sneakthief
Posted: Fri Sep 22, 2006 8:12 am Post subject:
Uncle Krunkus wrote: | How are the references you put into them derived? Did you use the +/-10V coming out of the LM329s | ..snip...
yes, that's exactly what i did. i have to admit, the +/-10v reference hasn't been tweaked yet: it's at +10.43v and -10.46v. i wonder if this is the problem.
BTW, yes, wiring will be happening ASAP, and probably for a long time!  |
oh it's not so bad - well, as far as i can remember  _________________ Sneak-Thief - raw electrofunk |
Posted: Fri Sep 22, 2006 2:04 pm Post subject:
No, the main thing is that it's stable. Being out by a little bit wouldn't matter, as long as you callibrate to that, it shouldn't change. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Oct 16, 2006 5:37 am Post subject:
Okay, so I've started wiring up. I've never been so excited about the prospect of listening to a sine wave!
I came up with the idea of doing multiple shielded signal runs using USB cable. I found about 8*2m ones in my junk box which I got given when I was at Jaycar. They are literally 4 conductors inside a really good foil and braid shield. Does anyone know any reason why I shouldn't use them? The main thing I wanted them for was to bring my Sqr/Tri/Saw/Sine outputs up to the selector switches, but do I need to worry about crosstalk? I can't imagine I do with signal levels like that, but what do you dudes think? _________________ What makes a space ours, is what we put there, and what we do there. |
deknow
Posted: Mon Oct 16, 2006 4:09 pm Post subject:
uncle k,
if it's really differant wavforms from the same oscillator, i really doubt a little crosstalk would even be noticeable...after all, wouldn't they all be in phase all of the time?
deknow |
Posted: Tue Oct 17, 2006 5:54 am Post subject:
Yeah, I realised today that I told someone else (zipzap?) here that they only needed to worry about shielding the noise cables. So I've kind of answered my own question really. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Oct 22, 2006 7:22 am Post subject:
Here are the latest pics.
Description: |
Here's the case finished. It turned out solid as the proverbial brick shithouse! |
Filesize: |
175.73 KB |
Viewed: |
430 Time(s) |
Description: |
Front panel, half dressed. |
Filesize: |
184.71 KB |
Viewed: |
497 Time(s) |
Description: |
What's inside, with the oscillators half wired up. |
Filesize: |
160.69 KB |
Viewed: |
503 Time(s) |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
toybox
Joined: Aug 03, 2005 Posts: 176 Location: chicago/peru,illinois usa
sneakthief
Joel
Posted: Mon Oct 23, 2006 4:20 am Post subject:
awesome work, can't wait for the sound samples
do you have a big pointy wizard hat to wear while you play it? |
Posted: Mon Oct 23, 2006 4:37 am Post subject:
Hey Sneakthief,
I've just finished wiring the VCOs, and I've realised that I need to do some fine tuning of the +/-10V reference. R1 & R4 were originally s'posed to be 267R and 287R (not sure why) now the updated schem shows them as 270R. I'll change them to be matched 1%, and the 1K5s, for which I used 5% carbon, I'll be changing to 1% as well. Laurie says on that schem to adjust the 1K2s for perfect +/-10V so I'm going to put in 200R 25 turn trimmers in series with 1K1s 1%. Aside from that everything seems to be working fine. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Oct 23, 2006 4:45 am Post subject:
Of course not! People who build the "Wizard" wear wizard hats!
http://www.elby-designs.com/asm2-wizard/asm2-wizard-about.htm
I have a very impressive Sorcerer's hat to wear. _________________ What makes a space ours, is what we put there, and what we do there. |
Joel
Posted: Mon Oct 23, 2006 5:14 am Post subject:
Ah, my mistake
(off to build the ASM2-Dunce.....) |
sneakthief
Posted: Mon Oct 23, 2006 5:32 am Post subject:
still haven't calibrated my +/-10v reference yet... i swear i'll get around to it!
ps. i heard the ASM-2 Dunce hat is easy to make  _________________ Sneak-Thief - raw electrofunk |
questionable
Joined: Aug 27, 2006 Posts: 42 Location: southern california
Posted: Sat Oct 28, 2006 10:15 am Post subject:
any bleeps and/or bloops out of that thing yet? _________________ Sounds Questionable |
Posted: Sat Oct 28, 2006 2:33 pm Post subject:
Yep,
I've got the oscillators running. I need to work out a problem with the V/Oct tracking, then I'll move onto the VCFs. I'll post some samples as soon as there's something decent happening. _________________ What makes a space ours, is what we put there, and what we do there. |
sneakthief
Posted: Sat Oct 28, 2006 2:56 pm Post subject:
re. v/oct tracking - Laurie's instructions didn't work at all for me. Since both of my vco's have the same issue, I think there's something fishy but I haven't quite figured it out yet.
Let me know what kind of calibration issues you're dealing with. I want to get to the bottom of this too. _________________ Sneak-Thief - raw electrofunk |
Posted: Sat Oct 28, 2006 3:59 pm Post subject:
sneakthief wrote: | re. v/oct tracking - Laurie's instructions didn't work at all for me. Since both of my vco's have the same issue, I think there's something fishy but I haven't quite figured it out yet. |
The problem I got was that with a CV of 5Volt I couldn't adjust the V/Oct trimmer to get 5 Octaves difference from the original frequency. I could only get just over 3. Is this what happened for you too?
The newest update of the schem shows 2*TL084s in each VCO, now, even though my original BOM shows TL084s, for some reason I've got two LF347s installed. I put them in ages ago so I've forgotten why that is different. What quad op-amps have you put in yours?
I've already e-mailed Laurie about it, and I'll keep you informed about the fix. Apart from this, it sounds really good, and the waveforms are very close, without me even doing any shape adjustments yet. I'm sure it's something simple. _________________ What makes a space ours, is what we put there, and what we do there. |
sneakthief
Posted: Sun Oct 29, 2006 12:55 am Post subject:
I've got 2 tl084's per vco. My problem is that when I use 5v on the cv-input (with nothing else connected), I can get the proper frequency, but the tracking is wonky.
That said, I can still get several octaves of decent tracking, just not as many as was claimed. As I said before, I think this might be related to my +/-10v reference not being calibrated yet.
michel _________________ Sneak-Thief - raw electrofunk |
Posted: Sun Oct 29, 2006 2:44 am Post subject:
I checked the datasheets for the LF347 and the TL084 today, and the large signal gain for the 347 is 100 V/mV whereas the 084 is 200 V/mV. I'm pretty sure that's my problem sorted out right there, but I'll see what Laurie reckons. _________________ What makes a space ours, is what we put there, and what we do there. |
sneakthief
Posted: Sun Oct 29, 2006 1:40 pm Post subject:
just got a message from Laurie: seems that TL074's may be the way to go for the exponential converter (instead of a tl084). i'll try this it and report back how it works. _________________ Sneak-Thief - raw electrofunk |
sneakthief
Posted: Mon Oct 30, 2006 4:36 am Post subject:
I changed over the exponential converter opamp to a tl074 and I now get good tracking over 5 octaves. Great! _________________ Sneak-Thief - raw electrofunk |
Posted: Mon Oct 30, 2006 5:00 am Post subject:
Cool, I'm glad your problems sorted.  _________________ What makes a space ours, is what we put there, and what we do there. |
sneakthief
Posted: Mon Oct 30, 2006 8:05 am Post subject:
Uncle Krunkus wrote: | Cool, I'm glad your problems sorted.  |
Well I built mine first! heheh. And to not make this post a total waste, I just finished wiring my 2nd SN-Voice *yeehaa* _________________ Sneak-Thief - raw electrofunk |
Posted: Sat Nov 11, 2006 6:18 am Post subject:
Both VCOs and VCF1 wired up and running really well.
It turns out that I had some old component values and a couple more things to sort out with this "prototype" board I got. I've tracked it all down and sorted it out. I definately feel like I'm learning more and more as things progress.
I've got to get some modulation sources happening!  _________________ What makes a space ours, is what we put there, and what we do there. |
