Radio / Connect Info Butt
Radio.ConnectInfoButt HistoryHide minor edits - Show changes to output 2023-09-30 11:26 [UTC-7]
by - Little update for very old BUTTon very old Mac
Added lines 10-16:
But also [2023-09-30] .. on and older Mac computer which could not use any BUTT later than 0.1.12 things could be made to work with filling the following fields with some non-empty text .. like 'none': * station name / description [icy-name] * station / info url [icy-url] * genre [icy-genre] Changed line 59 from:
*Password: the password that was assigned to you or public for any of the ports 8056, 8130, 8132, 8134, 8136, 8138. Or public:public for an sc_trans connection (ports 9878 or 9876). to:
*Password: the password that was assigned to you or ''public'' for any of the ports 8056, 8130, 8132, 8134, 8136, 8138. Or ''public:public'' for an sc_trans connection (ports 9878 or 9876). 2018-04-15 18:21 [UTC-7]
by - added a BUTT version requierment Changed line 6 from:
to:
>>lframe<< Changed line 10 from:
to:
>><< Added line 6:
--- Changed lines 10-12 from:
to:
--- Added lines 5-11:
We had a recent (2018-04-14) upgrade for the shoutcast streaming software. It turns out that BUTT version 0.1.15 no longer works due to some password issue. Please upgrade BUTT to version 0.1.16 Not sure about earlier BUTT versions - it is all a bit odd .. as the very very old oddcast streaming tool still works without problems. I did not test edcast or any other tools. Changed line 1 from:
<|[[Radio/ to:
<|[[Radio/ConnectionDetails]]|> Deleted line 22:
Changed lines 24-25 from:
to:
Changed line 26 from:
to:
Deleted line 122:
Added line 23:
>>bgcolor=#dee3e7 border='0px solid gray' padding=5px<< Changed lines 25-26 from:
to:
>><< Changed line 28 from:
to:
>>bgcolor=#dee3e7 border='0px solid gray' padding=5px<< Added line 125:
>><< Added line 6:
>>bgcolor=#dee3e7 border='0px solid gray' padding=5px<< Changed lines 8-18 from:
to:
>><< >>lframe font-size:smaller<< !!Contents (:toc:) (:indent:) >><< [[<<]] Added lines 21-22:
!!Installation Changed line 25 from:
to:
!!Configuration Changed line 6 from:
BUTT is available for Windows and for Mac OSX. to:
BUTT is available for Windows, Linux and for Mac OSX. Added line 16:
>>center<< Changed lines 18-19 from:
to:
>><< Added line 22:
>>center<< Changed lines 24-25 from:
to:
>><< Added line 28:
>>center<< Changed lines 30-31 from:
to:
>><< Added line 43:
>>center<< Changed lines 45-46 from:
to:
>><< Added line 49:
>>center<< Changed lines 51-52 from:
to:
>><< Added line 59:
>>center<< Changed lines 61-62 from:
to:
>><< Added line 78:
>>center<< Changed lines 80-81 from:
to:
>><< Added line 88:
>>center<< Changed lines 90-91 from:
to:
>><< Added line 96:
>>center<< Changed lines 98-99 from:
to:
>><< Added line 108:
>>center<< Changed lines 110-111 from:
to:
>><< Changed line 58 from:
For an sc_trans (DJ) connection (ports 9878 and 9876) you may set a lower bitrate and sample rate (when your upload link does not allow for the preferred settings). Do NOT use different settings for sc_serv connections (ALL ports except 9878 and 9876). to:
For an sc_trans (DJ) connection (ports 9878 and 9876) you may set a lower bitrate and sample rate (when your upload link does not allow for the preferred settings). Do NOT use different settings for sc_serv (DNAS) connections (ALL ports except 9878 and 9876). Changed line 31 from:
*Port: the port that was assigned to you or 9878 for an sc_trans test connection, or 9876 to go live with sc_trans (do not use port 9876 for testing - it will go onto the main stream directly). to:
*Port: the port that was assigned to you or 9878 for an sc_trans (DJ) test connection, or 9876 to go live with sc_trans (DJ) (do not use port 9876 for testing - it will go onto the main stream directly). Changed line 58 from:
For an sc_trans connection (ports 9878 and 9876) you may set a lower bitrate and sample rate (when your upload link does not allow for the preferred settings). Do NOT use different settings for sc_serv connections (ALL ports except 9878 and 9876). to:
For an sc_trans (DJ) connection (ports 9878 and 9876) you may set a lower bitrate and sample rate (when your upload link does not allow for the preferred settings). Do NOT use different settings for sc_serv connections (ALL ports except 9878 and 9876). Changed line 55 from:
*Bitrate: to:
*Bitrate: 128k Added lines 59-60:
For an sc_trans connection (ports 9878 and 9876) you may set a lower bitrate and sample rate (when your upload link does not allow for the preferred settings). Do NOT use different settings for sc_serv connections (ALL ports except 9878 and 9876). Added lines 46-47:
The Name filled in here is the stream name as it will be sent out along with the stream. You could set an URL to your web site in the URL field, but there are no server tools currently that display this information - likewise for AIM ICQ etc. Changed lines 18-19 from:
to:
Attach:ButtMainScreen.jpg Deleted lines 20-21:
[==] Changed lines 18-19 from:
Attach:ButtMainScreen.jpg to:
%lfloat%Attach:ButtMainScreen.jpg Added lines 21-22:
[==] Changed line 18 from:
to:
Attach:ButtMainScreen.jpg |
Edit - History - Print - Recent Changes - Search Page last modified on 2023-09-30 11:26 [UTC-7] - 3893 views
