slashes, or dots
2007-03 # months
@1176304315 # Unix timestamps (seconds since 1-Jan-1970 00:00 UTC)
now # the current time
today # today @ 00:00:00
yesterday # yesterday @ 00:00:00
"next Monday" # relative dates
"last Thursday" # relative dates
"-3 days" # three days ago
"+2 weeks" # two weeks from now
Note: If you want to convert a Unix timestamp you must prefix with the @. Thus, The when parameter uses PHP's strtotime function to convert date strings according to the GNU date input formats; as of this writing it only understands English phrases in date specifications. The variable strlen
The "strlen" expression returns the length of a string. The first argument is the string to be measured.
rand
The "rand" expression returns a random integer. The first argument is the minimum number to be returned and the second argument is the maximum number to be returned. If called without the optional min, max arguments rand() returns a pseudo-random integer between 0 and RAND_MAX. If you want a random number between 5 and 15 (inclusive), for example, use (rand 5 15).
toupper / tolower
The "toupper" and "tolower" expressions convert a string into uppercase or lowercase. The first argument is the string to be processed.
ucfirst / ucwords
The "ucfirst" expression converts to uppercase the first character of the string, and "ucwords", the first character of each word. The first argument is the string to be processed.
pagename
The "pagename" expression builds a pagename from a string. The first argument is the string to be processed.
asspaced
The "asspaced" expression formats wikiwords. The first argument is the string to be processed.
Nesting expressions
Markup expressions can be nested:
Notes
See also
This page may have a more recent version on pmwiki.org: PmWiki:MarkupExpressions, and a talk page: PmWiki:MarkupExpressions-Talk. |
Edit - History - Print - Recent Changes - Search Page last modified on 2011-10-09 19:02 [UTC-7] - 460 views
