Recent Changes - Search:
go to the forum
Contents
Site
Help
« may 2025 · sep 2025 »
    add a calendar item
    Radio / Broadcasting Info
    Radio.BroadcastingInfo History
    Hide minor edits - Show changes to output
    2013-04-08 15:34 [UTC-7] by Blue Hell -
    Changed line 22 from:
    You are only allowed to broadcast material that you own the copyrights for, or for material for which the copyright owner gave you explicit permission, or for material that is in the public domain. Permission can be as simple as the material having been published under a permissive license, or as complicated as negotiating a deal with the copyright holder.
    to:
    You are only allowed to broadcast material that you own the copyrights for, or material for which the copyright owner gave you explicit permission, or material that is in the public domain. Permission can be as simple as the material having been published under a permissive license (like Creative Commons), or as complicated as negotiating a deal with the copyright holder.
    2013-04-04 20:48 [UTC-7] by Blue Hell -
    Deleted lines 0-2:
    [[http://electro-music.com/radio/ |  Attach:Site.Icons/radio_em2.png"Listen Now!"]]
    2013-04-04 20:44 [UTC-7] by Blue Hell -
    Added lines 1-3:
    2013-04-03 21:05 [UTC-7] by Blue Hell -
    Changed lines 22-24 from:
    You are only allowed to broadcast material that you own the copyrights for, or for material for which the copyright owner gave you explicit permission, or for material that is in the public domain. Permission can be as simple as the material having been published under a permissive license, or as complicated as negotiating a deal with the copyright holder. In latter case you should [[Radio.StreamOperators | contact a stream operator]] to discuss your plans.
    to:
    In the latter case you should [[Radio.StreamOperators | contact a stream operator]] to discuss your plans.
    to:
    2013-04-03 21:03 [UTC-7] by Blue Hell -
    Added lines 22-23:
    2013-04-03 19:51 [UTC-7] by Blue Hell -
    Changed line 17 from:
    *Your tracks can be played on the radio as well of course, see the [[(Radio.)AirYourTracks]] section for more on this.
    to:
    *Your tracks can be played on the radio as well of course, see the [[(Radio.)AirYourTracks | Air Your Tracks]] section for more on this.
    2013-04-03 19:50 [UTC-7] by Blue Hell -
    *Your tracks can be played on the radio as well of course, see the [[(Radio.)AirYourTracks section for more on this.
    to:
    Added lines 16-17:
    2013-04-02 18:58 [UTC-7] by Blue Hell -
    Changed line 24 from:
    For more details on this see the [[Radio.ConnectionInfo | Connection Details]] section.
    to:
    For more details on this see the [[Radio.ConnectionDetails | Connection Details]] section.
    2013-04-02 18:32 [UTC-7] by Blue Hell -
    Added lines 1-25:
    !!Radio broadcasting
    {_stub_}
    !!!Show formats
    >>bgcolor=#dee3e7 border='0px solid gray' padding=5px<<
    There are a couple of radio show formats available.
    *The regularly [[ Radio.ScheduledShows| Scheduled shows]] on the main channel, or you can do an irregularly timed one, or even a one off show - these would all be announced on the forum pages. Streaming in this format needs a stream operator to be involved to make a schedule entry for the show and this will take care of automatic forum announcements for it. The streaming itself can involve a stream operator switching your port to the main channel, or you can use a DJ connect to switch yourself into the main stream.
    *Ad-hoc streaming on the open port, or [[Radio.OpenPortStreaming|Open Port Streaming]]. Open Port Streaming will not be automatically announced on the forum pages, but it is possible to put up a forum wide message for it during the show. This model can be used without needing help from a stream operator. This is usually coordinated through the {_chat_room_}.
    *[[Radio.PrivateStreaming | Private streaming]], in this model nothing is announced, but you can share your sounds with other people this way. This is usually coordinated through the {_chat_room_}.
    *Streaming for a special event. This can be very much like Private streaming, except that a stream operator will switch your port to the main stream once your show starts. Or, when you run a regular show, you can use your normal way to connect up.
    !!!General information
    Streaming audio on electro-music.com works with some server side software and some client side software. To be able to stream on our server you will need some client software on your computer. Our servers use the SHOUTcast model, your client will have to be compatible with that.
    To be able to stream successfully a couple of things must be working. There is a connection component (your client to our server), an audio setup component (where does the audio come from on your computer) and a PR component (how your broadcast will be announced).
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-04-08 15:34 [UTC-7] - 1237 views
