today> Bill Fox solo tonight! Chez Mosc
Softpot Ribbon Controller
Page 24 of 28 [684 Posts]
Goto page: Previous 1, 2, 3, ..., 22, 23, 24, 25, 26, 27, 28 Next
wetterberg
PostPosted: Wed May 20, 2009 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Thanks, guys. Very Happy
No, the sequencer is not part of the standard feature set, but, as it is now, it's a fairly simple circuit. I've just got the stage selection in; ... In the meantime, I can post the schems of what I have now - it's pretty straight-forward.
oh yes please!!! I've been looking for a simple VC address circuit Very Happy
Scott Stites
Audio files: 96
PostPosted: Wed May 20, 2009 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, no prob. I don't think everything in this circuit will be needed by a CV address system - it's sort of Appendage-centric, but it'll probably get you pointed in the direction you want to go.
This is just a quick "Is this worth it?" validation - I wanted to see if the concept was worth the effort (I certainly think it is). So, stuff like how the 10V reference and range control are implemented are just expedient contrivances. Same thing goes with the CD4516 config - the hooks are there for clocking, direction, etc, but not installed. I just wanted to see if the addressing was a good thing to have.
I'm not crazy about the LM339 performance here. The hysteresis values were taken straight from the datasheet, but on the decision points between steps the 339 still can break into oscillation if you hit the exact point on the ribbon. I'll probably look at going in a different direction there (I went with LM339s because I have a bunch of 'em). Heck, maybe an LM3914 in bar-graph mode would work. In any event, the direction I'm headed is to incorporate this into a linked/synchronized 8X2/16X1 sequencer that I actually designed back before the Klee. May not be necessary, because Bill is a whiz with programmed parts.
6K9 is my value for my low level LEDs; it can be any value you like that drives an LED to the brightness of your hearts desire. The resistor string is made up of 10K resistors, BTW (I neglected to put that value on the schematic).
In any event, this is the exact circuit I used on the last two videos.
Cheerios,
Scott
Appendage Sequence Initial Schematic
 Filesize:  140.65 KB
 Viewed:  492 Time(s)
My Site
TekniK
PostPosted: Wed May 20, 2009 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
the direction i saw with the option is that u can use the(or several) ribon controllers like a serge tkb where u can 'glide' between the zones like u can on a tkb.
I already imagine me to have 4 of these in front of me Smile
an amazing good idea those zones per pitch implement
Scott Stites
Audio files: 96
PostPosted: Wed Jul 15, 2009 2:03 pm    Post subject:
Subject description: Appendage Meets MIDI Meets IKC
According to some guy by the name of State Machine, his Appendage has gone MIDI (I'm sooo glad I named the thing "Appendage" Laughing ).
He sent the proto-group an email a couple of days ago:
I am excited to say that I tested the MIDIfication (Phase 1) of my Appendage tonight and I am very excited about this. I setup up the Appendage along side my computer rig running Ableton LIVE and an instance of Spectrasonics Omnisphere "power synthesizer"on a MIDI track. I then patched the Appendage MIDI OUTPUT to my Novation MIDI interface, Port 1, connector and set the channel to accept MIDI data from this port at the channel set by the Appendage digital MCC unit. I used "MIDI -OX" for MIDI data analysis to view the incoming data from this MIDI port along side my sequencer. The analog MIX OUT of the Appendage is "normaled" on my panel to the CV input of the CV2MIDI adapter as well as the GATE OUTPUT to the GATE input of the CV2MIDI adapter. They can, however, be patched over from other sources by simply inserting a jack. It was tuning time. As I viewed the MIDI note data and tapped the low and high points of the ribbon, I adjusted the INIT & OFFSET controls to set a 2 or 3 octave span across the ribbon, 24 or 36 counts respectively.
The fun then began !!! I layered 3 patches at a time in Omnisphere and played for about 3 hours straight !!!!!!! Holy cow what fun that is ..... Scott, your Appendage and my CV2MIDI adapter work so well together !!! This is so much fun playing my digital and analog synths using a single RIBBON CONTROLLER. Now with this AND the IKC, I can simultaneously control my analog and digital gear .... This whole thing sunk into one big package will be soooo cool !!! The master plan is coming together !!
This is THE FIRST MIDI capable Appendage !! Next, I will add MIDI continuous controllers (CC's) to my firmware and digitize the SLIDE, BEND, TFS. With a small modification I shall add [4] 2:1 analog switches, thus I will then have a total of 10 channels of analog signaling I can digitize with up to 10 bit resolution on each channel but right now my firmware divides full scale by 8 so that I can stuff 7 bit values into my MIDI data stream. Right now I use one CV from the Appendage, and a master VOLUME "CC#7". Adding the SLIDE, BEND, TFS will account for using 5 channels with 5 left over for other MIDI controllers that I can route into my software synthesizers. This is Phase 2.
Bill went on to explain phases 2 through 5, but I'll let him reveal that in his own good time.
This really excites me - I'd love to control my humble SH-201 with my Appendage. Speaking of Appendage, the design has been in the can for a fairly long time. What's holding things up is me - I've got about two thirds of the build doc done.
Pics of Bill's setup: I probably should let Bill point out what is what - I may be getting things mixed up!
 Filesize:  28.32 KB
 Viewed:  20277 Time(s)
Bill's setup - the Appendage board is board towards the bottom.
 Filesize:  80.89 KB
 Viewed:  338 Time(s)
 Filesize:  47.1 KB
 Viewed:  351 Time(s)
 Filesize:  67.44 KB
 Viewed:  330 Time(s)
My Site
PostPosted: Wed Jul 15, 2009 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
boyz, you rock!
in the last weeks i sometimes thought of the appendage controller and the softpots i already have in my drawer.
and then is there still the awesome IKC sitting there and waiting to get built. as bill said, now everything starts to come together! i am very excited about this.
a fatar/IKC and an appendage controller in one cabinet! that will be awesome. Very Happy
PostPosted: Thu Jul 16, 2009 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott, thanks for posting this information and photos of which I will explain in a moment. Phase 1 is complete. Phase 2 is in the works and 90% of the software has been written and tested and the extra circuit board is being constructed with the remaining phases of the project are outlined below. I hope this will be a part of a line of new expansion boards that can interface to the Appendage Touch Ribbon Controller. The first photo from your post is the prototype shield that attaches to the main MCU board. This contains a limiting buffer amplifier, all interface connectors, and the recommended MIDI electrical interface by the MMA for MIDI INPUT and OUTPUT. The next photo down is the Appendage front panel, MIDi adapter & Appendage PC boards. The next photo down is a close up of the adapter board with shield stacked onto the MCU board. It also shows the interface cables attached. The last photo is some of my panel wiring and the adapter card next to this. As the prototype job gets larger, more and more things get mounted to the temporary plates on the rack assembly.
Appendage MIDI Adapter Specifications and project Phases (Rough Draft):
Project phases:
Phase 1: Build up MIDI Interface “shield” prototype board, interface to the Appendage. Initial firmware y will perform a simple CV to MIDI NOTE ON/OFF conversion.
Phase 2: Add MIDI continuous controllers (CC's) to my firmware and digitize the SLIDE, BEND, TFS. With a small modification I shall add [4] 2:1 analog switches, thus I will then have a total of 10 channels of analog signaling I can digitize with up to 10 bit resolution on each channel but right now my firmware divides full scale by 8 so that I can stuff 7 bit values into my MIDI data stream. Right now I use one CV from the Appendage, and a master VOLUME "CC#7". Adding the INIT ,SLIDE, BEND, TFS will account for using 6 channels with 4 left over for other MIDI controllers that I can route into my software synthesizers.
Phase 3: Add 24 PPQN sync, 1/8th, 1/16th, 1/32nd note clock outputs for analog sequencer synchronization to a MIDI clock stream thus synchronizing both computer and analog sequencer. All outputs shall be TTL/CMOS compatible, fully buffered via 74HC244 with series protective 100R resistor. Synchronization pulses will only be generated when a) the device is receiving MIDI TIMING CLOCK from another source and if the unit has received a MIDI START COMMAND. Clocks will turn off when the device receives a MIDI STOP command. There is, however, an MIDI START/STOP OVERIDE so that the device will generate synchronization when only the MIDI TIMING CLOCKS are being received.
NOTE: This phase of the software is nearly completed as testing commenced last evening.
Phase 4: A USB bridge chip exists (FTDI 232) on the “Arduino 2009” MCU board so I can implement OSC (Open Sound Control) over USB so that the Appendage can control parameters in Reaktor and MAX/MSP sound design environments.
Phase 5: Integrate all circuitry onto a single circuit card that will connect to the 20 pin AUXILIARY connector of the Appendage PC board.
NOTE: It is recommended that all those who develop expansion boards for the Appendage utilize the 20 pin AUX connector.
CONTROLS and INPUTS:
NOTE: All MIDI CC messages are ONLY sent out when values are changed (Slider or potentiometer is moved or turned), however, upon power on, the unit will read all the values of the sliders and potentiometers and send their initial values to the MIDI OUTPUT . In addition, the unit will detect if a SNAPSHOT button has been activated and upon receiving this, the unit will read all the values of the sliders and potentiometers and send their initial values to the MIDI OUTPUT.
Sliders & Potentiometers
1) "MIX" with patch over (0-10v) Note: Hard Limited to -0.3V (NOTE NUMER ON/OFF)
Input type (TRS, NC, JACK)
2) “INIT" with patch over (0-10v) Note: Hard Limited to -0.3V (CC#20)
3) "SLIDE" with patch over (0-10v) Note: Hard Limited to -0.3V (CC#21)
4) "TFS" with patch over (0-10v) Note: Hard Limited to -0.3V (CC#22)
5) "BEND" with patch over (0-10V) Note: Hard Limited to -0.3V (CC#23)
6) MIDI MASTER VOLUME KNOB (0-5v) (CC#7)
Input type (10K Linear Potentiometer)
7) GENERAL PURPOSE ASSIGNABLE CONTINUOUS CONTROLLER MESSAGE (0-5v) (CC#24)
Input type (SLIDER POTENTIOMENTER, 60MM, LINEAR, 10K)
8) GENERAL PURPOSE ASSIGNABLE CONTINUOUS CONTROLLER MESSAGE (0-5v) (CC#25)
9) GENERAL PURPOSE ASSIGNABLE CONTINUOUS CONTROLLER MESSAGE (0-5v) (CC#26)
10) SLIDER 4 GENERAL PURPOSE ASSIGNABLE CONTINUOUS CONTROLLER MESSAGE (0-5v) (CC#27)
Pushbuttons & Switches:
SNAPSHOT (PUSHBUTTON, N.O., MOMENTARY) - Upon receiving this, the unit will read all the values of the sliders and potentiometers and send their initial values to the MIDI OUTPUT.
NOTE OFF INHIBIT [NOTE LATCH or SUSTAIN] (SPST ON-OFF SWITCH) – When activated, all NOTE OFF MIDI messages are suppressed thus allowing the receiving device, preferably polyphonic, to continue playing a sustained notes even after the ribbon is released. As each note is latched, the controller will remember each note off suppressed, and from what MIDI channel. Upon disabling this feature, all notes that were suppressed will then have a NOTE OFF command sent to turn just those notes OFF.
ALL NOTES OFF (PUSHBUTTON, N.O., MOMENTARY)- This is a panic button in case any stuck notes are experienced. When activated, all notes being played by the receiving device will be turned OFF.
START OVRD (SPST ON-OFF SWITCH) - Synchronization pulses will only be generated when a) the device is receiving MIDI TIMING CLOCK from another source and if the unit has received a MIDI START COMMAND. Clocks will turn off when the device receives a MIDI STOP command. There is, however, an MIDI START/STOP OVERIDE so that the device will generate synchronization when only the MIDI TIMING CLOCKS are being received.
Danno Gee Ray
PostPosted: Thu Jul 16, 2009 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the Appendage PCB available for purchase by the general public?
Or, is it still only available to the "New Rube Golberg Club"?
PostPosted: Thu Jul 16, 2009 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dan !!
The PC board will be distributed by sMs Audio Electronics, that be me ... Very Happy The first round of boards will be by pre-order and the announcement for purchase will be a separate thread. As usual, I will take PCB orders for a predetermined amount of time, place the order, then ship when they arrive.
It's a large board, 8.5" x 4" and will cost about $40.00
Click on the attachment to view the assembly of the final production PC board.
If folks are interested, I may source parts kits but would have to get some feedback here to see if it's worth the go.
Also, All my schematics and source code for the MIDI adapter I and Scott have been writing about will be open source and free to download ....
Bill
 Filename:  appendage_pcb_layout_rev107E.bmp
 Filesize:  181.39 KB
 Downloaded:  403 Time(s)
Adam-V
PostPosted: Thu Jul 16, 2009 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill, you are the man!
I'd be keen to see a parts kit for this. I have trouble finding the time to build any projects these days let alone finding time to source components. I've still got 4 Klees, 4 UD-1s and 6SN-Vs to build amongst many other projects.
Adam-V
Danno Gee Ray
PostPosted: Thu Jul 16, 2009 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bill,
Most awesome news!
I was just running out of saliva from my Pavlov's Dog imitation....You guys ideate...I salivate. LOL
Damn nice work there all of you. Hope you didn't mind the tongue in cheek remark about the "New Rube Goldberg Club"...I began to feel like the neghbor down the street from the Hot Rod guy, listening to his Big Block with Blower purring away, wishing I had one o' those.
When it comes out, I'm in.
Again, most excellent work by you all!
Scott Stites
Audio files: 96
PostPosted: Thu Jul 16, 2009 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
We kept the number of pulleys down to a bare minimum. Laughing
Bill - is a sequined cape included in that potential parts package?
BTW, dang - can't remember his handle on e-m, but Joe the Walking Stick guy can make a nice ribbon assembly that will be compatible with the Appendage. Hope he chimes in. His site is:
http://members.cox.net/ribboncontrollers/
Cheerios,
Scott
My Site
PostPosted: Fri Jul 17, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Dan - Not offended at all man !!! It was funny !! Laughing
Scott --- A cape sequined with "Stites Appendage" across the back !!!
Adam V -- OK< your getting me closer to a decision . AND, I just recieved anothr mail saying they really wanted a kit to ...
Alos, if those who may be interested in adding the MIDI stuff I have been talking about, this is the display that is compatible with it ....
http://electro-music.com/forum/topic-32751.html
Thanks guys ....
Bill
mark_olson
PostPosted: Fri Jul 17, 2009 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, if a little more peer pressure would help, consider this: I've been saving my pennies since that day long ago when Scott first suggested the possibility that a kit might be forthcoming. Smile
Mark
PostPosted: Fri Jul 17, 2009 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh the pressure, the pressure .... I am caving into the pressure Shocked
Looks like I will have to work up a kit and pricing. I really think the softpots will need to come with the kit but may come standard with the 500mm units. It may also include the isolated TRS jack and pin strip that the softpot attaches to.
OK, lemme' think about this.
The kits will probably be on a pre-order basis like the PCB BUT I am fairly quick, and my reputation is not bad either ... wink wink ..., to deliver once I get all my stock in.
OK
Thanks .....
Anymore peer pressure by the way ????
Danno Gee Ray
PostPosted: Fri Jul 17, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah...OK...More pressure...I have a crystal ball, peer into this!
..."You will do the kits....you will do the kits"....
How's that for peer pressure?
aetherpulse
PostPosted: Fri Jul 17, 2009 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love a kit!
RKHobbs
PostPosted: Fri Jul 17, 2009 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Piling on the pressure...
I'll pre-order a PCB and a parts kit. Sequined cape in red please.
Rob
diablojoy
PostPosted: Sat Jul 18, 2009 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
there are 2 versions of ribbons available, the soft pot and another called
hot pot . which one to use ? there are some distinct differences,
soft pot 500 mm
100 - 10k
poly base
$25 each roughly
hot pot 500 mm
100 - 20k
fibreglass base
$30 each roughly
supposedly has a better feel
has any one tried the hot pot ?
will it work as well considering the differing resistance [less accuracy over given distance]
thinking of buying at least 4 of these
p.s. state machine have you checked out midibox gm5 module as a way of providing usb to midi connectivity it is a very good solution that is already up and running.
www.sparkfun.com/commerce/product_info.php?products_id=8681
www.sparkfun.com/commerce/product_info.php?products_id=9092
adambee7
PostPosted: Sat Jul 18, 2009 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd grab two of these. Really good work guys. Very Happy Very Happy Very Happy
slo
PostPosted: Sun Jul 19, 2009 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd get a parts kit too, saves a lot of hassle. I think the kit should be 2 choices, with or without the softpot, 'cause some of us have the ribbon already, just waiting for the day we can put the cape back on.
George
Randaleem
PostPosted: Wed Jul 22, 2009 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
http://members.cox.net/ribboncontrollers/Cheerios, Scott
Hi Scott,
At Muffwiggler, he goes by Chromium. Not sure about his handle here either? But agreed, he makes nice ribbon controllers! Kind regards, Randal
Randaleem
PostPosted: Wed Jul 22, 2009 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bill, Schematics? Or has this become a PCB/kit only offering?
robotfunk
PostPosted: Thu Jul 23, 2009 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Interested in PCB + Kit here
machine.cuisine
PostPosted: Thu Jul 23, 2009 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd do a PCB and KIT for sure.
"There's an audiophile born every minute!" - P.T. Barnum, paraphrased
Sound
PostPosted: Thu Jul 23, 2009 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
sMs Electroncs Kits for ever! Very Happy
One here.
