M185 sequencer Project - NEW PCB VERSION
Page 15 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, ..., 44, 45, 46 Next
xpmtl
PostPosted: Wed Aug 19, 2009 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Would take 2 sets of switches if it happens (already have the pcbs Smile )
http://sdiy.xpmtl.net
sduck
PostPosted: Wed Aug 19, 2009 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Already have boards, but will definitely buy switches if they become available.
wmonk
Audio files: 15
PostPosted: Wed Aug 19, 2009 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for one board and 2 sets of switches Smile
delayed
PostPosted: Wed Aug 19, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
how much will the switches run? and when is the cut off date?
cyphersum
PostPosted: Wed Aug 19, 2009 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 sets of PCB+PIC+switches.
Thanks.
:brian
adambee7
PostPosted: Thu Aug 20, 2009 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
If this happens ill be up for 2xpcbs and pics and switch sets. nice. Very Happy Very Happy
julian
PostPosted: Thu Aug 20, 2009 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea who the author was, as someone emailed me the file, but is the attatched panel the correct (and final) layout for 5u units?
The .fpd file is titled - m_185_ver32_192[1].fpd
Thank, Julian
 Filesize:  158 KB
 Viewed:  378 Time(s)
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
krisp14u
PostPosted: Thu Aug 20, 2009 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
It was originally done by lexvortex who sent it to me to tart it up a little and I sent it back
I know lexvortex had one made so maybe ask him how it worked out
there are some photos in the thread somewhere try page 13
Paul Darlow
www.krisp1.com
a100user
PostPosted: Thu Aug 20, 2009 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take pcb's and switches for two sequencers
Ta
Edit - PIC's too Wink
djthomaswhite
PostPosted: Thu Aug 20, 2009 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
How much did the switches go for last time?
Thomas
www.naturalrhythmmusic.com/diy.html
ryktnk
PostPosted: Thu Aug 20, 2009 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
The switch prices are £15 for one set [9 x 8way + 10 x 4way]
Thanks
-ryk
ach_gott
PostPosted: Thu Aug 20, 2009 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for four of each (PCB+PIC, Switch set). Glad to hear this is going forward!
julian
PostPosted: Thu Aug 20, 2009 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Im just in discussion with Dave (Lexvortex) about the MOTM format panel design -
He has advised me -
"Everything fits well on the panel, the only things to be aware of are whether you are using V1 or 2 of the software, one requires the CV in and the other does not and would require a name change under CV control section. also the LED size is not MOTM spec."
He added -
I would also bring the writing over the buttons down closer to the buttons and for the clock in out I would pull that up a bit, but those are just cosmetic things that are a personal preference.
magman
PostPosted: Thu Aug 20, 2009 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like I'm going to have to join this queue as well, as if my project stack wasn't big enough already.
Put me down for two sets of PCB's, PIC's and switches please.
Regards
Magman
robotfunk
PostPosted: Thu Aug 20, 2009 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be up for 4x PCB + PIC
ericcoleridge
PostPosted: Thu Aug 20, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ryk,
I will take one set of switches.
One set contains all switches for one module--yes?
Will you PM when you're ready to take payment? It can be hard to follow exactly what's going on in a long thread like this.
nerdware
PostPosted: Thu Aug 20, 2009 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in one PCB, one PIC, and one set of switches.
Funky40
G2 patch files: 5
PostPosted: Thu Aug 20, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take two sets of switches plus some spare + 2 PCBs ( if switches becomes available) , not shure if i need the Pics or not.
I'll make the definitve Order when it is clear if switches are available too.
thanks ryk.
johans121
PostPosted: Fri Aug 21, 2009 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
2 PCB/PIC/Switches for me please....
Don't feed me Indian, you WILL regret it!
-Jim
diablojoy
PostPosted: Fri Aug 21, 2009 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
since it seems the switches will be available [thank you for that] it will be
4 boards 4 pics and also 4 sets of switches for me too thanks
reflux
PostPosted: Sat Aug 22, 2009 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm definitely in for one Pcb/Pic/Switches. Thanks
bubblechamber
PostPosted: Sat Aug 22, 2009 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll take 1 pcb/pic and 2 sets of switches
thanks.
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
delayed
PostPosted: Sun Aug 23, 2009 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
i would like one full set board/pic/switches
dingebre
PostPosted: Sun Aug 23, 2009 2:26 am    Post subject: Which Switches and an FPD file Reply with quote  Mark this post and the followings unread
A quick question, the panel designed by lexvortex included a slider switch for the stages, but the panel by ryktnk has a rotary for this switch. Is a slider included in the switch parts kit for the stages switch? I'm trying to design a Frac/Euro panel and would like to know.
On that note, I'm contributing the Euro and Frac panels as a WIP. The Frac is essentially identical except for the panel size. The Euro is 42 HP, but the Frac had to be in a 6 module wide panel (9 inches). You can take the Frac or Euro, double them, and fit them in a full 19 inch wide panel, too.
The panels are derived from lexvortex's panel. Thank you very much for the panel! It was an excellent starting place and made the job quite easy. Basically, I just flipped it by 90 degrees and moved/rotated a few things.
Please be warned, these panels likely need tweaking; hole size for pots (I'm using the 12 mm Alpha with a 7mm + a bit hole size), the LED's may need to be moved a bit depending on the LED choice, etc. And, since I haven't built it or mocked one up yet, I can't guarantee clearances. that said, hope it helps someone.
(Added RYK Logo: RYK )
David
 Filesize:  78.98 KB
 Viewed:  257 Time(s)
Blacet M185.fpd
 Filename:  Blacet M185.fpd
 Filesize:  2.83 KB
 Downloaded:  223 Time(s)
Euro M185.fpd
 Filename:  Euro M185.fpd
 Filesize:  2.85 KB
 Downloaded:  276 Time(s)
dingebre@3dphysics.net
julian
PostPosted: Sun Aug 23, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I have just cut a 5u (MOTM format) panel for my own system, on David Afonso's design, taking into account his proposed changes to the lettering position etc. mentioned previously.
The result, produced with Dave's permisison, is below -
This panel is for the V1 software, in addition to having custom hole sizes for 3mm leds, without a skirt. I personally prefer the non-infilled panels, hence the lack of infill in the photo.
I will cut production panels with standard LED hole sizes, and for the V2 software's panel components.
The cost would be GBP £45 per panel
The pricing is exclusive of shipping / card fees, but inclusive of all EU taxes (unfortunatly not refundable for export orders)
Panels will be produced in batches, and shipped from the UK.
If you are interested please pm me directly with the following information -
*name + email address
*what country youre in
*how many panels (5u, v2 design) you would like
*how you would like to pay (sterling / euro transfer @ 0% or credit card @ 4.4%)
If there is sufficient interest, i may open this offer to euro / frac panels too.
