today> Twyndyllyngs Chez Mosc
Rumour: What will bring Clavia to the MusikMesse?
Page 12 of 13 [324 Posts]
Goto page: Previous 1, 2, 3, ..., 10, 11, 12, 13 Next
3phase
G2 patch files: 141
PostPosted: Wed Apr 04, 2007 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Although OTOH, thank christ that most of us are up to broadband status, because sending a pch3 file including a sample (or many) could turn out to be one logistical nightmare! Shocked
Which is an issue for that new wave thingy as well BTW, either the patch goes without the samples and it makes no sense (if the samples are used of course) or the samples are in and the patch is huge. Clavia didn't know yet how to handle that.
That shouldnt be a problem... a sample module in a modular should be a ram module that can be read out and triggered within the patch..the content of this ram module dont has to be part of the patch.
It eitehre gets realtime recorded like in the delay lines now..exept that it stays in the machine memory on that location or managed via usb...
lets say you have 128 sample locations... you dum them seperatly or maybe a special safe option that dumps the patch and associated samples to the editor...
But the patch itself should be just the structure of modules as it is now...
PostPosted: Wed Apr 04, 2007 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
v-un-v wrote:
... nitty-gritty ...
Well, what does that mean?
I'm not a native speaker...
Wout
Details. I think the expression has a implication of the details being somewhat unstructured and informal and probably practical?
PostPosted: Wed Apr 04, 2007 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Yep of course there's a bigger picture and you Wout (and Rob) are the closest to Clavia's secret empire Wink
ACHTUNG!
PostPosted: Wed Apr 04, 2007 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree; live sampling is a lot of fun once you get the hang of it and of course sample manipulations can be a great effect as a part of a larger patch.
The sad fact is that most consumers expect samples to work like presets and be ready-made for them, some chunk of the market for the Modulars doesn't even make it's own patches.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 04, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it would be nice to have both options for the G2.
Attaching a small sample to a patch for portability, and having a file system object that can contain multiple samples or tables, accessible to any module.
If you use those Linn drum samples a lot, you wouldn't want to have to have a copy in each performance.
Audio files: 235
PostPosted: Wed Apr 04, 2007 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nitty-gritty means the tiny little details.
http://dictionary.reference.com/browse/nitty-gritty
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Apr 04, 2007 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I almost gave away too much!
/Dasz
Fozzie
G2 patch files: 49
PostPosted: Thu Apr 05, 2007 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
Question you mean in the phase-osc thread or what?
dorremifasol
G2 patch files: 49
PostPosted: Thu Apr 05, 2007 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I wonder...
What's the difference between the Nord Wave and using the G2's input as a waveform oscillator with a sampler attached to it (triggering the notes at the same time)?
Albert
suthnear
PostPosted: Thu Apr 05, 2007 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Aside from convenience, my main interest would be in being able to create new sounds via the kind of audio rate transformation shown in the messe video. I'm holding onto a waldorf q because of how good its (limited, in that there are only two of them) wavetable oscillators sound when frequency modulated, but I often wish I could expand its palette. Modulating a sample (its phase, frequency, start/end points, loop length, etc) using the g2's modulators within its freely configurable environment would be incredible.
None of this would be possible if the audio was being piped in from a sampler...
monobass
G2 patch files: 12
PostPosted: Thu Apr 05, 2007 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly.
As for the Wave, 10 years ago it would have been very exciting, but it really doesn't stand out in the overall market based on what Clavia have told us so far.
Steve
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Apr 05, 2007 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a product idea and began posting it (as it is related to this topic a little bit), thus I stopped. but left a trail ...
/Dasz
PostPosted: Thu Apr 05, 2007 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Come on guys! This is a bit like trying to reinvent the wheel!! Holger Czukay once said; "we should celebrate what's already here rather than continually striving for the next and better" (from an interview with him yonks ago- which was probably described in a slightly different way! Embarassed )
Has our creativity completely eluded us?
Perhaps we should burn our synthesizers and return to the simple things like learning to play the violin?? Shocked Laughing
ACHTUNG!
3phase
G2 patch files: 141
PostPosted: Thu Apr 05, 2007 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
dorremifasol wrote:
I wonder...
when you have a ram table its not just trigering a sample..you can process the readout position and do all kind of things .. backward ..forward..slicing... grains... an external sampler you just can trigger...
dorremifasol
G2 patch files: 49
PostPosted: Thu Apr 05, 2007 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
But... will those things be possible with the Nord Wave? I haven't seen many controls for the waveforms in the suface... aside from the usual ones.
Albert
monobass
G2 patch files: 12
PostPosted: Thu Apr 05, 2007 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
um. yeah. You seem to be having a circular argument with yourself here Smile
Steve
Audio files: 235
PostPosted: Thu Apr 05, 2007 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
But he is winning... Very Happy
monobass
G2 patch files: 12
PostPosted: Thu Apr 05, 2007 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm rooting for the underdog.
Steve
NoiseLab
PostPosted: Thu Apr 05, 2007 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Although it's not interesting for me to go for a Nord-synth. They could bring the 'Lead' concept to a next level with an equivalent of Focusrite's Liquid technology... so you have convolution for synths!!! Naming the 'NordChameleon'. Shocked
I think that will perfectly fit in Clavia's "performance philosophy concept"...
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Apr 05, 2007 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
adding wave sequencing/wave-interpolation-morphing-feedback would also be cool ... but this requires more than one osc dedicated to samples and wavetables and a few more "modules" to implement inside the wave ...
/Dasz
3phase
G2 patch files: 141
PostPosted: Thu Apr 05, 2007 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
no..such thing are the domain of max msp and reaktor... in hardware maybe kyma is a match..but thats about it... ..
its more a modular/patch thing... so whenever there is a nord modular with sampling capabilitys we would see such table things...
the nord wave is a sampler synth hybrid in a small package...not the bleeding edge sound-designtool...ratheer a classical synth with some extra possebilitys...
iPassenger
G2 patch files: 78
PostPosted: Fri Apr 06, 2007 2:33 am    Post subject:
Subject description: Sorry off topic.
Off topic:
Been reading this topic for a while now, n then recently realsied I didn't even know what this Kyma thing was. So had a look on google n checked it out. My word that is some machine.
iP (Ross)
PostPosted: Fri Apr 06, 2007 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh? With some efford I can probably think of 20 instruments where this is trivial to do.
Studio-ES
PostPosted: Sun Apr 15, 2007 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Granular hardware samplers? V-Synth? Varios won't do granular. The Akai samplers won't. The E-mu's won't either. Don't know about Kurzweil samplers. You could set the sample start and stop times very close to each other and modulate both parameters to get a 'granular-esque' effect on most samplers, but's it not quite the same.
As far as 'Splicing', the Ultra E-mu's and Varios will do that. Yamaha too but it's very limited on those.
I'd be interested in hearing about hardware samplers that can do these tricks (especially granular).
Thanks.
PostPosted: Sun Apr 15, 2007 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, sorry. MAX and the Kyma are computer based (even if the kyma has a hardware component it still depends on it) so I thought we were taliking software for detailed/arbitrary buffer controll (including grains).
For hardware based grains I think you'd need a Ensoniq sampler with that alternative OS you can buy online. For that sort of thing hardware (and most software) kinda sucks, part of the problem is that you need so much detailed controll from high-rez interfaces so a good setup will depend heavily on parsing live input so you'll need something programable.
Strangely; for detailed realtime controll of bufferplayback few hardware things come close to one of the first samplers; the S612 has hardware sliders for controll of loop-points.
Alternately you could look into pitch-shifters. Pitch-shifter use a technique that's like a very specific (and limited) implementation of grains. The older the pitch-shifter and the more extreme the settings the more it'll have that typical grainy sound.
