Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Sun Sep 21, 2008 7:18 am Post subject:
So is this wonder of modern magic going to be available to the common man soon, or are you going to continue to tease us with these seeming feats of magic?
How more plainly can I say it?...I want one!
Thanks for all the great work Scott! |
Scott Stites
Audio files: 96
Posted: Sun Sep 21, 2008 11:03 am Post subject:
| Quote: | | I might want to try to mod one for use with digital synths maybe ... which shouldn't be too hard as you already split out everything comfy & nicely ... can I sign up for the board and the kit already? |
| Quote: | | So is this wonder of modern magic going to be available to the common man soon, or are you going to continue to tease us with these seeming feats of magic? |
That's all being planned. Right now the design is in a state of flux - I'm mainly working on refining the signal acquistion, which is where all of this new stuff is coming from. The goal is to do the switching without a lot of hideous wiring and to keep the switches simple and as few in number as possible. The idea is that one can have the board, but not have to include every little gadget it supplies - some may just want a little ribbon bender, but nothing else, etc., etc. Even the full kanhuna will not be a huge panel experience like the Klee.
Another goal is to keep the circuit parts in the realm of the readily accessible for anyone to get (no unobtainium). Other than the SoftPot itself, the circuit uses widely available parts.
| Quote: | | It sounds like you went inside my head, looked at everything I wanted a controller fo my synth to be, and then made it! I can't wait to build it. |
Actually, your brain was downloaded and put on file some months back. Didn't you read the fine print when you signed up to electro-music?
Today I tried another thing that I've been wanting to implement. It's a special case of applying external signals and gates. It mainly is for taking advantage of the auto-lag circuit. My SH-201 has a portamento mode that only applies glide during legato play (I hope I'm using the right terminology here). In other words, if you play individual notes, there is no glide. If you press one key, then press another, the note will slide up or down between the two. It's a very expressive means of playing a keyboard, and I use it all the time.
The autolag circuit is basically the same thing. It doesn't glide until the first sample is taken, then the glide is automatically initiated. It always does this, but if you have "glide" set to zero, you never hear it on the Appendage. Anyway, I hooked up my keyboard CV and the gate output, and, it worked just fantastic! Even on very, very long releases, no de-tuning from droop can be heard. It's very smooth, and it's as if the keyboard were directly hooked to the VCO - but it's not - it's going through the maw of the Appendage S&H circuitry. The Appendage is actually creating the gates and triggers as well. In this mode, the ribbon does nothing.
Not only does it work for keyboards, but I think it would for sequencers as well, particularly the Klee, which can provide a gate over several steps using the merge switches. The first step would not glide, but as long as the gate was high, the following notes would glide. When the gate drops, the last value is held by the Appendage circuit.
Cheerios,
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 12:25 pm Post subject:
Some handy-dandy artwork. And yes, that is a finger that I'm attempting to draw......
| Description: |
| Filesize: |
17.63 KB |
| Viewed: |
311 Time(s) |
| Description: |
| Filesize: |
18.3 KB |
| Viewed: |
290 Time(s) |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Tue Sep 23, 2008 12:45 pm Post subject:
Scott:
Thanks for giving us the finger. Very tantalizing.
But what we're all waiting for is the video!
Mark |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 12:50 pm Post subject:
More artwork...
| Description: |
| Appendage Gazzins and Gazzouts |
| Filesize: |
13.98 KB |
| Viewed: |
294 Time(s) |
| Description: |
| Appendage General Block Diagram |
| Filesize: |
16.26 KB |
| Viewed: |
300 Time(s) |
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Tue Sep 23, 2008 12:51 pm Post subject:
| Scott Stites wrote: | | ...And yes, that is a finger .... |
you're not fooling me,
i know it's your nose... |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 12:52 pm Post subject:
| Quote: | | Thanks for giving us the finger. |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 12:54 pm Post subject:
| Quote: | | i know it's your nose... |
A month or so ago, it was often my forehead. I definitely, in the course of things, have found unique combinations of swear words..... _________________ My Site |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 1:59 pm Post subject:
Very basic apps.
I don't think I've mentioned it, but I've got State Machine helping out with PCBs and distribution.
| Description: |
| Filesize: |
11.11 KB |
| Viewed: |
242 Time(s) |
| Description: |
| Filesize: |
11.54 KB |
| Viewed: |
249 Time(s) |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 2:51 pm Post subject:
| Scott Stites wrote: | | I don't think I've mentioned it, but I've got State Machine helping out with PCBs and distribution. |
Oh!.......
My layout skills not good enough anymore hey?!?
I knew you were seeing someone else behind my back!! Bitch!!
Just joking, I've got way too much on my plate these days anyway. I couldn't possibly fit in a ribbon controller unless you made an appointment maybe a year or so in advance.  _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Sep 23, 2008 5:08 pm Post subject:
I like the new name Scott Mark III Appendage !! The diagrams really sum up the major modes nicely and you have not even touched on the "Hyper Trigger" modes using drum voices. Much easier I think than trying to explain in pure text I never learned so much from getting the finger. Your finger has such perfectly round nails and the knuckle crease, is that a modified ground symbol from your schematic capture? Oh dear, I must be tired, sorry for the bad humor ........
Bill |
Posted: Tue Sep 23, 2008 5:13 pm Post subject:
| Quote: | | I knew you were seeing someone else behind my back!! Bitch!! |
I believe that long distance relationship with you Andy was getting to Scott, now he only has to travel 1500 miles to see me ...........
Bill |
Scott Stites
Audio files: 96
Posted: Tue Sep 23, 2008 9:17 pm Post subject:
No Andy,
You design a mean PCB (you did a bang-up job on the Klee and the much fabled MPS). It's just that, for this project, Bill's looking at designing an integrated system with analog/digital applications as well as using it as an adjunct to the IKC. He's got all the tools for that kind of stuff right there, so it's just as easy for him to knock out this PCB. Don't think you're going to easily escape proto duties (that is, if you're game).
Isn't that a nicely manicured finger? And, those are painstakingly rendered knuckle-wrinkles, I'll have you know....
Cheerios,
Posted: Wed Sep 24, 2008 12:27 am Post subject:
| State Machine wrote: | | Your finger has such perfectly round nails and the knuckle crease, is that a modified ground symbol from your schematic capture? |
Oh, I think it's pretty clear what's going on here!
How could I have been so blind?!?  _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Wed Sep 24, 2008 6:09 am Post subject:
| Quote: | | Arrrrrr, even pirates want to play with the Appendage ......... |
It's said that the Flying Spaghetti Monster has one for each of its noodly appendages..... _________________ My Site |
Posted: Wed Sep 24, 2008 6:49 am Post subject:
| Quote: | Oh, I think it's pretty clear what's going on here! Shocked
How could I have been so blind?!? |
bugfight
Posted: Wed Sep 24, 2008 8:01 am Post subject:
| Scott Stites wrote: | | ... noodly appendages..... |
woohoo!
when can i get this special "noodly appendage" ? |
Posted: Wed Sep 24, 2008 2:59 pm Post subject:
| Scott Stites wrote: | | ..., but I've got State Machine helping out with PCBs and distribution. |
ha, so the appendage controller is almost cut and dried? together with andy's and bill's TH keyboardcontroller this will be... err... my poor english can't express it!
now my plan is to build 2009 a keyboard synth with these controllers. i am so happy now, can't wait. _________________
Tech Buddy at Random*Source |
Scott Stites
Audio files: 96
Posted: Thu Sep 25, 2008 6:21 am Post subject:
| Quote: | | ha, so the appendage controller is almost cut and dried? |
Yep - the hardest part (signal acquisition) has settled out nicely, and there's a good current source set up for the current mode. The only thing that needs settled on is the output selection - basically determining what we can get away with and still keep it a relatively compact board. That goes slowly, because I can only get real work done during the weekend. Last night I worked out a simple switch arrangement that will allow the different modes to be selected easily, while keeping to common and easily accessible switches (I've been fighting my tendency to use C&K 7211s mainly because they're not quite so common, and they're usually rather expensive).
Cheerios,
fluxmonkey
Posted: Thu Sep 25, 2008 10:55 am Post subject:
| bugfight wrote: | you're not fooling me,
no, i think he he plays by ear...
ta dum. _________________ www.fluxmonkey.com |
bubblechamber
Posted: Thu Sep 25, 2008 11:06 am Post subject:
Cheerios,
Scott |
has anyone tried these? i keep forgetting to order a sample, but it's on my next mouser order list. i have some 7211s to compare them against and i'll try to remember to post the results when they show up.
http://www.mouser.com/Search/ProductDetail.aspx?qs=JTMHOUw%252b%2fhnWG0t2ApqIUA%3d%3d _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
Scott Stites
Audio files: 96
Posted: Thu Sep 25, 2008 12:11 pm Post subject:
| Quote: | | has anyone tried these? i keep forgetting to order a sample, but it's on my next mouser order list. i have some 7211s to compare them against and i'll try to remember to post the results when they show up. |
Wow - never knew that one existed! I'd be interested to know your results. A lot of people are down on Mountain Switches, but I've used them without problems for years now. Last bunch I bought I put into the Klee, and it's been just fine now for a year or so.
I would never have been able to afford stuffing that puppy with NKK, that's for sure.  _________________ My Site |
Dragon's Lair
Joined: Dec 29, 2006 Posts: 205 Location: Hope BC, Canada
Posted: Sat Sep 27, 2008 9:18 pm Post subject:
Great project Scott, if you need beta testers for the boards, count me in.
Did you know that you can now order the softpots directly from Spectra Symbol, I got a dozen 500mm pots from them a couple months ago, for experimenting with my own Pic based Midi ribbon controllers. |
