ASM-2
Page 4 of 8 [192 Posts]
PostPosted: Sun Nov 12, 2006 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Both VCOs and VCF1 wired up and running really well.
It turns out that I had some old component values and a couple more things to sort out with this "prototype" board I got. I've tracked it all down and sorted it out. I definately feel like I'm learning more and more as things progress.
I've got to get some modulation sources happening!
WOW !!!! The project is LOOKING REAL GOOD !!! I have to read all the messages in this thread to get the all the details down! I love the panel also!
Bill
VCO
PostPosted: Sat Nov 25, 2006 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It looks really nice! I'm in the middle of building an ASM-2 Wizard myself and it's a lot of fun. Very Happy
interferenz
PostPosted: Fri Dec 08, 2006 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello to everybody!
I found this thread so I have registered this forum and now I'm a new member. Smile.
I want to build a modular analog synth by myself and have found the asm-2. I'm not sure whether it's the right system to start with.
I'm a beginner in DIY and I think it is more difficult to build up a system containing all modules on a single PCB than to build up single modules.
But the ASM-2 seems to be a nice system with a fair price tag.
What's about the voltage levels of the ASM-2. Is it possible to add modules from other manufactors to the system ?
Are there any sound examples online ?
greetings
Volker
PostPosted: Fri Dec 08, 2006 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it will be fine for patching into other modular gear. The CVs are normalised to 0 -> 10V and the signals are -5 -> +5V. I haven't finished mine yet (not far to go) so I haven't done any sound samples yet.
It is a big project, it has taken me a number of months of solid work. Single modules are good too. I like the idea of having a complete setup which I can then add extra stuff to later, if I want.
As with any DIY electro-music type project, it's the case and peripheral finishing touches which take a bit of thought and extra work. Soldering up the PCB only took a week.
Maybe start off with a WSG or SoundLab if you haven't got a lot of experience.
Oh, and welcome to electro-music.com! Smile
interferenz
PostPosted: Fri Dec 08, 2006 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Dear Uncle Krunkus Smile,
I think I will order a PCB and the documentation to get a besser felling what will be going on If I try to build the system.
There is the ASM-2 Wizzard for which they offer a nice front plate, this could save a lot of work I think and it looks nice also.
Anyway I am looking forward to your sound samples of the ASM-2.
Bye
Volker
PostPosted: Sat Dec 09, 2006 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome to get a copy of my "Sorcerer" front panel artwork as well, if you want it. It's kind of half way between a Genie and a Wizard. Mostly pre-patched, but with a selection of patch points across the bottom which you could configure to your own personal taste. You can find the pic of it earlier in this thread. I'd send a high res version for you to use though.
interferenz
PostPosted: Wed Dec 13, 2006 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I have ordered a soundlab kit to keep things simple in the beginning and to improve soldering knowledge.
After the hopefully success with it I will get the ASM - 2.
staying tuned..
Volker
PostPosted: Wed Dec 13, 2006 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Soldering practice is always a good thing. Like I said though, the best lesson you'll learn for your ASM2 is how you house your SoundLab, and how you finish it off. Patching options, panel artwork, controller mounting etc.
PostPosted: Mon Dec 25, 2006 5:21 am    Post subject: First sample Reply with quote  Mark this post and the followings unread
Here's the first sample of the ASM-2 Sorcerer. Standard kind of drone sound: - S&H on 2 VCOs into 2 VCFs panned L&R.
I made it by Christmas! Yeah! Very Happy
I've still got the RingMod, ADSRs and the LFOs to go, but it's pretty inspiring to get this far. I've also got to do all the adjustments as well.
Sorry, the sample was lost in the crash of Aug'07 Sad
questionable
PostPosted: Mon Dec 25, 2006 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
congrats! it's making noise! i've still got a few more modules to wire up, and then have to sort out the power supply issue.
Sounds Questionable
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Dec 25, 2006 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great.
The last ASM2 samples posted were also very nice, like a Virus demo (I mean that in a good way).
This seems to be a very good quality product.
Scott Stites
Audio files: 96
PostPosted: Wed Dec 27, 2006 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats - a bouncing baby ASM-1. Sounds like a synth to me. Very Happy
PostPosted: Wed Dec 27, 2006 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
No,... Rolling Eyes
The Sorcerer is an ASM-2! Cool
I've been sidelined by a fault in a Behringer Eurodesk MX 3282A. (Paying job)
So the Sorcerer will have to wait.
PostPosted: Mon Feb 05, 2007 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey everybody!
Just a quick update to let you all know that I'm back to doing a little bit of wiring on the Sorcerer every night. The front panel is fully dressed, and I only have the LFOs and ENVs to go for the basic wiring to be finished. (A solid day's work would do it easily. I just don't get whole days to myself anymore! Rolling Eyes )
I'll take some photos (and some samples) soon.
PostPosted: Mon Feb 05, 2007 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey everybody!
Very good. That is quite the LARGE project! It's really coming along. I love the panel! I look forward to the pictures UK! Very Happy
"Divide and Conquer" as they say ! Doing the job in part acts will result in a higher quality electronic instrument that will last many years!
Nice work my friend Very Happy
Bill
PostPosted: Tue Mar 13, 2007 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
All basic wiring finished.
Front panel mostly dressed.
All modules functioning.
Now, an extensive period of testing and adjusting.
 Filesize:  311.75 KB
 Viewed:  399 Time(s)
 Filesize:  260.87 KB
 Viewed:  430 Time(s)
 Filesize:  285.79 KB
 Viewed:  439 Time(s)
goodrevdoc
PostPosted: Tue Mar 13, 2007 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW! That is truly awesome Uncle K! Also, very neat job on the wiring.
-jusitn
Audio files: 234
PostPosted: Tue Mar 13, 2007 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good work, Andy. Very good looking craftsmanship.
Funky40
G2 patch files: 5
PostPosted: Tue Mar 13, 2007 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks very very nice !
Scott Stites
Audio files: 96
PostPosted: Tue Mar 13, 2007 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorcerrific!
PostPosted: Wed Mar 14, 2007 12:31 am    Post subject: The Square Dance Reply with quote  Mark this post and the followings unread
Here it is just noodling along by itself. No effects. LFOs are modulating each other and PWMs, Inverted VCF to enhance stereo effect, bit of RingMod mixed in etc.
Still haven't done any adjustments, so the levels, wave shapes and DC offsets are probably all over the place. Still, it seems to be enjoying itself. It did this for over 10 mins before accidently stalling both LFOs. Man I wish I had recorded that!
Sorry, this sample was lost in the crash of Aug'07. Sad
Audio files: 234
PostPosted: Wed Mar 14, 2007 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great. Congrats. Reminds me a little of Bernard Herman's score for The Day the Earth Stood Still. Very Happy
Audio files: 309
PostPosted: Wed Mar 14, 2007 10:01 am    Post subject: Re: The Square Dance Reply with quote  Mark this post and the followings unread
That's typical for noodles, they work best when not being recorded Very Happy
A nice sounding synth !
jimh54
PostPosted: Fri May 18, 2007 3:36 pm    Post subject: I want one Reply with quote  Mark this post and the followings unread
I ordered a board ant the parts kit. He still has not sent the order invoice. anybody know if he's still selling these?
disregard. I heard from him just now.
Where can I get an aluminum case like that?
PostPosted: Sat May 19, 2007 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi jimh54,
don't hesitate to drop by and ask any questions you need answers to. Put them on this thread rather than PMing, so others can refer to them if need be.
I got one of those cases from Jaycar Electronics here in Australia, but didn't end up using it. I've gone all rack mount now. They ship OS if you can't find one nearby.
http://www.jaycar.com.au/
