Softpot Ribbon Controller
Page 7 of 28 [684 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 26, 27, 28 Next
Scott Stites
Audio files: 96
PostPosted: Sun Sep 07, 2008 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian! Very Happy
And the FET switch worked perfectly!! When set for no drop, there is no discernible difference in side to side motion of slide. Finger wiggle vibrato is dulled, but the hammer-on lag more than compensates for that. Now one can slide to any point, release, and not worry about detuning. Bend offset is no longer affected, because the first sample taken (when both initial and slide S&Hs take a sample simultaneously), there is no lag. The signal to initiate the lag comes from the flipflop controlling the gate. The gate goes high immediately after the first sample is taken, so any subsequent samples taken by the slide S&H are cushioned by the cap.
I've got it set up as a potentiometer control. If you don't want the compensation (and there are situations, believe it or not, that you may not), you simply dial it out. And you can dial it to just where you want it (narrower ranges will need less compensation).
Now, what situations would you choose to eschew the compensation? Well, the video of me jamming out that Antman posted a few posts back is one example -that was a simple gated signal from the ribbon controller. Gating the Appendage with no release time masks the detuning. Here you can have full minute finger wiggleage vibrato with no worrys. Introducing release time begins to expose the drop in pitch when the finger is removed. However, I plan to leave the hold switch in as well (it doesn't add any more parts other than a diode and could be left off at the builder's discretion). It's pretty easy to use (you just press the switch then release pressure), and allows a greater degree of expression. A nice feature of the hold switch is it allows one to pound out steps while sliding. There is a certain technique for avoiding the drop as well without using the hold switch or compensation, though it takes practice. For bug music, all of this is pointless. Laughing
For controllers, one would probably set-and-forget the lag time and not worry about the hold switch. This stuff is for if the touch ribbon is the main instrument board itself.
None of this, of course, affects the initial note CV.
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Sep 07, 2008 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
After playing with it since my last post....
Cool Shocked Cool
This just puts it into the stratosphere!!!
My Site
Scott Stites
Audio files: 96
PostPosted: Wed Sep 10, 2008 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
The detune upon release wasn't the squish factor at all. I just had to up the value of a component by about X1500. Laughing
Thing is, I fell in love with the action of this lag circuit that I put in, and will keep it. It really is pretty much like the legato function a lot of synths have (my SH-201 has it) - it's a mode of portamento that doesn't glide on individual notes, but if you press a key while pressing another key, the note will glide from one to the next.
Wha? Legato on a ribbon controller? Aren't they supposed to glide by design?
If you hammer-on with the Appendage, it will step to the hammer-on value. With this glide circuit, it will glide to the hammer-on value. It makes for a really nice sweep, and also is great for really deep vibrato that would require a wrist-snapping movement otherwise. And you can make a VCO sound like a l'il birdie with it, which is worth the price of admission alone.
My Site
HL-SDK
PostPosted: Wed Sep 10, 2008 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
{jumps on the bandwagon}
I heard about this project indirectly from the sdiy list, and I'm surprised you all are still using just one sensor. Almost the first thing I thought of was a bank of 8-16, but not for doing CV work, for interfacing with pure data or max msp (too $$ for me).
Then I thought of multitouch and I feel that that may be out of my league - albeit infinitely cooler.
How about a sample and hold that keeps the value after finger has been released, so we don't have to use some sort of hold button, there is a switch that remembers the value of the softpot when finger is released.
Try perhaps lighting to go along with these, like LEDS underneath them?
I might get one of these to see if I can work out something
Scott Stites
Audio files: 96
PostPosted: Thu Sep 11, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
How about two? Wink
That's exactly what the Appendage does - it holds the value of the initial position and the last position pressed. The hold switch (which has been dropped) was to help in keeping a detune from happening upon release. The design has been improved so that does not pose an issue (the considerable detune heard was a corrected design flaw, not "finger squish"), hence the removal of the hold switch.
The bend voltage is derived from the relative value of the initial and slide S&Hs, that's why there are three voltages available from this portion of the circuit.
I specifically avoided using a pressure sensor. There's nothing stopping someone from placing a pressure sensor underneath the appendage. However, that complicates the build process considerably (IMO). The appendage as it is can be glued to one's ass and still work. The appendage produces gates, trigger and CVs reliably without the use of a pressure sensor. That's why I refer to it as a "touch ribbon" rather than just as a ribbon controller.
That's always an option. Very Happy
Cheerios,
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Sat Sep 13, 2008 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The design is still evolving. Last night/today I worked out how to do multi-touch without altering the basic structure. Then I figured out a better way. Laughing
Speaking in preliminary terms, this capability will greatly expand what one can get out of a single touch ribbon.
The new voltages I envision will be:
Initial CV 2
This CV is a fixed CV, like the initial CV of the current design. When you first apply pressure, Initial 1 and Initial 2 will be at the same value. When you apply a second point of pressure, Initial CV 2 will assume the value of Initial CV1 plus the voltage proportional to the relative distance between the two pressure points. A gate and trigger for CV2 will fire at this time. I'm thinking I can finagle it to where if the second pressure point is above the initial pressure point, the CV will be higher than Initial, and below the initial pressure point, the CV will be lower than the Initial. Also, this CV should change to different points when the second pressure is released and reapplied at a different area. This will, in effect, make the Appendage a duophonic touch ribbon.
Slide CV2
This CV is not fixed, but slides relative to the position of initial contact.
Bend CV2
This CV is like the current Initial Bend. The second point of contact will output a zero voltage, and bend high or low depending on the direction of movement of the second point of contact.
Relative Position CV
This CV outputs a voltage directly proportional to two different points of contact. I believe it can be made higher or lower, depending on which side of the initial point of contact the second point of contact goes.
The second position voltages are *not* divider based, but are based on the current passing through the SoftPot. They are whole increments, unlike the current Appendage hammer-on voltages. The Appendage still uses voltage for detection, but the means to manipulate it into doing this stuff has been staring me in the face for quite some time - I just didn't recognize it.
Currently, the Appendage provides three trigger modes:
1. Trigger - supplies a trigger on each new note event. Hammer-ons and hammer-offs do not retrigger.
2. Retrigger - supplies a trigger on each new note event, and positive voltage transitional hammer-ons and hammer-offs.
3. Hypertrigger - supplies a trigger if you look at it funny. Laughing No, seriously, this operation makes you sound like you have about twenty lightning fast fingers. It supplies a trigger on the following events:
1. Note On
2. Note Off
3. Hammer-On Up
4. Hammer-Off Down
5. Hammer-On Down
6. Hammer-Off Up
You can easily produce some extremely fast runs using Hyper-Trigger. It would also be very handy if you're controlling a drum voice with the trigger - you could produce some outrageous drum fills by gently applying and withdrawing pressure.
The schematics I've posted have been long-since blown past. They're a good starting point for experimentation, but they don't reflect where the Appendage is now. I'll post when I'm ready to put a fork in it and call it done, but rest assured there will be PCBs if you don't feel like jacking with it.
Cheerios,
Scott
My Site
RF
Audio files: 28
PostPosted: Sat Sep 13, 2008 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="Scott Stites"]
... rest assured there will be PCBs if you don't feel like jacking with it.
Cheerios,
Scott
Wathing this evolve has been great -
Very cool stuff!
bruce
Scott Stites
Audio files: 96
PostPosted: Sun Sep 14, 2008 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are some samples of the evolushun:
Hypertrigger is a short demo of the hypertrigger function. Basically I'm just moving my finger over different areas of the ribbon and wiggling it up and down.
Hyper With Autolag is another demo of hypertrigger. All of the "slides" heard in this are actually the autolag. It shows up on hammer-ons.
Hyper Soft is hypertrigger again - I have a slower attack on the EG.
Appendage_HyperTrigger.mp3
Hypertrigger example.
 Filename:  Appendage_HyperTrigger.mp3
 Filesize:  307.88 KB
 Downloaded:  1272 Time(s)
Appendage_Hyper_With_Autolag.mp3
Hypertrigger with Auto Lag
 Filename:  Appendage_Hyper_With_Autolag.mp3
 Filesize:  1.22 MB
 Downloaded:  1247 Time(s)
Appendage_Hyper_Soft.mp3
HyperTrigger with Soft Attack
 Filename:  Appendage_Hyper_Soft.mp3
 Filesize:  1.05 MB
 Downloaded:  1264 Time(s)
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Sep 14, 2008 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a sample that uses the dual pressure positional CV. Basically, if you apply two pressure points, the farther apart they are, the higher the voltage. I have the filter cranked pretty low, and the CV is controlling the cutoff (it's also modulating both VCOs). A hammer-on (widely spaced) cranks it on high (if you listen to the sample, you won't miss that Wink ), a slide of the two pressure points away from each other increases gradually.
The two VCOs are controlled rather interestingly - one is controlled by slide, and one is controlled by slide and bend, so by moving the initial point up and down, the two VCOs detune proportionally.
Appendage_Dual_Pressure_CV.mp3
Dual Pressure CV and stuff...
 Filename:  Appendage_Dual_Pressure_CV.mp3
 Filesize:  3.57 MB
 Downloaded:  1258 Time(s)
My Site
bugfight
PostPosted: Sun Sep 14, 2008 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
woohoo!
totally crazy.
i gots some ribbons now, can i wait or will i breadboard??
not that there's any shortage of projects to keep me busy...
aetherpulse
PostPosted: Sun Sep 14, 2008 8:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
This really sounds like everything I ever wanted a controller for my modular to be! I must have two...
What's the best length of material to get? I probably should start sourcing this stuff to have ready when the circuit is ready for consumption...
Scott Stites
Audio files: 96
PostPosted: Sun Sep 14, 2008 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the Appendage modulation input being modulated by a VCO, which it in turn is being modulated with the modulated slide and bend CV. This puts FM on the CV, which is being used to modulate two sine wave VCOs which are passed through the 2040 filter, which is controlled by the bend voltage. The Appendage is gating/triggering the EG, which is also controlling the filter and VCA.
West_Coast_Appendage.mp3
Appendage FM
 Filename:  West_Coast_Appendage.mp3
 Filesize:  7.65 MB
 Downloaded:  1205 Time(s)
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Sep 14, 2008 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whatever suits the purpose - the circuit would work as a modulator (like pitch/bend), which would be smaller. A main controller (like I'm using it in these samples) is better suited with a longer length. I'm using a 500mm strip - 200mm might be a bit short for that. The 500mm has a resistance of 20K, I think shorter is 10K, but I'm aiming to accomodate any size (and +/-15 or +/-12V power supplies).
Here's another FM sample, with different settings. The creepy beginning was done by gently carressing the ribbon up and down and mildly applying pressure here and there to generate gates/triggers.
Appendage_Nightmare.mp3
A bad FM dream...
 Filename:  Appendage_Nightmare.mp3
 Filesize:  9.99 MB
 Downloaded:  1218 Time(s)
My Site
mark_olson
PostPosted: Mon Sep 15, 2008 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
...rest assured there will be PCBs...
And this is the board that will make me fall off the wagon and break the promise I made to myself (to say nothing of my wife) that I wouldn't buy any more until I'd soldered up a respectable few of those I have accumulated.
Jeez, these samples are just stunning.
Way to go Scott.
Mark
numbernone
PostPosted: Mon Sep 15, 2008 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Samples sounds so much like the ridiculous 1960's academic electronic music that I love so much.
Truly drooling in anticipation to build a few of these.
PostPosted: Wed Sep 17, 2008 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
the softpots arrived today (50mm and circle type/iPOD style Shocked ). now that you incorporated the multitab feature i know i will have to order a 500mm type of softpot. Very Happy
BTW are the softpots stickers? they look like they are but i don't know and don't want to damage them...
Scott Stites
Audio files: 96
PostPosted: Wed Sep 17, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes - the SoftPots have an adhesive strip on the back. Make sure you have something to stick them to before you strip it off. Very Happy
As coincidence would have it, last night I did figure out how to allow the circuit to easily accomodate either 20K (500 mm) or 10K (less than 500 mm) SoftPots - it just requires an extra resistor for the smaller ones.
I tried it with a 100mm and a 200mm last night - it worked great! It was amazing sliding that 100mm and sending the modular from sub-aubdible to supersonic with a slight flick of the finger. Don't worry - you can scale the voltages. Laughing
Scott
My Site
PostPosted: Wed Sep 17, 2008 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
The samples are great Scott and have to agree with Numberone, I love the sound of the 1960's style electronic music and this definitely brings us there man !!! Good show !!!!. PS: I will reply to your PM's tomorrow at work Wink
Bill
bubblechamber
PostPosted: Wed Sep 17, 2008 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
really great samples. this is very cool and i can't wait to see the end result. keep up the amazing work.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
Scott Stites
Audio files: 96
PostPosted: Sat Sep 20, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I hope the craziness of the samples I produce doesn't give the impression that's all the Appendage is good for. Very Happy
The thing is, it's ribbon controlled, and learning to play a ribbon controller for standard western tonality is much like learning a new instrument, like a trumpet or a cello. Obviously, quantization would make that process easier. Of course, that is not the only intended use of the Appendage - using it as an expression or gestural controller is very intuitive.
Using voltage as the source of the ribbon provides a very precise positional voltage when one point of pressure is applied. You can set the range so that you have a clear idea where octaves, steps, and so forth are. Using two points of pressure has a much more "west coast" feel. If you have two points that are an octave apart, pressing one or the other will produce a difference of one octave on the initial and slide outputs. Pressing both will produce an interval between the two octaves on the slide output. The bend output reflects this difference as the direct proportion between the two - so it will output something on the order of half a volt, up or down, depending on which side of the first point of pressure you apply the second point of pressure.
I've said little about it, but for some time now, the Appendage has been producing a fourth voltage I've come to call TFS (short for Two Fingered Salute, not the other meaning). This voltage reflects the distance between points of pressure in the form of a positive voltage. Using voltage to feed the ribbon, the response of this voltage is roughly logarithmic - it is not a linear relationship. The farther apart the two points of pressure are, the more sharply it will rise. It's a musically pleasing response, particularly when controlling a filter.
Using voltage to feed the ribbon allows one to hammer-on and hammer-off freely above and below the initial point of pressure. It also allows truly remarkable relationships between the initial, slide, bend and TFS outputs in ways I cannot describe - it would take a video to really demonstrate it.
There is another method of deriving voltages from the ribbon, and that is by feeding it a constant current source. There are advantages and drawbacks to this method.
The advantages are that hammer-on intervals and TFS have a direct linear relationship to their respective positions on the ribbon. The disadvantage is that it relegates one to low note priority. In other words, if one hammers on above the initial point of contact, the slide voltage will not change. It only changes if one hammers on below the initial point of contact. This does, however, provide a way to independently sweep a filter or some other parameter without changing the original pitch value by using the TFS voltage. The voltage method allows this with the initial note value, but the advantage here is that the original position can still slide and bend while independently controlling the TFS.
The point of this long-winded post is, I like both responses. Why does one have to choose between one or the other? The latest experimentation proves that one does not. The Appendage now on the breadboard provides two different operational modes, which I like to call "West Coast" (voltage fed) and "East Coast" (current fed). It's literally like having two instruments in one.
And - the left note priority of the "East Coast" mode? It can be either left or right note now, which was easy enough to implement, and which, in itself, provides some pretty cool things when using AutoLag.
All of this paves the way to true duophonic control of the Appendage, which will be realized on the optional second board I'm tentatively calling the "Control Freak". This second voltage will reflect the value of position two, complete with its own gate, trigger, intial, slide and bend outputs. It will be linear in East Coast Mode and non-linear in West Coast Mode. The control freak will allow you to control a large number of modules in surprising ways from a single controller.
I haven't even mentioned the control mechanisms concocted for the original board involving the S&H properties of the Appendage. These will tie the operation of the Appendage more intimately with the operation of keyboards, sequencers and nearly any module in a modular synth in a number of ways. But I probably should stick a fork in this post....
Cheerios,
Scott
My Site
bugfight
PostPosted: Sat Sep 20, 2008 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome news, esp providing both responses...
looking forward to playing with this.
no point in my trying to breadboard since you have gone way past the orig
meanwhile i can work on shortening the queue...
(and thus breaking a historical trend)
bubblechamber
PostPosted: Sat Sep 20, 2008 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is looking better and better. thanks for all the work you're putting into this Scott.
i heard back from Spectra about samples, and they charge, with a 2 piece minimum. their prices are exactly the same as Spark.
Scott Stites
Audio files: 96
PostPosted: Sat Sep 20, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, for crying out loud.....
I'll describe what I've been working on today, though the ramifications/applications I'll leave up to y'all. I'm talking LFO/Noise here, but think "Keyboard/Sequencer" (do it at night instead of sleeping, that seems to work for me Laughing ).
OK - the Appendage is really just a specialized, very high performance S&H circuit that also de-glitches the ribbon and scales the voltage response from the ribbon (along with autolag and producing gates and triggers, etc.). It actually consists of three sample and hold circuits, though one of them is not "heard" - it is used in discriminating between "valid" and "invalid" voltages originating from the SoftPot tap.
Of the two sample and holds that are "heard", one takes only one sample per pressure event, while the other constantly samples during a pressure event. The one that constantly samples, though it is operating as a sample and hold, actually behaves like a Track and Hold. The reason I just don't do go ahead and make it "Track and Hold" has to do with the reliability of signal acquisition (I tried it this week, Ian). The end result is that the response of the ribbon is 100% reliable and smooth as butter. You touch it, it gates, triggers, and produces voltages depending on where you touched it. You touch in more than one spot...well, I already covered that. Laughing
Back to the Sample and Hold function. I've created two inputs: signal input and gate input. The signal input goes straight to the S&H section. The gate determines how and when the Appendage reacts to the signal input. There are three modes of gating:
1. Ribbon actuated gate. You press the ribbon, and the Appendage samples the incoming voltage, produces a trigger, and holds a gate as long as the ribbon is pressed. This is essentially a finger controlled sample and hold. As long as the pressure is applied, the initial output holds the first sample, the slide output tracks the incoming signal, and the bend output generates the differential between the two. The TFS signal is still active, and is loads of fun to control things while all of this is going on. When you release the ribbon, the initial still holds its value, the slide holds at the last point before pressure was removed, and so does bend (all of these hold for frikkin' ever - this S&H system kicks ass).
2. Ribbon Controlled External Clock - You plug in an LFO to the gate input (this acts as a clock), but nothing will happen until you press the ribbon. When the ribbon is pressed, the S&H begins sampling in sync with the LFO. All of the above outputs apply, only the trigger will trigger on each clock impulse and the gate will gate while the clock is high. This all occurs as long as pressure is applied. When pressure is released, the slide and bend voltages hold at their last point, initial maintains its signal, and the gate and triggers cease. TFS operates normally while pressure is applied.
3. Clock Controlled Appendage - The LFO will constantly clock the Appendage, which will then act as a "normal" clocked S&H. Triggers repeat, gates repeat, in sync with the clock. Initial takes the first sample, slide and bend track while the clock is high, and hold while the clock is low. The only effect pressing the ribbon will be that you can still control the TFS signal.
The Appendage is designed with a modulation input as well, and also is capable of mixing its signals together. For example, mixing the TFS with initial allows one to bend the sampled signal around while all of the above is going on. It also allows the "tracked" signal to be mixed in, which is particularly cool when sampling a noise source.
So "free" with your appendage you get a very unusual, extremely low droop S&H to boot.
Now - the clock signal does not have to be an LFO - it can be a gate from a sequencer or a keyboard - which would be useful while while sampling the output of the sequencer or keyboard.... Also, the Appendage does not have be sampling an external signal in these modes - it can be looking at the ribbon voltage instead. Think about controlling a ribbon that's producing notes in sync with a sequencer. Wink
None of this adds any ICs or excessive parts, I'm just exploiting what's already there.
There's more, but that's all for now....
Cheerios,
Scott
My Site
Audio files: 308
PostPosted: Sat Sep 20, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked this thing is getting even nutser than the Klee Cool
I might want to try to mod one for use with digital synths maybe ... which shouldn't be too hard as you already split out everything comfy & nicely ... can I sign up for the board and the kit already?
aetherpulse
PostPosted: Sat Sep 20, 2008 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It sounds like you went inside my head, looked at everything I wanted a controller fo my synth to be, and then made it! I can't wait to build it.
