today> Twyndyllyngs Chez Mosc
M185 sequencer Project - NEW PCB VERSION
Page 6 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 44, 45, 46 Next
ryktnk
PostPosted: Thu Aug 21, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
PM's are now out !
thanks
-ryk
neandrewthal
PostPosted: Fri Aug 22, 2008 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't receive a PM. Did you get my order for 2 boards?
etaoin
PostPosted: Fri Aug 22, 2008 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here. My order was confirmed by PM, but I didn't get the payment PM...?
http://www.casia.org/modular/
ryktnk
PostPosted: Fri Aug 22, 2008 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Sorry guys, still a few more to send.
-ryk
vtl5c3
PostPosted: Fri Aug 22, 2008 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Ugghh... How did I miss this thread?!?
If there's a second run or a cancellation, I'd love one of these boards + PIC.
ryktnk
PostPosted: Fri Aug 22, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I can put you on the list in case some of the reservations
don't get bought.
thanks
-ryk
ericcoleridge
PostPosted: Fri Aug 22, 2008 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not 100% sure, but I thought I had reserved one also. Didn't receive PM.
lexvortex
PostPosted: Sat Aug 23, 2008 11:34 pm    Post subject: I'll take one Reply with quote  Mark this post and the followings unread
I'll take one PCB if there are any cancellations or another run of boards Smile
Thanks,
ryktnk
PostPosted: Tue Aug 26, 2008 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
All orders that have been paid are now posted [in theory]
3-5 days Europe
5-7 days Outside Europe
Here is the finished documentation for the project [hope it makes sense]
Good luck with the solder iron, and some
nice panel fronts !
-ryk
M185_BOM.pdf
 Filename:  M185_BOM.pdf
 Filesize:  59.06 KB
 Downloaded:  731 Time(s)
M185_construction_notes.pdf
 Filename:  M185_construction_notes.pdf
 Filesize:  329.26 KB
 Downloaded:  878 Time(s)
M185_panel_wiring.pdf
 Filename:  M185_panel_wiring.pdf
 Filesize:  330.4 KB
 Downloaded:  712 Time(s)
M185b_manual.pdf
 Filename:  M185b_manual.pdf
 Filesize:  56.83 KB
 Downloaded:  1251 Time(s)
henrikgo
PostPosted: Tue Aug 26, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
If possible I'd also like a PCB & PIC please.
303monkey
PostPosted: Wed Aug 27, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Ryk
I just seen mention of some 8 way switch's metioned on an earlier post. Do you still have any to go with my order?
ryktnk
PostPosted: Wed Aug 27, 2008 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
At the moment all the 8-way switches have been reserved, sorry.
-ryk
jaidee
PostPosted: Thu Aug 28, 2008 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Oops - I saw the reference to the possibility of some 8 way slide switches being made available but hadn't realised that they were actually up for grabs.
I've dones some searching on the net and have found a number of Chinese manufactures of 8 way slide switchs but no obvious retail source.
Is ryktnk or anyone else able to offer pointers to a retail source of 1p8t and 1p4t slide switches (i.e. a source which will sell in small quantities and accept credit card payment)??
And by the way - I've received my board and PIC; thanks to ryktnk for making all this happen!
norman phay
PostPosted: Thu Aug 28, 2008 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I got the package yesterday, many many thanks, I'm really looking forward to getting these built up.
Exc documentation too!
If anyone is group-buying the special slide switches, count me in, like JD I didn't realise there was some on offer.
ryktnk
PostPosted: Thu Aug 28, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I got mine in China last year, there are a couple of companies
that make them, but the MOQ is probably 200 or more.
If lots of people are interested maybe I can try and get some
more.
Panel wise the rotary switches are much easier to work with
because the slide switches all need precision rectangular cut-outs
which means CNC = expensive.
The slide switches have screw holes at each end.
-ryk
endif
PostPosted: Thu Aug 28, 2008 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not necessarily CNC, could just drill a pilot hole and then route it out, then file off the edges.. but unless you have a nice router and the skills to go with it, not very precise.
~ !J!
http://www.endif.org
http://www.crunchpod.com
http://www.myspace.com/endif
Danno Gee Ray
PostPosted: Fri Aug 29, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Got my board and chip today. looks great.
Thanks
303monkey
PostPosted: Sat Aug 30, 2008 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Recieved my boards and pic's too.
Cheers ryk
panele
PostPosted: Mon Sep 01, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
pcb and pic arrived today, looks very good
thank you for this project Wink
Peake
PostPosted: Mon Sep 01, 2008 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
.100 SIP power connection? I approve. Can't wait.
mono-poly
PostPosted: Mon Sep 01, 2008 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah i wan those knobs man and i can use a lot.
so i guess an order off a few 100 should be realized easy.
philpeery
PostPosted: Mon Sep 01, 2008 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Man, how did I miss this one! If any orders get canceled, I would be up for 2 boards + 2 PIC's. If you do a second run, please put me down for the same number. Wow, this project looks really cool, I am green with envy...!
Phil
gubbeper
PostPosted: Mon Sep 01, 2008 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you ever do a second run I would like one board with a Pic please! Smile
/Per
/Per
I'm on Twitter
Luka
PostPosted: Mon Sep 01, 2008 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived in melbourne
thanks rky
look forward to making this
problemchild
melbourne australia
XeroX
PostPosted: Tue Sep 02, 2008 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks ryk,
the boards arrived today.
so i will build them up, so fast as possible Wink
but i could not find the Switch 2P4T or 1P4T in germany Sad
