M185 sequencer Project - NEW PCB VERSION
Page 8 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, ..., 44, 45, 46 Next
neandrewthal
PostPosted: Fri Sep 05, 2008 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
krisp14u wrote:
ivehavesent you a PM but i will put down hear too
1 full set of switchs for me
Have you started an MOTM format layout for this yet?
Peake
PostPosted: Fri Sep 05, 2008 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am thinking that this module can be used as a burst generator, ala Ken Stone's module. If it's set to 1 stage only, you can obviously have up to 8 pulses occur upon each cycle or external trigger. If it's changed via analog addressing (random voltage as an input, changed via each beat's trigger), you could assign different numbers of pulses per stage and get randomized selection...or if stepped, a certain number of pulses for each of the 8 stages, cycling... Could be very interesting. Even moreso with a pair (five fast on one voice, slightly slower 3 on another voice, to create thick clap sounds, etc.). I can't wait to run them through a slew to create complex envelopes...
And am I correct that the pulse output duty cycle is VC?
ryktnk
PostPosted: Sat Sep 06, 2008 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
loopcycle wrote:
i read through the thread again. now why do people want to use the slide switches instead of rotaries? i cant figure it out. it seems like more of a hassle than anything?
Yes, they are a bit tricky, as to panel mount you
need square cut-outs.
Hello
Sounds like an interesting use for the module.
RE " pulse output duty cycle" if you mean the width of the pulse
then yes this is voltage controllable, but only if your'e using the
internal clock.
From reading your post it soundsl like for the clap idea would
you want it to be a one shot sequence or would you open/close the
sound with an envelope ? [sadly there is no one-shot option on this seq]
-ryk
norman phay
PostPosted: Sat Sep 06, 2008 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you put me down for 20 x 8-way and 22 x 4-way please, ryk. Many thanks. That should do for both sequencers, and give me a couple of spares too.
norman phay
PostPosted: Sat Sep 06, 2008 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
The little slide switches look to be better to use to me, by which I mean I'll be wanting to tweak these in real time and the sliders work better for me for that than rotaries. They also have a slightly smaller panel footprint. As I'm going to be designing a scaeffer panel for these, the cutouts for them won't be a problem.
Luka
PostPosted: Sat Sep 06, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
im going to have to pull out of the potential switch group buy. i had a reality check. all the group buys are catching up on me, spread too thin and not focussing my cash on ordering parts to building my current stuff.
sorry bout that.
problemchild
melbourne australia
slo
PostPosted: Sat Sep 06, 2008 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I've already said I would like one set of switches, but just to clarify, I would like 1 set for 1 sequencer, (both types of switches)
Thanks for this
George
Peake
PostPosted: Sat Sep 06, 2008 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoops, no Start/Stop gate inputs- I talked before I confirmed. I'm sure that something satisfactory can be made to happen along these lines, or that it will still provide new ideas because of its uniqueness...Not a problem, still a great project!
krisp14u
PostPosted: Sun Sep 07, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
neandrewthal wrote:
1 full set of switches for me
Not yet I’m a little snowed under with other stuff at the moment
But when I do I will post it up hear unless some one else comes up with something cool in the meantime
Paul Darlow
www.krisp1.com
ryktnk
PostPosted: Sun Sep 07, 2008 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Well yes, you could wire up an 8-way switch from the LEDs 2-8 anodes, and then send this to the R/S input on the board [perhaps with a diode]
With this you would get a one-shot feature, where the seq would
stop when it got to the selected stage.
Leave LED1 anode to switch unconnected, this would then give you
a "one-shot" off position, and then subsequent one-shot 2,3,4,5,6,etc steps
The R/S input is a flip-flop toggle, so you could use a gate input to
fire this, but obviously it would just set the seq to the opposite of current
state, IE if running it would stop, if stopped it would run.
Hope this helps.
-ryk
Dego
PostPosted: Sun Sep 07, 2008 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I can take switches for 1 seq, please Smile
Peake
PostPosted: Sun Sep 07, 2008 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
Hope this helps.
-ryk
Yes, it does help! Thanks for the tip.
ringer
PostPosted: Sun Sep 07, 2008 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ryktnk,
My front panel design is almost done, missing are the frequency, stage count and stage mode markers. I am laying out the motherboard pcb for all the front panel hardware to avoid all the flying leads. Would it be possible to have the footprint and dimensions for switches, thanks.
Regards,
Ringer
ryktnk
PostPosted: Mon Sep 08, 2008 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
ringer wrote:
Here is a preview of the front panel.
Hello Ringer
That is looking really nice, very cool.
Here are the switch dimensions diagrams.
I think the spacing for the switches is bigger than planned . . .
The height of the "knob ?" is as follows:-
8-way 8mm tall
4-way 7mm tall
I would recommend waiting until you get the switches
before etching !
-ryk
 Filesize:  64.38 KB
 Viewed:  295 Time(s)
 Filesize:  75.22 KB
 Viewed:  330 Time(s)
julian
PostPosted: Tue Sep 09, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi there,
i wouldnt mind a set of switches also, (for one board)
thanks
lexvortex
PostPosted: Sun Sep 14, 2008 10:24 am    Post subject: 2nd run Reply with quote  Mark this post and the followings unread
Any chance that you will be doing a second run of PCBs and PICs?
Thanks,
Danno Gee Ray
PostPosted: Sun Sep 14, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be in for one sequencer's full set of switches.
djthomaswhite
PostPosted: Mon Sep 15, 2008 3:11 pm    Post subject: Rotary Switches Reply with quote  Mark this post and the followings unread
Would there be a preference between "Shorting" and "Non-Shorting" switches?
Also, in the wiring diagram do the pins of each step connect back to Step 1, or to the previous step... and to which pins? Is it pin-to-pin chain or to other pins? The diagram is not too specific here. Thanks!
Tom
Thomas
www.naturalrhythmmusic.com/diy.html
ryktnk
PostPosted: Mon Sep 15, 2008 5:14 pm    Post subject: Re: Rotary Switches Reply with quote  Mark this post and the followings unread
Tom
Hello
Perhaps shorting might be better, but its probably
not too important, unless you managed to switch the switch
at the exact milli-second the PIC was reading the switch data.
Sorry for the confusion about the wiring, I maybe should
draw new diagram.
Do you mean the pins on the swithces ?
If yes then:-
All the switches are connected in parallel, with the voltage divider
resistors at one end, EXCEPT the "pole" pin of each switch which
is connected to the POT connectors via a diode [see diagram]
Hope this helps.
-ryk
klo
PostPosted: Mon Sep 29, 2008 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
please,
make a second order.
im real horny of this sequencer and im not alone!!!!
del_poolp
PostPosted: Wed Oct 01, 2008 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
+1000000000
ryktnk
PostPosted: Fri Oct 03, 2008 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hello
ok point taken.
if there is enough interest, and when the £ is
worth something again I will try and get some
more PCBs and PICs.
PS Has anybody finished building one yet ?
-ryk
del_poolp
PostPosted: Fri Oct 03, 2008 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, good news Wink
If people cannot finish, I can buy their PCB and their PIC for the same price Wink
Just one question, its work on +/- 12v (eurorack) ?
Luka
PostPosted: Fri Oct 03, 2008 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
mine are deep in the backlog
and will be for some time unfortunately
problemchild
melbourne australia
henrikgo
PostPosted: Fri Oct 03, 2008 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
If there's another run, I'm in for two kits/PCBs, prepay is no problem!
